object notes component stopped working with 2011R1.8
CBoekhuis
Post by CBoekhuis »
Good afternoon,
not sure if I should report it here, but after upgrading to 2011R1.8 the component object_notes stopped working.
The Notes tab is still working under the host detail screen, but under the service detail screen the Notes tab has disappeared.
Greetings,
Hans Blom
Re: object notes component stopped working with 2011R1.8
Hans,
Thanks for the feedback! It is confirmed that this is a bug in R1.8. We will be working on fixing it as soon as we can. I posted it on our bug tracker. You can view it here:
http://tracker.nagios.com/view.php?id=200
CBoekhuis
Post by CBoekhuis »
Thanks for the confirmation, I'll wait for the fix to appear.
mguthrie
Post by mguthrie »
We've got this fixed in SVN as of this morning. Are you interested in the patch, or do you want to wait until 1.9? (It will be the same file).
arnab.roy
Post by arnab.roy »
Hi Mike,
Can you provide the patch to me it seems our system is also affected by this, also can you confirm why we cannot seem to have the history and objectnotes components together ?
Cheers
Arnab
CBoekhuis
Post by CBoekhuis »
Hi Mike,
that's great news. Could I have the patch please?
Also as Arnab wrote, we could never get object notes and the history component both working together, they seem to bite each other. But this problem was there before 1.8
Anyway, thanks for the great work
Hans
mguthrie
Post by mguthrie »
Yeah, let me see where the fixes are on this, but I think the fix should resolve each of the above issues, but I'll let you guys confirm ; )
arnab.roy
Post by arnab.roy »
Ok will wait for you to upload the patch
mguthrie
Post by mguthrie »
Make a backup of the following file:
cp /usr/local/nagiosxi/html/includes/components/xicore/status-object-details.inc.php /tmp
Then unzip and overwrite the old status-object-details file.
cp ./status-object-details.inc.php /usr/local/nagiosxi/html/includes/components/xicore/
Let us know if this takes care of the issue.
arnab.roy
Post by arnab.roy »
That fixed both the bugs great work thanks...
Cheers
Arnab
