https://exchange.nagios.org/components/ ... 0&cf_id=24
Here is exactly this plugim which I'm trying to use.
I'm copying it into text file with .sh extension
I have another question. Inform OS v2.3.1 which is highlighted in description is the only one which can be monitored or I can use it, for example with for storage with v3.1.2?
HP 3PAR storage monitoring
avandemore
Re: HP 3PAR storage monitoring
You may have used vi to create the file, but if you copy/pasted from a windows editor into vi then you also copy/pasted Windows line endings into a UNIX script.
Also to be clear by vi I assume you mean vim. There is a large difference for many things.
Please run the dos2unix referenced earlier or use vim itself to correct the errors:
Save and exit the file. Try running it again.
:set ff=unixPrevious Nagios employee
