check_nrpe with check_cpu_stats always returns OK on Linux
srikgali
Post by srikgali »
I see this issue in Nagios Xi , i am getting always OK for even high CPU utilization.
Re: check_nrpe with check_cpu_stats always returns OK on Lin
Can you show us the actual command run from the command line along with the output of it? Set the "warning" threshold lower than the "iowait" value to see if the status will change.
srikgali
Post by srikgali »
Thanks for your response.
COMMAND: /usr/local/nagios/libexec/check_nrpe -H <hostname of remote> -t 30 -c check_cpu_stats -a "-c 2 -w 1"
OUTPUT: CPU STATISTICS OK : user=1.75% system=0.75% iowait=0.00% idle=97.49% nice=0.00% steal=0.00% | CpuUser=1.75;CpuSystem=0.75;CpuIoWait=0.00;CpuIdle=97.49;CpuNice=0.00;CpuSteal=0.00;75;80
My intention is get CPU alerts if Linux server Total CPU Utilization ( w - 85% and C-90%) not just the IOWAIT%.
so if %idle is less than 15% then it should alert out Warning message and if %idle is less than 10% then it should alert critical message.
In this case, you will need to use a different plugin as the "check_cpu_stats.sh" one is only reporting on iowait.
[root@192 libexec]# /usr/local/nagios/libexec/check_cpu_stats.sh -h
check_cpu_stats.sh Revision 1.2 - CPU Utilization check script for Nagios
Usage: check_cpu_utilization.sh -w <warning value in % for iowait>
-w Warning level for cpu iowait
-h Show this page
Usage: check_cpu_stats.sh
Usage: check_cpu_stats.sh --help
Usage: check_cpu_stats.sh -w <warning>
Revision 1.2 (c) 2007 Steve Bosek ([email protected])
This plugin will check cpu utilization (user,system,iowait,idle in %)
-w is for reporting warning levels in percent of iowait
I found the "check_linux" stats" plugin on the Nagios Exchange.
https://exchange.nagios.org/directory/P ... ts/details
I haven't tested it but it seems like it is what you are looking for. Give it a try and let us know if this resolved your problem.
srikgali
Post by srikgali »
OH Really, Thanks .
I ran this script on the server side and got below error.
# sh check_CPU_Linux.pl
check_CPU_Linux.pl: line 31: use: command not found
check_CPU_Linux.pl: line 32: use: command not found
check_CPU_Linux.pl: line 33: syntax error near unexpected token `('
check_CPU_Linux.pl: line 33: `use utils qw($TIMEOUT %ERRORS &print_revision &support);'
This is a perl script. Don't use "sh" to run it. Can you view the plugin's usage by running the following command?
/path/to/your/plugin/check_CPU_Linux.pl -h
srikgali
Post by srikgali »
I got below output
# ./check_CPU_Linux.pl -h
Can't locate Sys/Statistics/Linux.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./check_CPU_Linux.pl line 35.
BEGIN failed--compilation aborted at ./check_CPU_Linux.pl line 35.
ssax
Dreams In Code
Post by ssax »
What distro/version is this? If RHEL/CENT, please run this command on the remote machine:
rpm -qa | grep perl-Sys-Statistics-Linux
If nothing is returned, run this on the remote machine, and try it again:
yum install perl-Sys-Statistics-Linux
What is the output of this command:
find / -name Linux.pm
srikgali
Post by srikgali »
These are production servers, cant install required rpms. if possible can you suggest any other cpu monitoring plugins?
You may want to search the exchange site for a plugin that you do not have to install any modules, etc on your server.
Most plugins require something to be installed.
