You need to run "su - nagios" before running the command.
Thank you
Pending check issue
Re: Pending check issue
Here is the result running as "su - nagios" ssax,
[root@MA100DLVMON813 scripts]# su - nagios
[nagios@MA100DLVMON813 ~]$ /usr/local/nagios/libexec/check_icmp -H ma100dlvapl823 -w 3000.0,80% -c 5000.0,100% -p 5
OK - ma100dlvapl823: rta 0.161ms, lost 0%|rta=0.161ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=0.220ms;;;; rtmin=0.110ms;;;;Re: Pending check issue
Is this only occurring for the Ping checks (meaning you have other checks that work properly)?
yes ssax, as of moments this only happened to the "Ping check" all the other services are working fine.
Please PM me a copy of your profile, you can download it by going to Admin > System Config > System Profile and click the Download Profile button in the top right corner.
hey ssax,
I have sent you a PM with the system profile. Thank you for your time.
Thank you, received.
I notice all the Ping services are defined in /usr/local/nagios/etc/static, maybe that has something to do with it.
Are any of the Ping services working?
This is very strange, it should be working, we may have to move this into a remote session, please send an email to [email protected] with a descriptive subject and a detailed body with a link back to this thread so that we can get one set up.
Thank you
Thank you
Good morning ssax,
That is correct all my services are in the static directory, and yes other ping services are working, but now if I add anymore ping services they stay in the pending state until I do "force immediate check"
Please give me a name of a host that you have that it's failing for, I could've been looking at a working one.
hey ssax,
This one wasn't working ma100dlvapl823 i have to "force immediate check"
