Not Happy NRPE on Raspberry PI
OK First off I had an issue open and the last posted replied wipe your PI and start over with clean install of NRPE and Plugins
The He LOCKED the QUESTION so I can no longer posted I never asked for it to be locked and now I have to start all over again this is not acceptable
So I removed all NRPe and Nagios Server and Nagios Plugins on the PI
restarted the PI
Started to install NRPE again and now can not start the NRPE daemon service
ran this to install
sudo apt-get install nagios-nrpe-server
After I put Allowed_hosts=10.2.8.79 the Nagios server ip address
I tried to start the service this failed
root@raspberrypi:/tmp# sudo service nagios-nrpe-server restart
Failed to restart nagios-nrpe-server.service: Unit nagios-nrpe-server.service failed to load: No such file or directory
I believe that file Nagios-nrpe-server belongs in this folder /etc/init.d it is not there and it did not get created during the install
Need help on this please
restarted the PI
ran this to install
- Box293
- Too Basu
Re: Not Happy NRPE on Raspberry PI
Is there anything logged in /var/log/syslog ?
yes tons of stuff what to look for
I used these instructions to install nrpe on the PI
https://outsideit.net/monitor-raspberry/
this failed to run
make install-xinetd
ran this
apt-get install xinetd
then it worked
But still now nrpe service of any kind running
this failed to run
make install-xinetd
ran this
then it worked
- Box293
- Too Basu
If you're using xinetd then you don't use an NPRE service, xinetd is responsible for running nrpe (it starts and stops it every time a connection attempt is made).
There should be a file called /etc/xinetd.d/nrpe
Please post any configuration files you changed and the location of these files.
Also post the result of testing NRPE from the nagios server:
check_nrpe -H pi_addressAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
root@raspberrypi:/usr/local/nagios/nrpe-2-15# ls /etc/xinetd.d
chargen daytime discard echo nrpe time
root@raspberrypi:/usr/local/nagios/nrpe-2-15# ls /etc/xinetd.d/nrpe
/etc/xinetd.d/nrpe
root@raspberrypi:/usr/local/nagios/nrpe-2-15# vi /etc/xinetd.d/nrpe
# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
flags = REUSE
socket_type = stream
port = 5666
wait = no
user = nagios
group = nagios
server = /usr/local/nagios/bin/nrpe
server_args = -c /usr/local/nagios/etc/nrpe.cfg --inetd
log_on_failure += USERID
disable = no
only_from = 127.0.0.1
The only file I modified is this one located here
vi /usr/local/nagios/etc/nrpe.cfg
log_facility=daemon
pid_file=/var/run/nagios/nrpe.pid
server_port=5666
nrpe_user=nagios
nrpe_group=nagios
allowed_hosts=10.2.8.79
dont_blame_nrpe=1
allow_bash_command_substitution=0
debug=0
command_timeout=60
connection_timeout=300
command[check_load]=/usr/lib/nagios/plugins/check_load $ARG1$
command[check_mem]=/usr/lib/nagios/plugins/check_mem $ARG1$
command[check_procs]=/usr/lib/nagios/plugins/check_procs $ARG1$
command[check_swap]=/usr/lib/nagios/plugins/check_swap $ARG1$
from the Nagios server
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/./check_nrpe -H 10.2.8.72
connect to address 10.2.8.72 port 5666: Connection refused
connect to host 10.2.8.72 port 5666: Connection refusedroot@tgcs017:/usr/local/nagios/etc/objects#
Update
Checked etc/services
# Nagios services
nrpe 5666/tcp
that's there
Update
ran this on the PI
service xinetd restart
Now from Nagios server
CHECK_NRPE: Error - Could not complete SSL handshake.
/etc/xinetd.d/nrpe
# default: on
service nrpe
flags = REUSE
port = 5666
wait = no
user = nagios
group = nagios
disable = no
log_facility=daemon
server_port=5666
nrpe_user=nagios
nrpe_group=nagios
dont_blame_nrpe=1
debug=0
command_timeout=60
Update
# Nagios services
nrpe 5666/tcp
that's there
Update
ran this on the PI
- Box293
- Too Basu
You need to edit this file:
/etc/xinetd.d/nrpe
And change this line to include your IP Address
only_from = 127.0.0.1 10.2.8.79
Then restart the xinetd service.
When xinetd is used, the allowed_hosts= line in /usr/local/nagios/etc/nrpe.cfg is ignored.
/etc/xinetd.d/nrpe
Getting closer on this one
made the change
/etc/xinetd.d/nrpe
Now on Nagios server this works
NRPE v2.15
On the Nagios Page I still get this warning No handler for command: check_mem
Update
When I run this from the Nagios server I get this it works
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/./check_nrpe -H 10.2.8.72 -c check_mem
[MEMORY] Total: 434 MB - Used: 82 MB - 18% [SWAP] Total: 99 MB - Used: 0 MB - 0% | MTOTAL=455725056;;;; MUSED=84869120;;;; MCACHE=245768192;;;; MBUFFER=71135232;;;; STOTAL=104853504;;;; SUSED=0;;;;
When I run this on the PI it works
root@raspberrypi:/home/pi/Downloads# /usr/local/nagios/libexec/./check_mem.sh
[MEMORY] Total: 434 MB - Used: 81 MB - 18% [SWAP] Total: 99 MB - Used: 0 MB - 0% | MTOTAL=455725056;;;; MUSED=84160512;;;; MCACHE=245768192;;;; MBUFFER=71135232;;;; STOTAL=104853504;;;; SUSED=0;;;;
What am I missing here?
made the change
/etc/xinetd.d/nrpe
NRPE v2.15
Update
You need to setup a definition for check_mem in /usr/local/nagios/etc/nrpe.cfg, for example -
Then, restart the service once again and it should return the expected result. If it does not, take a look at permissions and make sure the nagios user can execute check_mem.sh
command[check_mem]=/usr/local/nagios/libexec/check_mem.sh
I have that already defined in nrpe.cfg
command[check_mem]=/usr/local/nagios/libexec/check_mem.sh $ARG1$
Check permissions on what?
As you can see in my previous post
I am able to run check_mem.sh
How do I do this?
How do I do this?
- Box293
- Too Basu
What is the output of:
find / -name *nrpe*
find / -name *.cfgAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
