check_nrpe with check_cpu_stats always returns OK on Linux
eloyd
Cool Title Here
Re: check_nrpe with check_cpu_stats always returns OK on Lin
Post by eloyd »
Is there a reason why check_load won't do what you want?
# ./check_load -h
check_load v1991 (nagios-plugins 1.4.13)
Copyright (c) 1999 Felipe Gustavo de Almeida <[email protected]>
Copyright (c) 1999-2007 Nagios Plugin Development Team
        <[email protected]>
This plugin tests the current system load average.
Usage:check_load [-r] -w WLOAD1,WLOAD5,WLOAD15 -c CLOAD1,CLOAD5,CLOAD15
Options:
 -h, --help
    Print detailed help screen
 -V, --version
    Print version information
 -w, --warning=WLOAD1,WLOAD5,WLOAD15
    Exit with WARNING status if load average exceeds WLOADn
 -c, --critical=CLOAD1,CLOAD5,CLOAD15
    Exit with CRITICAL status if load average exceed CLOADn
    the load average format is the same used by "uptime" and "w"
 -r, --percpu
    Divide the load averages by the number of CPUs (when possible)
Send email to [email protected] if you have questions
regarding use of this software. To submit patches or suggest improvements,
send email to [email protected]
Thanks for the suggestion eloyd.
srikgali, that plugin should be installed on your system so there isn't anything else that needs to be installed. Take a look at it and see if this plugin would work for you.
