NRPE NSClient++ check_cpu negative values
mhixson2
Re: NRPE NSClient++ check_cpu negative values
Post by mhixson2 »
Thanks. I've added it and now we wait. I really like the 'max size' option. I didn't know that was a thing.
All perfdata values have been positive over the last few checks. I'll post up the log once it goes negative again.
Sounds good, I'll leave this open should you have a negative update for us.
mhixson2
Post by mhixson2 »
Ok, I have negative results in the graph between about 3 and 4 am this morning. Log below. I don't see anything unusual in there - do you?
2016-09-28 03:05:22: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:05:28: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:05:29: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:06:00: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:06:00: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:06:01: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:06:01: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:06:14: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:06:14: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:06:16: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:06:16: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:06:25: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:06:25: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:06:25: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:06:26: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:06:26: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:09:19: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:09:19: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:09:19: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:09:19: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:09:19: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:09:20: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:09:20: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:09:20: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:09:33: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:09:49: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:09:49: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:09:54: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:09:54: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:10:20: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:10:25: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:10:26: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:10:27: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:10:58: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:10:58: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:10:59: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:10:59: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:11:12: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:11:12: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:11:14: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:11:14: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:11:23: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:11:23: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:11:24: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:11:24: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:11:24: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:14:17: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:14:17: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:14:17: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:14:17: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:14:17: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:14:18: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:14:18: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:14:18: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:14:31: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:14:47: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:14:47: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:14:52: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:14:52: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:15:18: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:15:23: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:15:24: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:15:25: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:15:56: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:15:56: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:15:57: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:15:57: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:16:10: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:16:10: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:16:12: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:16:12: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:16:21: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:16:21: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:16:22: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:16:22: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:16:23: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:16:23: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:19:15: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:19:15: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:19:15: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:19:15: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:19:15: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:19:16: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:19:16: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:19:16: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:19:29: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:19:45: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:19:45: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:19:49: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:19:49: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:20:16: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:20:20: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:20:22: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:20:23: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:20:54: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:20:54: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:20:55: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:20:55: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:21:08: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:21:08: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:21:10: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:21:10: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:21:19: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:21:19: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:21:20: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:21:20: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:21:21: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:21:21: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:24:13: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:24:13: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:24:13: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:24:13: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:24:13: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:24:14: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:24:14: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:24:17: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:24:17: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:24:25: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:24:43: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:24:43: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:24:47: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:24:47: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:25:14: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:25:18: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:25:20: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:25:21: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:25:52: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:25:52: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:25:53: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:25:53: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:26:06: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:26:06: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:26:08: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:26:08: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:26:17: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:26:17: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:26:19: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:26:19: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:26:19: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:29:11: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:29:11: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:29:11: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:29:11: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:29:11: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:29:12: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:29:12: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:29:12: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:29:23: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:29:41: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:29:41: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:29:45: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:29:45: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:30:12: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:30:16: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:30:18: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:30:19: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:30:51: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:30:51: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:30:51: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:31:04: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:31:04: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:31:06: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:31:06: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:31:15: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:31:15: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:31:17: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:31:17: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:31:17: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:34:08: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:34:08: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:34:08: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:34:09: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:34:09: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:34:09: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:34:10: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:34:10: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:34:10: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:34:21: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:34:39: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:34:39: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:34:43: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:34:43: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:35:10: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:35:14: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:35:16: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:35:17: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:35:48: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:35:48: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:35:49: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:35:49: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:36:02: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:36:02: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:36:04: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:36:04: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:36:13: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:36:13: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:36:15: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:36:15: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:36:15: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:39:06: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:39:06: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:39:07: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:39:07: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:39:07: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:39:07: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:39:08: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:39:08: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:39:08: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:39:19: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:39:37: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:39:37: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:39:41: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:39:41: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:40:08: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:40:12: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:40:14: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:40:15: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:40:46: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:40:46: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:40:47: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:40:47: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:41:00: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:41:00: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:41:02: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:41:02: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:41:11: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:41:11: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:41:13: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:41:13: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:41:14: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:44:04: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:44:04: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:44:05: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:44:05: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:44:06: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:44:06: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:44:06: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:44:06: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:44:06: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:44:17: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:44:36: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:44:36: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:44:39: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:44:39: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:45:06: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:45:10: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:45:12: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:45:13: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:45:44: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:45:44: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:45:45: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:45:45: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:45:58: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:45:58: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:46:00: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:46:00: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:46:10: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:46:10: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:46:11: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:46:11: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:46:11: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:49:02: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:49:02: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:49:03: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:49:03: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:49:04: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:49:04: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:49:04: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:49:05: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:49:05: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:49:05: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:49:15: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:49:35: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:49:35: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:49:37: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:49:37: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:50:05: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:50:08: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:50:10: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:50:11: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:50:42: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:50:42: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:50:43: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:50:43: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:50:56: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:50:56: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:50:58: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:50:58: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:51:08: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:51:08: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:51:09: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:51:09: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:51:09: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:54:00: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:54:00: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:54:01: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:54:01: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:54:02: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:54:02: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:54:02: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:54:03: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:54:03: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:54:03: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:54:13: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:54:33: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:54:34: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:54:36: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:54:36: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 03:55:03: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:55:06: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:55:08: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:55:09: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:55:40: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:55:40: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 03:55:41: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:55:41: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 03:55:54: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:55:54: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 03:55:57: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:55:57: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
2016-09-28 03:56:06: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:56:06: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\drive_space_nonclustered.bat 85 90
2016-09-28 03:56:07: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:56:07: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl L
2016-09-28 03:56:07: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl Q
2016-09-28 03:58:58: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:58:58: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl F
2016-09-28 03:58:59: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:58:59: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl D
2016-09-28 03:59:00: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:59:00: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl C
2016-09-28 03:59:00: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl H
2016-09-28 03:59:01: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:59:01: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl E
2016-09-28 03:59:01: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl G
2016-09-28 03:59:11: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:59:31: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:59:31: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl I
2016-09-28 03:59:35: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 03:59:35: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl J
2016-09-28 04:00:01: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 04:00:05: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 04:00:06: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 04:00:07: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 04:00:38: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 04:00:38: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl K
2016-09-28 04:00:39: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 04:00:39: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl R
2016-09-28 04:00:52: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 04:00:52: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl M
2016-09-28 04:00:55: debug:c:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.220.102.42, count=1
2016-09-28 04:00:55: debug:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: scripts\custom\disk_load.bat -dl T
Post by mcapra »
Can you share the output of:
/usr/local/nagios/libexec/check_nrpe
I'd be interested to see what check_nrpe version you're using. We haven't been able to replicate this internally. Definitely looks like some sort of integer overflow.
There's also this in the NSClient++ changelogs:
2015-11-20 Michael Medin
 ! Release 0.5.0.16
 * Fixed #201 negative perf data in checks
You might try using the latest stable version of 0.5:
https://www.nsclient.org/download/
mhixson2
Post by mhixson2 »
$ /usr/local/nagios/libexec/check_nrpe
Incorrect command line arguments supplied
NRPE Plugin for Nagios
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 2.15
Last Modified: 09-06-2013
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher required
I've updated the client to NSCP-0.5.0.62-x64 and renamed the CPU.rrd and xml files to start the graph over. Fingers crossed.
Look for an update from me on Tues 10/4 when I return to the office. Thanks for the help.
Sounds good - I'll leave this open awaiting your response.
mhixson2
Post by mhixson2 »
More occurrences of negative perfdata happened over the weekend (9/30, 10/2, 10/3 - all around 3am). When I upgraded NSClient again, I overwrote the default nsclient.ini with my custom config, which did not have debug logging enabled. Below is what the log captured (without debugging) around the time of one of these negative occurrences. Debug logging is now active again.
The logs appear to be three hours behind the server (so 00:00 log time = 03:00 server time).
2016-10-03 00:01:31: error:c:\source\master\include\socket/connection.hpp:120: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
2016-10-03 00:02:06: error:c:\source\master\include\socket/connection.hpp:120: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
2016-10-03 00:06:03: error:c:\source\master\include\socket/connection.hpp:120: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
2016-10-04 00:02:41: error:c:\source\master\include\socket/connection.hpp:120: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
2016-10-04 00:03:04: error:c:\source\master\include\socket/connection.hpp:120: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
2016-10-04 00:03:18: error:c:\source\master\include\socket/connection.hpp:120: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
2016-10-04 00:07:16: error:c:\source\master\include\socket/connection.hpp:120: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
2016-10-04 00:07:16: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2016-10-04 00:07:24: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: An existing connection was forcibly closed by the remote host: 1862
What timeout is the log referring to? A global setting, or the -t value in my check command? /usr/local/nagios/libexec/check_nrpe -H HOSTNAME -u -t 30 -c check_cpu -a 'warn=0' 'crit=load ge 98%'
Are you experiencing a high load on the server due to backups or other jobs running at this time? It is possible that this is a networking issue.
Some users reported similar errors, i.e.
caused by firewall issues:
http://forums.nsclient.org/t/nsclient-0 ... ost/4065/2
Can you run the following command on the Nagios XI server, and show the output?
nmap <client ip> -p 12489,5666
mhixson2
Post by mhixson2 »
I think all our SQL jobs run earlier in the night, but that's a good idea, I'll check that with our DBAs. They're a wild and crazy bunch that might have just scheduled all jobs on this server at 3am. I'll report back.
All of our checks are NRPE.
sudo nmap [HOST IP] -p 12489,5666
Starting Nmap 5.51 ( http://nmap.org ) at 2016-10-05 14:30 EDT
Nmap scan report for [HOST FQDN] [HOST IP]
Host is up (0.00049s latency).
PORT      STATE  SERVICE
5666/tcp  open   nrpe
12489/tcp closed unknown
Nmap done: 1 IP address (1 host up) scanned in 0.10 seconds
Sounds good, mhixson2! Let us know about your findings. We will keep the thread open. Make sure you don't have any check_nt checks as port 12489 seems to be closed.
