Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Thu Aug 18, 2016 7:43 pm
chr1s wrote: when i try to access the Website and switch to "hosts" or "Services" i receive : You don't have permission to access /nagios/cgi-bin/status.cgi on this server.
I suspect you need to execute these commands:
sudo a2enmod rewrite
sudo a2enmod cgi
systemctl restart apache2.service
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
chr1s
Posts: 9 Joined: Fri Aug 12, 2016 2:35 am
Post
by chr1s » Fri Aug 19, 2016 2:18 am
yes i'm using the nagiosadmin
a2enmod rewrite and a2enmod cgi already enabled
cgi.cfg
(12.04 KiB) Downloaded 157 times
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Fri Aug 19, 2016 12:25 pm
Please remove these lines -
authorized_for_all_host=nagios
authorized_for_all_services=nagios
Then, above them, change these from -
authorized_for_all_services=nagiosadmin
authorized_for_all_hosts=nagiosadmin
to -
authorized_for_all_services=nagiosadmin,nagios
authorized_for_all_hosts=nagiosadmin,nagios
Now run
service nagios restart - is it working at this point?
chr1s
Post
by chr1s » Mon Aug 22, 2016 1:21 am
no, unfortunately the same error message.
Apache2 log file says : nagios client denied by server configuration /usr/local/nagios/sbinstatus.cgi
chr1s
Post
by chr1s » Mon Aug 22, 2016 6:01 am
found the solution:
i made this commands again and instead of nagios, i used my nagiosadmin user
sudo useradd nagios
sudo groupadd nagcmd
sudo usermod -a -G nagcmd nagios
Posts: 9117 Joined: Mon Sep 23, 2013 8:40 am
Post
by tmcdonald » Mon Aug 22, 2016 9:49 am
Glad to hear it! Are we all good to close this up then?
chr1s
Post
by chr1s » Thu Sep 01, 2016 9:25 am
yes thank you
