Nagios Command
raamardhani7
Re: Nagios Command
Post by raamardhani7 »
Thanks again, eloyd
have a nice weekend *^.^*
Re: Nagios Command
Are we good to mark this thread as resolved?
raamardhani7
Re: Nagios Command
We will test and let you know.
Re: Nagios Command
Sounds good, let us know if you need any further assistance.
raamardhani7
Re: Nagios Command
I have installed NRDP on the Nagios XI server. However, I'd like to send some command to the NRDP server and receive below results from remote server.
OK, mccdev, MCCD13X, ONLINE INCREMENTAL completed on 04/13/16 at 20.15.30 in 00.15.08 h.m.s.
OK, mccqa, MCCQ13X, ONLINE INCREMENTAL completed on 04/13/16 at 20.17.56 in 00.01.07 h.m.s.
OK, mccref, MCCR13X, ONLINE INCREMENTAL completed on 04/13/16 at 20.20.47 in 00.01.34 h.m.s.
OK, mcctrain, MCCT13X, ONLINE INCREMENTAL completed on 04/13/16 at 20.23.28 in 00.01.06 h.m.s.
OK, plmdev, PLMD14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.27.59 in 00.02.52 h.m.s.
OK, plmqa, PLMQ14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.32.30 in 00.03.06 h.m.s.
OK, plmref, PLMR14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.35.26 in 00.01.22 h.m.s.
OK, plmsand, PLMS14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.42.07 in 00.05.10 h.m.s.
OK, plmstag, STG14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.47.34 in 00.04.06 h.m.s.
OK, plmtrain, PLMT14X, ONLINE INCREMENTAL completed on 04/13/16 at 21.02.04 in 00.12.39 h.m.s.
Here are my questions:
1. Do we need to install nrdp.php on the each remote servers?
2. How would i receive above results from the each remote server with commands? I mean what is the syntax for this?
3. Once I typed the below command, I did not receive any result:
/usr/bin/php /usr/local/nrdp/clients/send_nrdp.php --url=http://10.10.83.90/nrdp --token=asd7fjk3l34 --host==172.28.45.13 --service=ping --state=0 --output="The service looks okay"
note: 10.10.83.90: NRPD server
172.28.45.13: remote server
bwallace
Re: Nagios Command
Post by bwallace »
Yes. See bottom of page 3, here https://assets.nagios.com/downloads/nrd ... 1456514247
As tmcdonald mentioned, "The way around this is to run this as a passive check on a cron, and write directly to the nagios.cmd file to generate an alert for each match" he posted links with examples. Can you post what you have thus far?
To clarify , did you install the NDRP client on 172.28.45.13? I ask because of question #1 -- thanks -
raamardhani7
Re: Nagios Command
OK. I will install on the remote server. However, I'd like to clarify one thing.
If I'd like to generate alert for each line of below file using NRDP. Would there be any problem?
raamardhani7
Re: Nagios Command
I have installed NRDP on the Nagios XI (10.10.83.90) and remote (172.28.45.13) servers. However, once I typed the below command, I did not receive any result:
Re: Nagios Command
Was that a typo? I don't know if double-equals will matter but just to make sure, can you confirm whether you had a single or double?
Update: To address your previous question, you can certainly do this using the method I described before, otherwise you will need to either send each line to a different service, or set up a single service as a volatile service:
https://assets.nagios.com/downloads/nag ... vices.html
That, or use Nagios Logserver for this sort of thing, which is much better suited for parsing log entries.
Re: Nagios Command
Is this a typo? It should be:
/usr/bin/php /usr/local/nrdp/clients/send_nrdp.php --url=http://10.10.83.90/nrdp --token=asd7fjk3l34 --host=172.28.45.13 --service=ping --state=0 --output="The service looks okay"
Also, can you verify this is a valid token? To check, run the following command from the CLI on 10.10.83.90:
grep authorized_tokens /usr/local/nrdp/server/config.inc.php
