Network Switch/Router Wizard Port Speeds
brdr
Re: Network Switch/Router Wizard Port Speeds
Post by brdr »
it is same for me
ssax
Dreams In Code
Post by ssax »
I do not have any 10G to test, please try this on a test system.
*** Note: This will get reverted if you upgrade and will need to be reimplemented.
*** Make sure that you have known-good backups/vm snapshots before making any modifications
Replace the file below with the one I've attached:
/usr/bin/cfgmaker
cfgmaker.zip
Then setup a NEW (or you can delete your /etc/mrtg/conf.d/DEVICE.cfg files) device and see if the config files list it properly.
CarlWedu
Post by CarlWedu »
still 4.29 gbps on the Cisco 2960X
CarlWedu
Post by CarlWedu »
so i didnt make a backup of cfgmaker and then thought i could restore via replacing the network switch/router wizard, so i deleted that and downloaded from the web and re-installed. got version 2.1.8. it didnt update cfgmaker, but i ran my 2960X again and it works: 10gbps on the ints and 20gbps on the port-channels. sometimes even a blind squirrel finds an acorn.
not sure if its just the old wizard version or the combination of the old wizard and the new cfgmaker that is doing the trick here, but figure its pretty useful info for you guys...
bwallace
Post by bwallace »
Glad to hear its working now and thanks for the additional info - its helpful having those details available as evidenced by the brdr's forum post about this issue.
Were there any other questions here, or are we good to close this thread?
CarlWedu
Post by CarlWedu »
good to close. thank you!!
bwallace
Post by bwallace »
Thanks! Closing this one out now...
