Check NRPE for Services
kwhogster
Re: Check NRPE for Services
Post by kwhogster »
Posted this on the site
https://forums.nsclient.org/t/nsclient- ... -type/4243
3 days no response
I don't know what it the "average" response time on the NSClient++ support forum, so I am not sure if 3 days with no response is "normal". Unfortunately, this is out of our control. Have you verified that your issue occurs when there is too much output from your check? Have you tried borgified's solution (piping the STDOUT to a file, then retrieving the file later)?
kwhogster
Post by kwhogster »
Still no help from that site
kwhogster
Post by kwhogster »
this is what you are talking about?
borgified commented on May 19 2015
I encountered this issue in version 0.4.3.143 however i was able to get around the issue by piping the STDOUT to a file then retrieving that file later. I verified that the problem occurs when there is too much output by varying the amount of data that would get sent to STDOUT until the problem showed up. I am using legacy mode.
If so where do I do this? what file do I modify? nsclient.ini ??
Take a look at http://tldp.org/HOWTO/Bash-Prog-Intro-HOWTO-3.html
3.2 Sample: stdout 2 file
This will cause the ouput of a program to be written to a file.
ls -l > ls-l.txt
I believe borgified was mentioning having your check command pipe the full results to a file. For this, you would just add > /tmp/yourlog.txt to the end of the command definition.
kwhogster
Post by kwhogster »
To you mean on this???????
command_name check_nrpe
command_line /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ $ARG2$ $ARG3$ $ARG4$ > /tmp/yourlog.txt
If I do that wit would effect all others using this command
I think I should do this
command_name check_nrpe_test
Then the service would be
host_name TGCS002
service_description Check All Service
check_command check_nrpe_test!check_service! -a CheckAll "filter=name not like 'clr_optimization_v4.0.30319'" exclude=SysmonLog
servicegroups AllServices
check_interval 1
Am I on the right track???
kwhogster
Post by kwhogster »
I made the changes per my last post
now Nagios reports
Check All Service UNKNOWN 08-27-2016 08:47:55 0d 0h 0m 51s 1/3 (No output on stdout) stderr:
The yourlog,txt file was created this is the contents
root@tgcs017:/usr/local/nagios/etc/objects# cat /tmp/yourlog.txt
CHECK_NRPE: Invalid packet type received from server.
If I run this from the Nagios server command line
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/check_nrpe -H 10.2.8.12 -t 30 -c check_service -a CheckAll CHECK_NRPE: Invalid packet type received from server.
All gives same error Invalid Packet type received.
First thing to try is to upgrade to the latest 4.4.x version of the NSClient++ program on your windows server and see if that helps.
Also, could you post your nsclient.ini file from that server and also any errors from the nsclient.log file?
kwhogster
Post by kwhogster »
I will try the nsclient later
here is the nsclient.ini
# If you want to fill this file with all avalible options run the following command:
#   nscp settings --generate --add-defaults --load-all
#   nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; PASSWORD - Password used to authenticate against server
password = harley95
; TIMEOUT - Timeout when reading packets on incoming sockets. If the data has not arrived within this time we will bail out.
timeout = 30
; CACHE ALLOWED HOSTS - If host names (DNS entries) should be cached, improves speed and security somewhat but won't allow you to have dynamic IPs for your Nagios server.
cache allowed hosts = true
; BIND TO ADDRESS - Allows you to bind server to a specific local address. This has to be a dotted ip address not a host name. Leaving this blank will bind to all available IP addresses.
bind to =
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = 10.2.8.79
[/settings/NRPE/server]
; EXTENDED RESPONSE - Send more then 1 return packet to allow response to go beyond payload size (requires modified client if legacy is true this defaults to false).
extended response = true
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket.  default-workarounds	Various workarounds for what I understand to be broken ssl implementations no-sslv2	Do not use the SSLv2 protocol. no-sslv3	Do not use the SSLv3 protocol. no-tlsv1	Do not use the TLSv1 protocol. single-dh-use	Always create a new key when using temporary/ephemeral DH parameters. This option must be used to prevent small subgroup attacks, when the DH parameters were not generated using "strong" primes (e.g. when using DSA-parameters).
;ssl options = no-sslv2,no-sslv3
ssl options =
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = true
; ALLOW INSECURE CHIPHERS and ENCRYPTION - Only enable this if you are using legacy check_nrpe client.
insecure = true
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket.  none	The server will not send a client certificate request to the client, so the client will not send a certificate. peer	The server sends a client certificate request to the client and the certificate returned (if any) is checked. fail-if-no-cert	if the client did not return a certificate, the TLS/SSL handshake is immediately terminated. This flag must be used together with peer. peer-cert	Alias for peer and fail-if-no-cert. workarounds	Various bug workarounds. single	Always create a new key when using tmp_dh parameters. client-once	Only request a client certificate on the initial TLS/SSL handshake. This flag must be used together with verify-peer
; verify mode = peer-cert
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = true
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
; use ssl = true
; PORT NUMBER - Port to use for NRPE.
port = 5666
[/modules]
; CheckExternalScripts - Execute external scripts
CheckExternalScripts = 1
; CheckHelpers - Various helper function to extend other checks.
CheckHelpers = 1
; NSClientServer - A server that listens for incoming check_nt connection and processes incoming requests.
NSClientServer = 1
; NRPEServer - A server that listens for incoming NRPE connection and processes incoming requests.
NRPEServer = enabled
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; CheckNSCP - Use this module to check the healt and status of NSClient++ it self
CheckNSCP = 1
; CheckDisk - CheckDisk can check various file and disk related things.
CheckDisk = 1
; CheckEventLog - Check for errors and warnings in the event log.
CheckEventLog = 1
; NSCAClient - NSCA client can be used both from command line and from queries to submit passive checks via NSCA
NSCAClient = 1
; A list of templates for wrapped scripts.
[/settings/external scripts/wrappings]
; WRAPPING - An external script wrapping
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
An alias is an internal command that has been predefined to provide a single command without arguments. Be careful so you don't create loops (ie check_loop = check_a, check_a=check_loop)
bat = scripts\\%SCRIPT% %ARGS%
[/settings/external scripts/alias]
; ALIAS - Query alias
alias_volumes_loose = check_drivesize
alias_up = check_uptime
default =
alias_cpu = check_cpu
alias_service = check_service
alias_process_hung = check_process "filter=is_hung" "crit=count>0"
alias_sched_long = check_tasksched "filter=status = 'running'" "detail-syntax=${title} (${most_recent_run_time})" "crit=most_recent_run_time < -$ARG1$"
alias_process_count = check_process "process=$ARG1$" "warn=count > $ARG2$" "crit=count > $ARG3$"
alias_process = check_process "process=$ARG1$" "crit=state != 'started'"
alias_process_stopped = check_process "process=$ARG1$" "crit=state != 'stopped'"
alias_sched_task = check_tasksched show-all "filter=title eq '$ARG1$'" "detail-syntax=${title} (${exit_code})" "crit=exit_code ne 0"
alias_file_size = check_files "path=$ARG1$" "crit=size > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${size}" max-dir-depth=10
alias_file_age = check_files "path=$ARG1$" "crit=written > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${written}" max-dir-depth=10
alias_sched_all = check_tasksched show-all "syntax=${title}: ${exit_code}" "crit=exit_code ne 0"
alias_cpu_ex = check_cpu "warn=load > $ARG1$" "crit=load > $ARG2$" time=5m time=1m time=30s
alias_event_log = check_eventlog
alias_disk_loose = check_drivesize
alias_service_ex = check_service "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
alias_disk = check_drivesize
alias_mem = check_memory
alias_volumes = check_drivesize
; A set of filters to use in real-time mode
[/settings/system/windows/real-time/checks]
; A set of options to configure the real time checks
[/settings/system/windows/real-time]
; Add counters to check
[/settings/system/windows/counters]
; A list of wrapped scripts (ie. scruts using a template mechanism). The template used will be defined by the extension of the script.
; Section for the EventLog Checker (CheckEventLog.dll).
[/settings/eventlog]
; LOOKUP NAMES - Lookup the names of eventlog files
lookup names = true
; BUFFER_SIZE - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
buffer size = 131072
; SYNTAX - Set this to use a specific syntax string for all commands (that don't specify one).
syntax =
; DEBUG - Log more information when filtering (useful to detect issues with filters) not useful in production as it is a bit of a resource hog.
debug = false
; Section for configuring the shared session.
[/settings/shared session]
; ENABLE THE SAHRED SESSION - This is currently not added in 0.4.x
enabled = false
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
; SCRIPT - For more configuration options add a dedicated section (if you add a new section you can customize the user and various other advanced features)
default =
; Section for configuring the log handling.
[/settings/log]
; DATEMASK - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
date format = %Y-%m-%d %H:%M:%S
; FILENAME - The file to write log data to. Set this to none to disable log to file.
file name = ${exe-path}/nsclient.log
; LOG LEVEL - Log level to use. Available levels are error,warning,info,debug,trace
level = info
; Section for NSClient (NSClientServer.dll) (check_nt) protocol options.
[/settings/NSClient/server]
use ssl = false
; PORT NUMBER - Port to use for check_nt.
port = 12489
; PERFORMANCE DATA - Send performance data back to Nagios (set this to 0 to remove all performance data).
performance data = true
; Target definition for: default
[/settings/NSCA/client/targets/default]
; PASSWORD - The password to use. Again has to be the same as the server or it wont work at all.
password =
; VERIFY MODE - Target definition for: default
verify mode = none
; ALLOWED CIPHERS - A better value is: ALL:!ADH:!LOW:!EXP:!MD5:@STRENGTH
allowed ciphers = ADH
; SSL CERTIFICATE - Target definition for: default
certificate =
; TARGET ADDRESS - Target host address
address =
; ENCRYPTION - Name of encryption algorithm to use. Has to be the same as your server i using or it wont work at all.This is also independent of SSL and generally used instead of SSL. Available encryption algorithms are: none = No Encryption (not safe) xor = XOR des = DES 3des = DES-EDE3 cast128 = CAST-128 xtea = XTEA blowfish = Blowfish twofish = Twofish rc2 = RC2 aes128 = AES aes192 = AES aes = AES serpent = Serpent gost = GOST
encryption = aes
; TIMEOUT - Timeout when reading/writing packets to/from sockets.
timeout = 30
use ssl = false
; Section for NSCA passive check module.
[/settings/NSCA/client]
; HOSTNAME - The host name of the monitored computer. Set this to auto (default) to use the windows name of the computer.  auto	Hostname ${host}	Hostname ${host_lc} Hostname in lowercase ${host_uc}	Hostname in uppercase ${domain}	Domainname ${domain_lc}	Domainname in lowercase ${domain_uc}	Domainname in uppercase
hostname = auto
; CHANNEL - The channel to listen to.
channel = NSCA
; Section for system checks and system settings
[/settings/system/windows]
; DEFAULT LENGTH - Used to define the default interval for range buffer checks (ie. CPU).
default buffer length = 1h
; Files to be included in the configuration
[/includes]
; Section for external scripts configuration options (CheckExternalScripts).
[/settings/external scripts]
allow nasty characters = false
; COMMAND TIMEOUT - The maximum time in seconds that a command can execute. (if more then this execution will be aborted). NOTICE this only affects external commands not internal ones.
timeout = 60
allow arguments = false
; SCRIPT DIRECTORY - Load all scripts in a directory and use them as commands. Probably dangerous but useful if you have loads of scripts :)
script path =
; Configure which services has to be in which state
[/settings/system/windows/service mapping]
; Configure log file properties.
[/settings/log/file]
; MAXIMUM FILE SIZE - When file size reaches this it will be truncated to 50% if set to 0 (default) truncation will be disabled
max size = 0
[/settings/eventlog/real-time]
; DEBUG - Log missed records (useful to detect issues with filters) not useful in production as it is a bit of a resource hog.
debug = false
; LOGS TO CHECK - Comma separated list of logs to check
log = application,system
; STARTUP AGE - The initial age to scan when starting NSClient++
startup age = 30m
; REAL TIME CHECKING - Spawns a background thread which detects issues and reports them back instantly.
enabled = false
; Section for configuring the crash handler.
[/settings/crash]
; RESTART SERVICE NAME - The url to submit crash reports to
restart target = NSCP
; CRASH ARCHIVE LOCATION - The folder to archive crash dumps in
archive folder = ${shared-path}/crash-dumps
; SUBMISSION URL - The url to submit crash reports to
submit url = https://crash.nsclient.org/post
; ARCHIVE CRASHREPORTS - Archive crash reports in the archive folder
archive = true
; SUBMIT CRASHREPORTS - Submit crash reports to nsclient.org (or your configured submission server)
submit = false
; RESTART - Submit crash reports to nsclient.org (or your configured submission server)
restart = true
[/settings/eventlog/real-time/filters]
; FILTER DEFENITION - For more configuration options add a dedicated section
default =
[/paths]
; Path for certificate-path -
certificate-path = ${shared-path}/security
; Path for base-path -
base-path = C:\Program Files\NSClient++
; Path for shared-path -
shared-path = C:\Program Files\NSClient++
; Path for exe-path -
exe-path = C:\Program Files\NSClient++
; Path for crash-folder -
crash-folder = C:\Program Files\NSClient++
; Path for module-path -
module-path = ${shared-path}/modules
Here is the nsclient log
2016-07-01 14:47:33: error:D:\source\nscp\modules\NRPEServer\NRPEServer.cpp:132: Certificate not found: C:\Program Files\NSClient++/security/certificate.pem (generating a default certificate)
2016-07-01 14:47:33: error:D:\source\nscp\modules\NRPEServer\NRPEServer.cpp:132: CA not found: C:\Program Files\NSClient++/security/ca.pem (generating a default CA)
2016-07-14 05:35:01: error:D:\source\nscp\include\socket/connection.hpp:149: Failed to send data: The file handle supplied is not valid
2016-07-28 21:59:14: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 21:59:14: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:01:14: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:01:14: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:03:14: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:03:14: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:05:06: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:05:06: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:06:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:06:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:07:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:07:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:08:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:08:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:09:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:09:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:09:03: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:09:03: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:10:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:10:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:11:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:11:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:12:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:12:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:13:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:13:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:14:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:14:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:15:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:15:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:16:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:16:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-28 22:17:00: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-28 22:17:00: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-07-29 14:55:33: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-07-29 14:55:33: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:39:49: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:39:49: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:41:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:41:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:43:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:43:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:44:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:44:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:45:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:45:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:46:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:46:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:47:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:47:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:48:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:48:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:49:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:49:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:50:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:50:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:51:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:51:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:52:48: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:52:48: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-08 19:57:29: error:D:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2016-08-08 19:57:29: error:D:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2016-08-14 21:01:19: error:D:\source\nscp\service\NSClient++.cpp:893: Unknown command(s): checks_service available commands: commands {, alias_cpu, alias_cpu_ex, alias_disk, alias_disk_loose, alias_event_log, alias_file_age, alias_file_size, alias_mem, alias_process, alias_process_count, alias_process_hung, alias_process_stopped, alias_sched_all, alias_sched_long, alias_sched_task, alias_service, alias_service_ex, alias_up, alias_volumes, alias_volumes_loose, check_always_critical, check_always_ok, check_always_warning, check_counter, check_cpu, check_critical, check_drivesize, check_eventlog, check_files, check_memory, check_multi, check_negate, check_nscp, check_ok, check_os_version, check_pagefile, check_pdh, check_process, check_service, check_timeout, check_uptime, check_version, check_warning, checkalwayscritical, checkalwaysok, checkalwayswarning, checkcounter, checkcpu, checkcritical, checkdrivesize, checkeventlog, checkfiles, checkmem, checkmultiple, checkok, checkprocstate, checkservicestate, checkuptime, checkversion, checkwarning, filter_perf, negate, nsca_submit, render_perf, timeout, xform_perf}, plugins {, 0, 1, 2, 3, 4, 5, 7}
2016-08-14 21:01:19: error:D:\source\nscp\include\nscapi\nscapi_core_wrapper.cpp:159: Failed to execute command
2016-08-14 21:01:19: error:D:\source\nscp\include\nscapi\nscapi_core_helper.cpp:95: Failed to execute command: checks_service
2016-08-14 21:02:19: error:D:\source\nscp\service\NSClient++.cpp:893: Unknown command(s): checks_service available commands: commands {, alias_cpu, alias_cpu_ex, alias_disk, alias_disk_loose, alias_event_log, alias_file_age, alias_file_size, alias_mem, alias_process, alias_process_count, alias_process_hung, alias_process_stopped, alias_sched_all, alias_sched_long, alias_sched_task, alias_service, alias_service_ex, alias_up, alias_volumes, alias_volumes_loose, check_always_critical, check_always_ok, check_always_warning, check_counter, check_cpu, check_critical, check_drivesize, check_eventlog, check_files, check_memory, check_multi, check_negate, check_nscp, check_ok, check_os_version, check_pagefile, check_pdh, check_process, check_service, check_timeout, check_uptime, check_version, check_warning, checkalwayscritical, checkalwaysok, checkalwayswarning, checkcounter, checkcpu, checkcritical, checkdrivesize, checkeventlog, checkfiles, checkmem, checkmultiple, checkok, checkprocstate, checkservicestate, checkuptime, checkversion, checkwarning, filter_perf, negate, nsca_submit, render_perf, timeout, xform_perf}, plugins {, 0, 1, 2, 3, 4, 5, 7}
2016-08-14 21:02:19: error:D:\source\nscp\include\nscapi\nscapi_core_wrapper.cpp:159: Failed to execute command
2016-08-14 21:02:19: error:D:\source\nscp\include\nscapi\nscapi_core_helper.cpp:95: Failed to execute command: checks_service
2016-08-18 11:03:35: error:D:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: An existing connection was forcibly closed by the remote host: 1862
