Email Alerts Coming even if a service is live ?
Re: Email Alerts Coming even if a service is live ?
1. Yes, we don't need them all. Just trying to understand if they're on a different subnet or what not.
2. So do they time out eventually, or does it just 'not work'? Can you show us the mixed ping results so that we have something to look at?
3. ICMP flooding is usually at a switch / router level, you would have to look if something stops probing or what not. Based on what you've said this far, and if nothing is technically going down -- it sounds like your being ICMP limited.
soamz
Post by soamz »
10.10.11.4 , 10.10.11.15 , 10.10.10.21, 7.7.7.30, 10.10.10.23 and so many.
It comes and goes. I can send the screenshots, once I reach office.
Is there a way to find the culprit ?
The screen shots will help. There really isn't, it could be a network loop somewhere, or perhaps the ICMP flood prevention.
soamz
Post by soamz »
rkennedy wrote:The screen shots will help. There really isn't, it could be a network loop somewhere, or perhaps the ICMP flood prevention.
screenshots,check.
hsmith
Agent Smith
Post by hsmith »
Is it always the same device(s) causing these problems?
Former Nagios Employee.
me.
Post by Box293 »
Are those ping checks from the Nagios host?
You might want to run continual pings and output the data to a log file so you can catch anomalies.
soamz
Post by soamz »
hsmith wrote:Is it always the same device(s) causing these problems?
Yes. specific 10-20 devices only.
If I change their subnet and refresh device, then ping works again, then again goes dead.
Then again I fresh change, again it works.
So, its kind of very very weird.
soamz
Post by soamz »
Box293 wrote:Are those ping checks from the Nagios host?
Ping works fine in switch and PC.
Ping never gets cut to those devices.
but from server, it gets cuts.
Take a look at any firewall (on the clients) or switch logs to see if you can find something. It sounds like it's being blocked at that layer.
soamz
Post by soamz »
rkennedy wrote:Take a look at any firewall (on the clients) or switch logs to see if you can find something. It sounds like it's being blocked at that layer.
The ping would not work at the 1st place, if thats the case.
Its like a ghost, it works now, stops next moment,then again work and then again stops. :(
