Nagios Command
raamardhani7
Nagios Command
I have a file as shown below:
OK, mccdev, MCCD13X, ONLINE INCREMENTAL completed on 04/13/16 at 20.15.30 in 00.15.08 h.m.s.
OK, mccqa, MCCQ13X, ONLINE INCREMENTAL completed on 04/13/16 at 20.17.56 in 00.01.07 h.m.s.
OK, mccref, MCCR13X, ONLINE INCREMENTAL completed on 04/13/16 at 20.20.47 in 00.01.34 h.m.s.
OK, mcctrain, MCCT13X, ONLINE INCREMENTAL completed on 04/13/16 at 20.23.28 in 00.01.06 h.m.s.
OK, plmdev, PLMD14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.27.59 in 00.02.52 h.m.s.
OK, plmqa, PLMQ14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.32.30 in 00.03.06 h.m.s.
OK, plmref, PLMR14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.35.26 in 00.01.22 h.m.s.
OK, plmsand, PLMS14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.42.07 in 00.05.10 h.m.s.
OK, plmstag, STG14X, ONLINE INCREMENTAL completed on 04/13/16 at 20.47.34 in 00.04.06 h.m.s.
OK, plmtrain, PLMT14X, ONLINE INCREMENTAL completed on 04/13/16 at 21.02.04 in 00.12.39 h.m.s.
And, I'd like to generate Nagios alert for each above single line in my script.
Pls advise what command should be added into my script to generate alert for each line in a file.
Here is the command that I'm using on the command prompt:
/usr/local/nagios/libexec/check_nrpe -H $DB_HOSTNAME -t 30 -c check_backup.sh -a '$DB_NAME' -n
Best Regards
Best Regards
raamardhani7
Re: Nagios Command
Here is the script:
Here is the output for the above script:
And, below script is sub script, which calls from above script. However, I really don't think that I need this.
#!/usr/bin/bash
# Title: DB2 Database backup Check
# Author: Chris Park
# Date: Apr. 13rd, 2016
# Example usage: ./check_Db2_backup.sh
# This script checks the Db2 database bavkup status.
# 1. Retrieves CRITICAL alarm when below status occurs:
# * Backup instance is down
# * Backup failed due to TSM-50 found
# * Backup failed due to TMS4ACS mount failed
# * Backup terminated
# 2. Retrieves WARNING alarm when below status occurs:
# * Query failed
# * Verify failed
# * Verify failed due to DSM_Server was not set in the DSMI_Config
# 3. Retrieves OK alarm when below status occurs:
# * Full/Incremental backup completed
# Nagios return codes
FLAG=1
STATE_OK=0
STATE_WARNING=1
STATE_CRITICAL=2
STATE_UNKNOWN=3
PROGNAME=$(basename $0)
# Nagios backup condition
CRITICAL_1="Instance is DOWN"
CRITICAL_2="Backup failed"
CRITICAL_3="backup terminated"
WARNING_1="Query Failed"
WARNING_2="Verify Failed"
SVR_NAME=`hostname`
TMP_OUTPUT="/tmp/db2_backup_check.txt"
OUTPUTFILE="/tmp/db2_backup_check.$SVR_NAME"
NUM="/tmp/db2_backup_check.temp"
if [ -f $OUTPUTFILE ]
then
rm -f $OUTPUTFILE
fi
DATE_PRT=`TZ=EST+24 date +%b.%d.%Y`
YESTERDAY=`TZ=EST+24 date +%Y%m%d`
WORKDIR="/tmp/db2backup/backup/${YESTERDAY}*"
NODIR=`find $WORKDIR -type d | wc -l`
if [ $NODIR -gt 1 ]
then
CONDITION=`find $WORKDIR -type d`
for i in "$CONDITION"
do
if [ -d "$i" ];
then
continue
fi
done
echo "$i" > $NUM
LINE1=$(cat $NUM | awk -F/ '{print $NF}'|head -n 1)
LINE2=$(cat $NUM | awk -F/ '{print $NF}'|sed -n 2p)
if [ $LINE1 -gt $LINE2 ]
then
WORKDIR="/tmp/db2backup/backup/${LINE1}"
FLAG=0
fi
if [ $FLAG -eq 1 ]
then
WORKDIR="/tmp/db2backup/backup/${LINE2}"
fi
fi
if [ ! -d $WORKDIR ]
then
TEMP_STATUS="CRITICAL"
RETURN_STATUS=$STATE_CRITICAL
echo "$TEMP_STATUS, $SVR_NAME, backup did NOT run last night on $DATE_PRT. Need to check..." > $OUTPUTFILE
cat $OUTPUTFILE
exit
fi
ls $WORKDIR/backup_results.txt > /dev/null 2>&1
if [[ $? -ne 0 ]]
then
echo "$TEMP_STATUS, $SVR_NAME, it looks terminated during the backup process... log file does NOT exist on `date +'%B %m. %Y'`." >> $OUTPUTFILE
cat $OUTPUTFILE
exit
fi
egrep -e "^SUCCESS" $WORKDIR/backup_results.txt > $TMP_OUTPUT
egrep -e "$CRITICAL_1|$CRITICAL_2|$CRITICAL_3" $WORKDIR/backup_results.txt | sed -e 's/FAILURE :/CRITICAL :/g' -e 's/RC=[0-9]//g' -e 's/"//g'>> $TMP_OUTPUT
egrep -e "$WARNING_1|$WARNING_2" $WORKDIR/backup_results.txt | sed -e 's/FAILURE :/WARNING :/g' -e 's/Exit Code [0-9]//g' >> $TMP_OUTPUT
cat "$TMP_OUTPUT" | while read -r line
do
STATUS=`echo $line | awk '{print $1}'`
DB_INSTANCE=`echo $line | awk -F: '{print $2}' | sed -e 's/^.//' -e 's/.$//'`
DB_HOSTNAME=`echo $line | awk -F: '{print $3}' | sed -e 's/^.//' -e 's/.$//'`
DB_NAME=`echo $line | awk -F: '{print $4}' | sed -e 's/^.//' -e 's/.$//'`
DESCRIPTION=`echo $line | awk -F: '{print $NF}' | sed 's/^.//'`
case "$STATUS" in
"SUCCESS")
TEMP_STATUS="OK"
RETURN_STATUS=$STATE_OK
echo "$TEMP_STATUS, ${DB_INSTANCE}, ${DB_NAME}, $DESCRIPTION" >> $OUTPUTFILE
############ Do I really need another script? ###############################
/usr/local/nagios/libexec/check_nrpe -H $DB_HOSTNAME -t 30 -c check_Db2_backup_instance.sh -n
"CRITICAL")
VALUE=$(echo $DESCRIPTION|grep -c "Instance is DOWN")
if [ $VALUE -eq 1 ]
then
fi
VALUE=$(echo $DESCRIPTION|grep -c "Backup failed")
if [ $VALUE -eq 1 ]
then
fi
VALUE=$(echo $DESCRIPTION|grep -c "backup terminated")
if [ $VALUE -eq 1 ]
then
fi
"WARNING")
TEMP_STATUS="WARNING"
RETURN_STATUS=$STATE_WARNING
VALUE=$(echo $DESCRIPTION|grep -c "Query Failed")
if [ $VALUE -eq 1 ]
then
fi
VALUE=$(echo $DESCRIPTION|grep -c "Verify Failed")
if [ $VALUE -eq 1 ]
then
fi
TEMP_STATUS="UNKNOWN"
RETURN_STATUS=$STATE_UNKNOWN
echo "$TEMP_STATUS, No status found" >> $OUTPUTFILE
esac
done
cat $OUTPUTFILE
if [ -f $TMP_OUTPUT ]
then
rm -f $TMP_OUTPUT; rm -f $NUM
fi
#echo $FINAL_STATUS
#exit $RETURN_STATUSCode: Select all
OK, plmtrain, PLMT14X, ONLINE INCREMENTAL completed on 04/13/16 at 21.02.04 in 00.12.39 h.m.s.And, below script is sub script, which calls from above script. However, I really don't think that I need this.
#!/usr/bin/bash
# Example usage: ./check_Db2_backup_instance.sh
STATE_OK=0
STATE_WARNING=1
STATE_CRITICAL=2
STATE_UNKNOWN=3
SVR_NAME=`hostname`
cat "$OUTPUTFILE" | while read -r line
do
FINAL_STATUS=`echo $line|awk -F, '{print $1}'`
FINAL_INSTANCE=`echo $line |awk -F, '{print $2}'`
FINAL_DB=`echo $line|awk -F, '{print $3}'`
FINAL_DESC=`echo $line|awk -F, '{print $NF}'`
case "$FINAL_STATUS" in
"OK")
echo "$FINAL_STATUS, ${FINAL_INSTANCE}, ${FINAL_DB}, $FINAL_DESC"
"CRITICAL")
"WARNING")
"UNKNOWN")
esac
done
Reason: Please use [code][/code] tags around long output
Re: Nagios Command
It won't work that way. The plugin you are writing is going to be run against that file, and Core/XI will look at the results and determine if an alert needs to be sent. The way around this is to run this as a passive check on a cron, and write directly to the nagios.cmd file to generate an alert for each match:
http://old.nagios.org/developerinfo/ext ... ndlist.php
probably with SEND_CUSTOM_SVC_NOTIFICATION:
http://old.nagios.org/developerinfo/ext ... and_id=135
But this is somewhat circumventing the normal check logic.
Re: Nagios Command
Also, the assumption is that this is on your local Nagios server, which I believe is the case. If you need to do this on a remote box, you also need to use some tool (NRDP would be my preferred method) of sending the results back to your Nagios server.
Re: Nagios Command
raamardhani7, take a look through the docs that tmcdonald posted and let us know if you have any questions.
Thank you
Thank you
raamardhani7
Re: Nagios Command
Thank you for the prompt response, everyone.
Current data is sitting on the remote server, So, can I also run SEND_CUSTOM_SVC_NOTIFICATION command from the remote server?
Best Regards.
Best Regards.
Re: Nagios Command
As I said,
raamardhani7
Re: Nagios Command
Thanks, eloyd
Best Regards
Best Regards
Re: Nagios Command
NRDP is nice because it's built in to XI and if you read the documentation, you'll find how to use a really easy PHP script that lets you send results back to Nagios XI from a remote server.
