This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
uertti1
Posts: 6 Joined: Wed Dec 14, 2016 6:54 am
Post
by uertti1 » Wed Dec 14, 2016 8:54 am
I have a problem withc check_3par plugin when i want to use it it dispays information:
./check_3par.sh: line 50: $'\r': command not found
./check_3par.sh: line 354: syntax error: unexpected end of file
Can somebody explain me what should I do? For me code looks good but I'm useless in programing.
I will be greatfull for help
uertti1
Post
by uertti1 » Wed Dec 14, 2016 10:16 am
Ok.
I solved problem which won't let me restart ganios but now I have 7 more problems because of checks:
It is how it looks:
Posts: 3739 Joined: Thu May 05, 2016 3:54 pm
Post
by mcapra » Wed Dec 14, 2016 12:38 pm
How was this plugin put on the Nagios XI server? That looks like there may be some encoding issues within the file.
You might try running the plugin through dos2unix:
http://linuxcommand.org/man_pages/dos2unix1.html
You could also try copying the plugin's contents and pasting them into a fresh file with vi/vim.
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Wed Dec 14, 2016 1:00 pm
Also, in addition to what @mcapra posted - I believe it could be the variables being passed to Nagios, could you show us the complete command / service related definition?
uertti1
Post
by uertti1 » Thu Dec 15, 2016 3:06 am
I didn't put plugin on by web interface. I did it manually by creating plugin file via "vi" command and changing commands.cfg file.
# check_ps : Check Power Supply Node and Cage
# Degraded -> Warning
# Failed -> Critical
HERE IS LINE 50<---------------------------------------------------------------------------------
if ["$1" == "" ] || [ $2 == "" ] || [ $3 == "" ]
then
echo Invalid usage : check_3par InServ Username/passwordfile Command
exit 3
fi
INSERV=$1
USERNAME=$2
COMMAND=$3
TMPDIR=/usr/local/nagios/libexec
PCCRITICALFC=90
PCWARNINGFC=80
PCCRITICALNL=90
PCWARNINGNL=80
Here are my commands and services files.
http://textuploader.com/ddm9l
http://textuploader.com/ddm9q
uertti1
Post
by uertti1 » Fri Dec 16, 2016 2:11 am
Ahh... Of course sorry. I should say about it earlier. Of course I'm trying to use SSH, and I can connect to storage by ssh from nagiosXI server.
I read this document while I was including 3par plugin configuration on nagios.
Post
by rkennedy » Fri Dec 16, 2016 11:26 am
Can you run the command correctly from the CLI?
/usr/local/nagios/libexec/check_3par <iphere>
(replace <iphere>)
If that fails, please post the entire check_3par script for us to review.
uertti1
Post
by uertti1 » Mon Dec 19, 2016 4:23 am
This is what apears when I'm trying to use check command
[root@nagioss libexec]# /usr/local/nagios/libexec/check_3par <iphere>
/usr/local/nagios/libexec/check_3par: line 50: $'\r': command not found
/usr/local/nagios/libexec/check_3par: line 354: syntax error: unexpected end of file
Post
by rkennedy » Mon Dec 19, 2016 11:21 am
We'll need to take a look at it.
