root@raspberrypi:/home/pi/Downloads# find / -name *nrpe*
/lib/systemd/system/nrpe.service
/usr/lib/tmpfiles.d/nrpe.conf
/usr/local/nagios/nrpe-2-15
/usr/local/nagios/nrpe-2-15/include/nrpe.h
/usr/local/nagios/nrpe-2-15/nrpe.spec.in
/usr/local/nagios/nrpe-2-15/package/solaris/pkg/nrpe
/usr/local/nagios/nrpe-2-15/package/solaris/pkg/nrpe.xml
/usr/local/nagios/nrpe-2-15/contrib/nrpe_check_control.c
/usr/local/nagios/nrpe-2-15/contrib/README.nrpe_check_control
/usr/local/nagios/nrpe-2-15/src/check_nrpe
/usr/local/nagios/nrpe-2-15/src/nrpe
/usr/local/nagios/nrpe-2-15/src/check_nrpe.c
/usr/local/nagios/nrpe-2-15/src/nrpe.c
/usr/local/nagios/nrpe-2-15/sample-config/nrpe.cfg.in
/usr/local/nagios/nrpe-2-15/sample-config/nrpe.xinetd
/usr/local/nagios/nrpe-2-15/sample-config/nrpe.xinetd.in
/usr/local/nagios/bin/nrpe
/usr/local/nagios/libexec/check_nrpe
/usr/local/nagios/etc/nrpe.cfg
/var/cache/apt/archives/nagios-nrpe-server_2.15-1_armhf.deb
/var/cache/apt/archives/nagios-nrpe-plugin_2.15-1_armhf.deb
/var/lib/dpkg/info/nagios-nrpe-server.list
/var/lib/dpkg/info/nagios-nrpe-plugin.postrm
/var/lib/dpkg/info/nagios-nrpe-server.postrm
/var/lib/dpkg/info/nagios-nrpe-plugin.list
root@raspberrypi:/home/pi/Downloads# find / -name *.cfg
/home/pi/.config/lxpanel/launchtaskbar.cfg
/usr/lib/pypy-upstream/lib_pypy/cffi/_pycparser/_c_ast.cfg
/usr/lib/python2.7/dist-packages/distlib/_backport/sysconfig.cfg
/usr/lib/jvm/jdk-8-oracle-arm-vfp-hflt/jre/lib/arm/jvm.cfg
/usr/lib/python3/dist-packages/distlib/_backport/sysconfig.cfg
/usr/lib/libreoffice/share/config/soffice.cfg
/usr/share/doc/qstat/examples/contrib.cfg
/usr/share/monitoring-plugins/templates-basic/ssh.cfg
/usr/share/monitoring-plugins/templates-basic/ftp.cfg
/usr/share/monitoring-plugins/templates-basic/dhcp.cfg
/usr/share/monitoring-plugins/templates-basic/procs.cfg
/usr/share/monitoring-plugins/templates-basic/ping.cfg
/usr/share/monitoring-plugins/templates-basic/dummy.cfg
/usr/share/monitoring-plugins/templates-basic/http.cfg
/usr/share/monitoring-plugins/templates-basic/real.cfg
/usr/share/monitoring-plugins/templates-basic/load.cfg
/usr/share/monitoring-plugins/templates-basic/news.cfg
/usr/share/monitoring-plugins/templates-basic/tcp_udp.cfg
/usr/share/monitoring-plugins/templates-basic/apt.cfg
/usr/share/monitoring-plugins/templates-basic/telnet.cfg
/usr/share/monitoring-plugins/templates-basic/users.cfg
/usr/share/monitoring-plugins/templates-basic/disk.cfg
/usr/share/monitoring-plugins/templates-basic/ntp.cfg
/usr/share/monitoring-plugins/templates-basic/mail.cfg
/usr/share/monitoring-plugins/templates-standard/disk-smb.cfg
/usr/share/monitoring-plugins/templates-standard/breeze.cfg
/usr/share/monitoring-plugins/templates-standard/hppjd.cfg
/usr/share/monitoring-plugins/templates-standard/mailq.cfg
/usr/share/monitoring-plugins/templates-standard/fping.cfg
/usr/share/monitoring-plugins/templates-standard/nt.cfg
/usr/share/monitoring-plugins/templates-standard/flexlm.cfg
/usr/share/monitoring-plugins/templates-standard/ldap.cfg
/usr/share/monitoring-plugins/templates-standard/snmp.cfg
/usr/share/monitoring-plugins/templates-standard/radius.cfg
/usr/share/monitoring-plugins/templates-standard/mrtg.cfg
/usr/share/monitoring-plugins/templates-standard/dns.cfg
/usr/share/monitoring-plugins/templates-standard/mysql.cfg
/usr/share/monitoring-plugins/templates-standard/rpc-nfs.cfg
/usr/share/monitoring-plugins/templates-standard/ifstatus.cfg
/usr/share/monitoring-plugins/templates-standard/pgsql.cfg
/usr/share/monitoring-plugins/templates-standard/games.cfg
/usr/share/monitoring-plugins/templates-standard/netware.cfg
/usr/share/autoconf/autom4te.cfg
/usr/share/lxpanel/xkeyboardconfig/toggle.cfg
/usr/share/lxpanel/xkeyboardconfig/layouts.cfg
/usr/share/lxpanel/xkeyboardconfig/models.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:tcp_udp.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:apt.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:dummy.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:ssh.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:flexlm.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:ftp.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:news.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:nt.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:pgsql.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:procs.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:snmp.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:mysql.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:breeze.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:radius.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:disk-smb.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:load.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:netware.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:disk.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:fping.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:http.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:dhcp.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:users.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:ping.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:mrtg.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:ifstatus.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:ntp.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:dns.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:mail.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:ldap.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:rpc-nfs.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:hppjd.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:games.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:real.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:telnet.cfg
/var/lib/ucf/cache/:etc:nagios-plugins:config:mailq.cfg
/opt/Wolfram/WolframEngine/10.0/SystemFiles/IncludeFiles/TeX/texmf/pdftex/config/pdftex.cfg
/etc/xdg/lxpanel/launchtaskbar.cfg
/etc/nagios-plugins/config/ssh.cfg
/etc/nagios-plugins/config/disk-smb.cfg
/etc/nagios-plugins/config/ftp.cfg
/etc/nagios-plugins/config/breeze.cfg
/etc/nagios-plugins/config/dhcp.cfg
/etc/nagios-plugins/config/procs.cfg
/etc/nagios-plugins/config/ping.cfg
/etc/nagios-plugins/config/hppjd.cfg
/etc/nagios-plugins/config/mailq.cfg
/etc/nagios-plugins/config/fping.cfg
/etc/nagios-plugins/config/dummy.cfg
/etc/nagios-plugins/config/http.cfg
/etc/nagios-plugins/config/nt.cfg
/etc/nagios-plugins/config/real.cfg
/etc/nagios-plugins/config/load.cfg
/etc/nagios-plugins/config/flexlm.cfg
/etc/nagios-plugins/config/news.cfg
/etc/nagios-plugins/config/ldap.cfg
/etc/nagios-plugins/config/snmp.cfg
/etc/nagios-plugins/config/radius.cfg
/etc/nagios-plugins/config/mrtg.cfg
/etc/nagios-plugins/config/dns.cfg
/etc/nagios-plugins/config/tcp_udp.cfg
/etc/nagios-plugins/config/apt.cfg
/etc/nagios-plugins/config/mysql.cfg
/etc/nagios-plugins/config/rpc-nfs.cfg
/etc/nagios-plugins/config/ifstatus.cfg
/etc/nagios-plugins/config/pgsql.cfg
/etc/nagios-plugins/config/telnet.cfg
/etc/nagios-plugins/config/games.cfg
/etc/nagios-plugins/config/check_nrpe.cfg
/etc/nagios-plugins/config/netware.cfg
/etc/nagios-plugins/config/users.cfg
/etc/nagios-plugins/config/disk.cfg
/etc/nagios-plugins/config/ntp.cfg
/etc/nagios-plugins/config/mail.cfg
/etc/vdpau_wrapper.cfg
/etc/dpkg/dpkg.cfg
/etc/timidity/freepats.cfg
/etc/timidity/timidity.cfg
/etc/perl/Net/libnet.cfg
/etc/wildmidi/wildmidi.cfg
/etc/qstat.cfg
thanks
Not Happy NRPE on Raspberry PI
- Box293
- Too Basu
Re: Not Happy NRPE on Raspberry PI
From the Nagios server please post the nagios definitions for:kwhogster wrote:Now on Nagios server this works
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/./check_nrpe -H 10.2.8.72
NRPE v2.15
On the Nagios Page I still get this warning No handler for command: check_mem
- The service using check_mem
The host object the service is assigned to
The command definition for nrpe that the service uses
Define Service
TGCS018 and vMA both work My PI does not
The Host define
Again TGCS018 and vMA both are working
The command
# Defining Nagios Command for NRPE Plugin
command_name check_nrpe
command_line /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ $ARG2$ $ARG3$ $ARG4$
command_name check_nrpe_test
command_line /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ $ARG2$ $ARG3$ $ARG4$ > /tmp/yourlog.txt
command_name check_mem
command_line $USER1$/check_mem.sh
check_nrpe_test I am working on another issue with that one
# Define Check_nrpe for Check Mem on Linux
host_name RaspberryPi
service_description Check Memory Used Physical
check_command check_nrpe!check_mem! -a '-w 80 -c 90'
check_interval 1
servicegroups MemUsage
host_name TGCS018
check_command check_nrpe!check_mem! -a '-w 80% -c 90%'
check_interval 1
host_name vMA
check_interval 1
The Host define
# Define Unix Hosts
use linux-server
alias Rasbian
address 10.2.8.70
hostgroups linux-servers
use linux-server
host_name vMA
alias VmWare
address 10.2.8.7
use linux-server
host_name TGCS018
alias Cent OS7
address 10.2.8.74
The command
- Box293
- Too Basu
Your nagios server is not pointing to the IP Address 10.2.8.72.Box293 wrote:kwhogster wrote:Now on Nagios server this works
NRPE v2.15
On the Nagios Page I still get this warning No handler for command: check_memCode: Select all
define host{ use linux-server host_name RaspberryPi alias Rasbian address 10.2.8.70 hostgroups linux-servers }
Troy
OOOOPs that was it made the change to 10.2.8.72 brain fart I guess.
Now working
Now only have one function not working on Nagios
Now I can work on that one
Thanks every one for your help
This issue can be Locked now
Now working
