No handler for command: check_nrpe_mem
blaha
Re: No handler for command: check_nrpe_mem
Post by blaha »
Hi, there is output from CLI. Version NSClient++ - 0.3.8.76 on Windows server.
CLI
CLI
Looks like the GUI is reporting the same thing. Can you upgrade to NSClient++ 0.4.3 and see if you're experiencing the same result? It was working without issues on my end, using 0.4.3.
blaha
Post by blaha »
Hi, I will try NSClient++ 0.4.3, but I do not know exactly install NSClient++ 0.4.3 (in picture) and configure new nsclient.ini file on windows server.
Can you help me how configure new nsclient.ini file on windows server?
Thank you.
Jan
nsclient.ini
(7.21 KiB) Downloaded 427 times
NSC.ini
(11.94 KiB) Downloaded 441 times
Your nsclient.ini file looks fine, are you experiencing issues since upgrading? What are they?
Post by Box293 »
blaha wrote:Hi, I will try NSClient++ 0.4.3, but I do not know exactly install NSClient++ 0.4.3 (in picture) and configure new nsclient.ini file on windows server.
https://support.nagios.com/kb/article.php?id=118
blaha
Post by blaha »
Thanks, it work. Jan
Post by mcapra »
Is it alright if we lock this thread and mark the issue as resolved?
blaha
Post by blaha »
yes, it works! thank you.
