Need some help with an Snmp Entry.
skyerjoe
Re: Need some help with an Snmp Entry.
Post by skyerjoe »
Hello tgriep
Yes the basic snmptt definition will triggered the submit checkresult correctly .. so no problem with the basic trap definition
Btw. I have to restart snmpd also
But the ent value definition is the problem.
Here is the output from trapd in syslog with the trap with the additional value :
 2016-04-08 11:39:53 UDP: [xxx.16.9.138]:53831->[xxx.16.9.61]:162 [UDP: [xxx.16.9.138]:53831->[xxx.16.9.61]:162]:#012.1.3.6.1.2.1.1.3.0 = Timeticks: (0) 0:00:00.00#011.1.3.6.1.6.3.1.1.4.1.0 = OID: .1.3.6.1.4.1.31440.0.6#011.1.3.6.1.4.1.31440.2.2.1.1.5 = STRING: "2"
And the trap is no more showing in the snmptt unknown log i guess due to the main oid matching
best regards
Nagios Core 3.5.1
Checkmk 1.2.4p5
If the MATCH didn't match the data received exactly as it is specified, it will show up in the unknown log file.
Try editing the MATCH for that OID like below and see if it works for you.
MATCH $1:.1.3.6.1.4.1.31440.2.2.1.1.5:2
or
MATCH $1:.1.3.6.1.4.1.31440.2.2.1.1.5=2
skyerjoe
Post by skyerjoe »
Hey Guys again
So i tried to find out the right Value but it won't be fit at all
I tried some several definitions:
MATCH $+1:.1.3.6.1.4.1.31440.2.2.1.1.5=1
MATCH $1:.1.3.6.1.4.1.31440.2.2.1.1.5=1
MATCH $1:.1.3.6.1.4.1.31440.2.2.1.1.5:1
MATCH $+1:.1.3.6.1.4.1.31440.2.2.1.1.5:1
I'm not really sure i this the right way for the adiitional value definition
See my defintions before and these ones are worked a long time till i had update to our ubuntu server.
Furthermore these are the Ent Values which comes from the ow-server to the smptt unkonwn log if i trigger our water altert components manually:
Ent Value 0: .1.3.6.1.4.1.31440.2.2.1.1.4=2 water sensor 1
Ent Value 0: .1.3.6.1.4.1.31440.2.2.1.1.4=1 water sensor 1
Ent Value 0: .1.3.6.1.4.1.31440.2.2.1.1.5=2 water sensor 2
Ent Value 0: .1.3.6.1.4.1.31440.2.2.1.1.5=1water sensor 2
regards john
Nagios Core 3.5.1
Checkmk 1.2.4p5
Post by Box293 »
Try:
MATCH $1: 2
skyerjoe
Post by skyerjoe »
Try:
MATCH $1: 2
Hello Box293
thanks for helping
This one seems to work a litte bit bettter some triggered snmp traps will be processed.
But this match is not exactly enough.
The OID .1.3.6.1.4.1.31440.2.2.1.1.4 with the Value '2'
will be processed also
any more suggestions so far ?
regards john
Nagios Core 3.5.1
Checkmk 1.2.4p5
ssax
Dreams In Code
Post by ssax »
Try this:
MATCH $+1:(31440.2.2.1.1.5:2)
Or this:
MATCH $+1:(.1.3.6.1.4.1.31440.2.2.1.1.5:2)
skyerjoe
Post by skyerjoe »
Hello Again
Again thanks for help
I Tired several traps Matches with these Defintion ( incl. all commented out matches which are listed below )
EVENT wateralertOWSERVER .1.3.6.1.4.1.31440.0.6 "Status Events" Testing
FORMAT Water Status $+1
EXEC /usr/local/nagios/libexec/submit_check_result ow-server  "Water Alert level 2" 2 "Water status is critical"
#MATCH $+1:.1.3.6.1.4.1.31440.2.2.1.1.5:2
#MATCH $+1:(31440.2.2.1.1.5:2)
# works :MATCH $1: 2
SDESC
ow-server alert
EDESC
The only one which works is the
MATCH $1: 2
Variable but these one is as i mentioned already too common and too much matches fits for the matching condition .
regards john
Nagios Core 3.5.1
Checkmk 1.2.4p5
ssax
Dreams In Code
Post by ssax »
Looks like this is what works:
MATCH $+1:(enterprises.31440.2.2.1.1.5:2)
It's translating the OID.
skyerjoe
Post by skyerjoe »
Hello ssax
Unfortunately these Match leads also to an unknown trap
im not really sure . may i have to translate some oids or sth like that to reach the finish line
regards john
Nagios Core 3.5.1
Checkmk 1.2.4p5
ssax
Dreams In Code
Post by ssax »
Hmm, it works perfectly on mine.. please zip up and attach your /usr/share/snmp/mibs directory so I can lab this up.
Thank you
