object notes component stopped working with 2011R1.8
CBoekhuis
Re: object notes component stopped working with 2011R1.8
Post by CBoekhuis »
Hi Mike,
The object notes tab is functional again, great work!
As for the history tab, that didn't solve it, but that wasn't the scope of this post as far as I'm concerned.
I could start a new post for that problem if you like?
Hans
mguthrie
Post by mguthrie »
Just to be safe, can you try reinstalling the history tab component and see if it shows up? The fix *should* have fixed both, and it did in our local tests.
CBoekhuis
Post by CBoekhuis »
I did reinstall the history component, but still the same problem.
For clarification, when both components are installed and as soon as I click the "save" button after entering text in the objects note tab, The frame in the browser turns blank. When I go back in the the object notes tab, the text I entered has disappeared (not saved). This doesn't happen when the history component is not installed.
mguthrie
Post by mguthrie »
The history tab component is a community developed component. Can you run:
tail -f /var/log/httpd/error_log
And then attempt to recreate the blank page. When PHP has a fatal error, it produces a blank page in the browser and outputs error messaging to the apache log.
Post by Box293 »
What a great thread, I get a fix for a problem and also discover another problem for the History tab I created :lol:
I've had a bit of a play and it seems that the problem occurs when using Firefox (my version is 7.0.1).
When I use IE9 it seems to work OK. However when I tried IE7 the problem occurred.
This is going to push my php skill to the limit working this out.
Mike,
No errors recorded in /var/log/httpd/error_log. Any ideas how I can track down the source of the problem?
CBoekhuis
Post by CBoekhuis »
Confirmed, I use firefox 7.0.1 and IE 7.0.5730.13. In both browsers I have this "problem".
My colleague also noticed that this occurs in Firefox 8.0.1 and IE 8.0.6001.18702.
mguthrie
Post by mguthrie »
Hey Box293,
I think the reason you're not finding any log errors is that this wasn't a PHP issue, but a javascript issue. Here's the diff I ran for the tab fix, it was just a small change, and I'm not sure if it will help or not, but I thought I'd send it along.
 2011R1.8 - 10/28/2011
Index: C:/Users/mguthrie/SVN/nagiosxi/trunk/nagiosxi/basedir/html/includes/components/xicore/status-object-detail.inc.php
--- C:/Users/mguthrie/SVN/nagiosxi/trunk/nagiosxi/basedir/html/includes/components/xicore/status-object-detail.inc.php	(revision 880)
+++ C:/Users/mguthrie/SVN/nagiosxi/trunk/nagiosxi/basedir/html/includes/components/xicore/status-object-detail.inc.php	(revision 881)
@@ -39,6 +39,7 @@
 	do_callbacks(CALLBACK_SERVICE_TABS_INIT,$cbdata);
 	$customtabs=grab_array_var($cbdata,"tabs",array());
+	//echo "CUSTOMTABS:<BR>";
 	//print_r($customtabs);
 	// save this for later
@@ -79,7 +80,7 @@
 	<br clear="all">
 <script type="text/javascript">
-	$(function() {
+	$(document).ready(function() {
 		$("#tabs").tabs();
 	</script>
@@ -105,7 +106,7 @@
 	foreach($customtabs as $ct){
 		$id=grab_array_var($ct,"id");
 		$title=grab_array_var($ct,"title");
-		echo "<li><a href='#tab-custom-".$id."' class='ui-tabs-hide'>".$title."</a></li>";
+		echo "<li><a href='#tab-custom-".$id."'>".htmlentities($title)."</a></li>";
 	</ul>
You should have a javascript error console in your browser somewhere, use that to see if you have any javascript errors. (I should warn you, debugging javascript is a pain). I'll try and jump in on this as well when I get through the support threads, we're still playing catch-up from the holiday ; )
mguthrie
Post by mguthrie »
Hey Box293,
I'm pretty sure I found the issue. There were two issues with the history tab.
- a <link> tag in the html body, these can only go in the head of an html document
- an unclosed <form> tag, so any tabs that were after the history tab broke because it thought it was part of the same form
Patched version below, go ahead and test it out and see if this fixed it.
Changes on historytab.inc.php line 935 and 212
Post by Box293 »
Awesome thanks for that, I'll have a look tonight.
Much appreciated.
CBoekhuis
Post by CBoekhuis »
That works! Thank you all for fixing this issue, now we don't have to make a choice between which component to use :D .
Greetings,
Hans
