how can monitor with check_by_ssh
- Former Nagios Staff
Re: how can monitor with check_by_ssh
What's the output of /usr/local/nagios/libexec/check_uptime on the remote server?
dwhitfield wrote:What's the output of /usr/local/nagios/libexec/check_uptime on the remote server?
Uptime OK: 16 day(s) 23 hour(s) 30 minute(s) | uptime=24450.000000;;;
what are the permissions of check_ssh?
I don't insult, I diagnose.
ruffsense wrote:what are the permissions of check_ssh?
this is on nagios server
-rwxr-xr-x. 1 nagios nagios 183476 May 26 2016 /usr/local/nagios/libexec/check_by_ssh
What user did you run /usr/local/nagios/libexec/check_uptime as on the remote server? Was in nagios? If not, can you try that.
dwhitfield wrote:What user did you run /usr/local/nagios/libexec/check_uptime as on the remote server? Was in nagios? If not, can you try that.
i run this command with nagios user on remote server
[nagios@nppptgs root]$ /usr/local/nagios/libexec/check_uptime
Uptime OK: 17 day(s) 0 hour(s) 4 minute(s) | uptime=24484.000000;;;
also run that command with root user on remote server
[root@nppptgs ~]# /usr/local/nagios/libexec/check_uptime
Uptime OK: 17 day(s) 0 hour(s) 5 minute(s) | uptime=24485.000000;;;
This is the same server with the NRPE issue, yes? Is that server in production? If not, it might be easier at this point to just start over with that server and go back to NRPE since you have that working on your other servers.
dwhitfield wrote:This is the same server with the NRPE issue, yes? Is that server in production? If not, it might be easier at this point to just start over with that server and go back to NRPE since you have that working on your other servers.
yes this is the same server and this sever is in production site and is so important
sshd config file was ok ?
I think problem is sshd_conf file on remote host for example i said previously can not login with root user directly to server first have to login with user X Then su -
What is your idea??
baber wrote:dwhitfield wrote:This is the same server with the NRPE issue, yes? Is that server in production? If not, it might be easier at this point to just start over with that server and go back to NRPE since you have that working on your other servers.
What is your idea??
So many thanks from all of friends
problem has been solved with add switch E at the end of command line
/usr/local/nagios/libexec/check_by_ssh -H 10.10.10.10 -C 'uptime' -E
For others coming to this thread later, from the man page at http://nagios-plugins.org/doc/man/check_by_ssh.html
@baber, we ready to lock this up?-E, --skip-stderr[=n]
Ignore all or (if specified) first n lines on STDERR [optional]
