how can monitor with check_by_ssh
baber
Post by baber »
Dear all
Hi
i want use check_by_ssh
now i can ssh from nagios server to remote linux server without password but when run check_by_ssh from nagios server this errr appear
/usr/local/nagios/libexec/check_by_ssh -H 10.10.10.10 -C '/usr/local/nagios/libexec/check_uptime'
Remote command execution failed: Unauthorized access is prohibited.
how can solve the problem ?
BR
Reason: marking with green check mark
Re: how can monitor with check_by_ssh
Post by dwhitfield »
Are you running the command as root or as the nagios user?
Did you use the relevant parts of https://assets.nagios.com/downloads/nag ... ng_SSH.pdf to set this up?
baber
Post by baber »
dwhitfield wrote:Are you running the command as root or as the nagios user?
run command with nagios user on nagios server
when from nagios server with nagios user type ssh nagios@remote linux ip it will connect to that server without password but when type this command from nagios server with nagios user beloaw appear
/usr/local/nagios/libexec/check_by_ssh -H 10.4.1.97 -C '/usr/local/nagios/libexec/check_uptime'
On the remote server, what's the output of ls -la /usr/local/nagios/libexec/?
baber
Post by baber »
dwhitfield wrote:On the remote server, what's the output of ls -la /usr/local/nagios/libexec/?
output is :
total 6448
drwxrwxr-x. 2 nagios nagios   4096 Nov 29 18:45 .
drwxr-xr-x. 8 nagios nagios   4096 Nov 18 01:27 ..
-rwxr-xr-x. 1 nagios nagios 109380 Nov 21 19:23 check_apt
-rwxr-xr-x. 1 nagios nagios   2309 Nov 21 19:23 check_breeze
-rwxr-xr-x. 1 nagios nagios 112798 Nov 21 19:23 check_by_ssh
-rwxr-xr-x. 1 nagios nagios  14514 Nov 21 19:23 check_cciss-1.12
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_clamd
-rwxr-xr-x. 1 nagios nagios  89647 Nov 21 19:23 check_cluster
-rwxr-xr-x. 1 nagios nagios    349 Nov 21 19:23 check_cpu
-rwxr-xr-x. 1 nagios nagios   9450 Nov 21 19:23 check_daytime.pl
-rwxr-xr-x. 1 nagios nagios 114794 Nov 21 19:23 check_dhcp
-rwxr-xr-x. 1 nagios nagios 109660 Nov 21 19:23 check_dig
-rwxr-xr-x. 1 nagios nagios 132189 Nov 21 19:23 check_disk
-rwxr-xr-x. 1 nagios nagios  12981 Nov 21 19:23 check_disk.pl
-rwxr-xr-x. 1 nagios nagios   9348 Nov 21 19:23 check_disk_smb
-rwxr-xr-x. 1 nagios nagios 120155 Nov 21 19:23 check_dns
-rwxr-xr-x. 1 nagios nagios  58744 Nov 21 19:23 check_dummy
-rwxr-xr-x. 1 nagios nagios   3542 Nov 21 19:23 check_file_age
-rwxr-xr-x. 1 nagios nagios   6375 Nov 21 19:23 check_flexlm
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_ftp
-rwxr-xr-x. 1 nagios nagios 231033 Nov 21 19:23 check_http
-rwxr-xr-x. 1 nagios nagios 118453 Nov 21 19:23 check_icmp
-rwxr-xr-x. 1 nagios nagios  94055 Nov 21 19:23 check_ide_smart
-rwxr-xr-x. 1 nagios nagios  15238 Nov 21 19:23 check_ifoperstatus
-rwxr-xr-x. 1 nagios nagios  13386 Nov 21 19:23 check_ifstatus
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_imap
-rwxr-xr-x. 1 nagios nagios   6947 Nov 21 19:23 check_ircd
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_jabber
-rwxr-xr-x. 1 nagios nagios 103711 Nov 21 19:23 check_ldap
-rwxr-xr-x. 1 nagios nagios 103711 Nov 21 19:23 check_ldaps
-rwxr-xr-x. 1 nagios nagios   5064 Nov 21 19:23 check_listen_tcp_udp.sh
-rwxr-xr-x. 1 nagios nagios  98727 Nov 21 19:23 check_load
-rwxr-xr-x. 1 nagios nagios   6595 Nov 21 19:23 check_log
-rwxr-xr-x. 1 nagios nagios  22730 Nov 21 19:23 check_mailq
-rwxr-xr-x. 1 nagios nagios  12103 Nov 21 19:23 check_mem.pl
-rwxr-xr-x. 1 nagios nagios  93767 Nov 21 19:23 check_mrtg
-rwxr-xr-x. 1 nagios nagios  93748 Nov 21 19:23 check_mrtgtraf
-rwxr-xr-x. 1 nagios nagios    945 Nov 21 19:23 check_my_hplog
-rwxr-xr-x. 1 nagios nagios    486 Nov 21 19:23 check_my_hwclock
-rwxr-xr-x. 1 nagios nagios   1130 Nov 21 19:23 check_my_ntp
-rwxr-xr-x. 1 nagios nagios   1266 Nov 21 19:23 check_my_perm
-rwxr-xr-x. 1 nagios nagios    986 Nov 21 19:23 check_my_raid
-rwxr-xr-x. 1 nagios nagios    198 Nov 21 19:23 check_my_runlevel
-rwxr-xr-x. 1 nagios nagios  98713 Nov 21 19:23 check_nagios
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_nntp
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_nntps
-rwxrwxr-x. 1 nagios nagios 125293 Nov 29 18:45 check_nrpe
-rwxr-xr-x. 1 nagios nagios 114720 Nov 21 19:23 check_nt
-rwxr-xr-x. 1 nagios nagios 115676 Nov 21 19:23 check_ntp
-rwxr-xr-x. 1 nagios nagios 112146 Nov 21 19:23 check_ntp_peer
-rwxr-xr-x. 1 nagios nagios 109094 Nov 21 19:23 check_ntp_time
-rwxr-xr-x. 1 nagios nagios 129047 Nov 21 19:23 check_nwstat
-rwxr-xr-x. 1 nagios nagios   8926 Nov 21 19:23 check_oracle
-rwxr-xr-x. 1 nagios nagios 103949 Nov 21 19:23 check_overcr
-rwxr-xr-x. 1 nagios nagios 118149 Nov 21 19:23 check_ping
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_pop
-rwxr-xr-x. 1 nagios nagios 119469 Nov 21 19:23 check_procs
-rwxr-xr-x. 1 nagios nagios 102685 Nov 21 19:23 check_real
-rwxr-xr-x. 1 nagios nagios   9642 Nov 21 19:23 check_rpc
-rwxr-xr-x. 1 nagios nagios   1465 Nov 21 19:23 check_sensors
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_simap
-rwxr-xr-x. 1 nagios nagios 166365 Nov 21 19:23 check_smtp
-rwxr-xr-x. 1 nagios nagios 516378 Nov 21 19:23 check_snmp
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_spop
-rwxr-xr-x. 1 nagios nagios  99275 Nov 21 19:23 check_ssh
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_ssmtp
-rwxr-xr-x. 1 nagios nagios  93399 Nov 21 19:23 check_swap
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_tcp
-rwxr-xr-x. 1 nagios nagios 100933 Nov 21 19:23 check_time
-rwxr-xr-x. 1 nagios nagios 150011 Nov 21 19:23 check_udp
-rwxr-xr-x. 1 nagios nagios 109713 Nov 21 19:23 check_ups
-rwxr-xr-x. 1 nagios nagios  89243 Nov 21 19:23 check_uptime
-rwxr-xr-x. 1 nagios nagios  87997 Nov 21 19:23 check_users
-rwxr-xr-x. 1 nagios nagios   2995 Nov 21 19:23 check_wave
-rwxr-xr-x. 1 nagios nagios  83511 Nov 21 19:23 negate
-rwxr-xr-x. 1 nagios nagios  81229 Nov 21 19:23 urlize
-rwxr-xr-x. 1 nagios nagios   1949 Nov 21 19:23 utils.pm
-rwxr-xr-x. 1 nagios nagios   2791 Nov 21 19:23 utils.sh
also on remote server these output commands:
ll -a /home/nagios
total 40
drwx------. 5 nagios nagios 4096 Dec  1 18:28 .
drwxr-xr-x. 5 root   root   4096 Dec  1 18:25 ..
-rw-rw-r--. 1 nagios nagios 1981 Dec  1 21:06 .bash_history
-rw-r--r--. 1 nagios nagios   18 Dec 22  2015 .bash_logout
-rw-r--r--. 1 nagios nagios  176 Dec 22  2015 .bash_profile
-rw-r--r--. 1 nagios nagios  124 Dec 22  2015 .bashrc
drwxr-xr-x. 2 nagios nagios 4096 Jul 14  2010 .gnome2
drwxr-xr-x. 4 nagios nagios 4096 Nov  1 11:40 .mozilla
drwxr-xr-x. 2 nagios nagios 4096 Dec  1 21:05 .ssh
-rw-------. 1 nagios nagios  669 Dec  1 18:28 .viminfo
ll -a /home/nagios/.ssh/
total 16
drwx------. 5 nagios nagios 4096 Dec  1 18:28 ..
-rw-------. 1 nagios nagios  396 Dec  1 21:05 authorized_keys
-rw-r--r--. 1 nagios nagios  391 Dec  1 20:26 known_hosts
Please post the complete command definition.
Something that looks like, but for your setup
command_name check_slash_free
command_line $USER1$/check_by_ssh -i /var/ssh/nagios-key -l nagios
-H $HOSTADDRESS$ -C '$USER1$/check_disk -w $\ARG1$ -c $ARG2$ -p
baber
Post by baber »
dwhitfield wrote:Please post the complete command definition.
i write this in command.cfg file on nagios server
    command_name    check_ssh_disk
    command_line    $USER1$/check_by_ssh -H $HOSTADDRESS$ -C '/usr/local/nagios/libexec/check_disk -w 20% -c 10%' -t 30
but now below command also not work correctly
[nagios@Nagios ~]$ /usr/local/nagios/libexec/check_by_ssh -H 10.10.10.10 -C '/usr/local/nagios/libexec/check_uptime'
on remote server root user can not login to server we have to connect to server with oyher user then su - for use roor user
is there any relation?
what do i have to do ?
baber
Post by baber »
even when i just ssh to remote server with nagios user this appear
[nagios@Nagios libexec]$ ssh [email protected]
Last login: Thu Dec  1 21:06:05 2016 from 10.0.4.73
Authorized uses only. All activity may be monitored and reported.
baber wrote:even when i just ssh to remote server with nagios user this appear
That doesn't look like an error to me, just a notice. Just to be sure nothing weird is going on though, can you post the contents of /etc/ssh/sshd_config? You can scrub as needed or PM me the file if you are concerned.
If you choose to PM the file, please make sure you update this forum thread that you have done so, so that the thread pops back up on our dashboard.
baber
Post by baber »
i have sent httpd.conf file
also this is a banner
cat /etc/ssh/sshd_banner
also don't have to change this line in httpd_config file that sent PM
PermitRootLogin no
this is sshd_config file on remote server
# This is the sshd server system-wide configuration file.  See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/local/bin:/bin:/usr/bin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented.  Uncommented options change a
# default value.
#Port 22
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
# Disable legacy (protocol version 1) support in the server for new
# installations. In future the default will change to require explicit
# activation of protocol 1
Protocol 2
# HostKey for protocol version 1
#HostKey /etc/ssh/ssh_host_key
# HostKeys for protocol version 2
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_dsa_key
# Lifetime and size of ephemeral version 1 server key
#KeyRegenerationInterval 1h
#ServerKeyBits 1024
# Logging
# obsoletes QuietMode and FascistLogging
#SyslogFacility AUTH
SyslogFacility AUTHPRIV
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
PermitRootLogin no
#StrictModes yes
MaxAuthTries 4
#MaxSessions 10
#RSAAuthentication yes
#PubkeyAuthentication yes
#AuthorizedKeysFile	.ssh/authorized_keys
#AuthorizedKeysCommand none
#AuthorizedKeysCommandRunAs nobody
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#RhostsRSAAuthentication no
# similar for protocol version 2
#HostbasedAuthentication no
# Change to yes if you don't trust ~/.ssh/known_hosts for
# RhostsRSAAuthentication and HostbasedAuthentication
#IgnoreUserKnownHosts no
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# To disable tunneled clear text passwords, change to no here!
#PasswordAuthentication yes
#PermitEmptyPasswords no
# Change to no to disable s/key passwords
#ChallengeResponseAuthentication yes
ChallengeResponseAuthentication no
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
#KerberosUseKuserok yes
# GSSAPI options
#GSSAPIAuthentication no
GSSAPIAuthentication yes
#GSSAPICleanupCredentials yes
#GSSAPIStrictAcceptorCheck yes
#GSSAPIKeyExchange no
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication.  Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
#UsePAM no
UsePAM yes
# Accept locale-related environment variables
AcceptEnv LANG LC_CTYPE LC_NUMERIC LC_TIME LC_COLLATE LC_MONETARY LC_MESSAGES
AcceptEnv LC_PAPER LC_NAME LC_ADDRESS LC_TELEPHONE LC_MEASUREMENT
AcceptEnv LC_IDENTIFICATION LC_ALL LANGUAGE
AcceptEnv XMODIFIERS
#AllowAgentForwarding yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding no
#X11DisplayOffset 10
#X11UseLocalhost yes
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation yes
#PermitUserEnvironment no
#Compression delayed
ClientAliveInterval 3000
ClientAliveCountMax 0
#ShowPatchLevel no
#UseDNS yes
#PidFile /var/run/sshd.pid
#MaxStartups 10:30:100
#PermitTunnel no
#ChrootDirectory none
# no default banner path
#Banner none
# override default of no subsystems
Subsystem	sftp	/usr/libexec/openssh/sftp-server
# Example of overriding settings on a per-user basis
#Match User anoncvs
#	X11Forwarding no
#	AllowTcpForwarding no
#	ForceCommand cvs server
# CIS Benchmarks
# CIS 6.2.12
Ciphers aes128-ctr,aes192-ctr,aes256-ctr
# CIS 6.2.14
Banner /etc/ssh/sshd_banner
BR
