Service Status NOT FOUND
Re: Service Status NOT FOUND
Those logs appear to be old - what is the output of this ran on the Windows machine?
netstat -na | findstr 12489
Additionally, please post the full curent nsclient.ini from one of the machines. (also, specify which one it is)
Post by Box293 »
kwhogster wrote:Added Notes to my last posting of the ini files
I just restated one of the servers no change the same three services not working.
Also from the Nagios server I run this
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/./check_nt -H 10.2.8.34 -v SERVICESTATE -d SHOWALL -l uxsms
CRITICAL - Socket timeout after 10 seconds
HTH
This command won't work as you haven't specified the port or the secret.
It should be:
/usr/lib/nagios/plugins/check_nt -H 10.2.8.34 -p 12489 -s xxxxxxxx -v SERVICESTATE -d SHOWALL -l uxsms
Using your nsclient.ini file (SERVER06) on Windows 2008 R2 with NSClient v0.4.1.73 works fine:
./check_nt -H 10.25.14.2 -p 12489 -s xxxxxxxx -v SERVICESTATE -d SHOWALL -l uxsms
 uxsms: Started
I suggest:
  • un-installing NSClient++
    rebooting the server
    make sure the C:\Program Files\NSClient++ directory does not exist
    Install NSClient++
If that doesn't work then I would re-do above steps but try the latest version of NSClient++
kwhogster
Post by kwhogster »
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/./check_nt -H 10.2.8.33 -p 12489 -s xxxxxxxx -v SERVICESTATE -d SHOWALL -l uxsms
uxsms: Started
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/./check_nt -H 10.2.8.33 -p 12489 -s xxxxxxxxxx -v SERVICESTATE -d SHOWALL -l windefend
windefend: Started
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/./check_nt -H 10.2.8.34 -p 12489 -s xxxxxxxxx -v SERVICESTATE -d SHOWALL -l windefend
windefend: Started
root@tgcs017:/usr/local/nagios/etc/objects# vi servers.cfg
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/./check_nt -H 10.2.8.33 -p 12489 -s xxxxxxxx -v SERVICESTATE -d SHOWALL -l UxSms
UxSms: Started
That works
Rkennedy
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>netstat -na | findstr 12489
TCP 0.0.0.0:12489 0.0.0.0:0 LISTENING
TCP [::]:12489 [::]:0 LISTENING
Both machines look fine
As you can see from Box293 posting I had the command incorrect
Now it works with that command from the Nagios server and it sees those services are running.
Also I have a NRPE that checks all services and that is working too.
Just these three services on two servers very strange
Any ideas?
Post by dwhitfield »
kwhogster wrote: That works
Great!
Any ideas?
I'm a bit confused. The check @Box293 gave you is working...what exactly isn't working?
Reason: had an extra quote tag
kwhogster
Post by kwhogster »
Take a look at first page and my first post.
This was two questions
the one that is working is the command when I run it from the Nagios server console.
The Nagios web portal still shows not found
This is something in the config file I think now all network works nmap netstat etc. these in past post too.
REmember that I have over 70 services being checked on both of these machines and all but three are working
Yes strange
What user are those 3 services starting / running as? It may be related to permissions.
Also, please post the nsclient.log file as this may have a clue to where the problem is occurring.
kwhogster
Post by kwhogster »
rKennedy
The services
windefend Local Service account
wuauserv Local Service account
uxsms Local Service Account
NOTE
I also use this NRPE Check
host_name TGCS006
service_description Check All Service
check_command check_nrpe!checkservicestate! -a CheckAll exclude=WLMS
servicegroups AllServices
check_interval 1
This works fine it checks all the autostart services to make sure they are all started. It is not complaining about any of the three above
See attached nscleint ini file
ncslient.txt
nsclient of both servers
(16.92 KiB) Downloaded 428 times
kwhogster wrote:rKennedy
The services
NOTE
host_name TGCS006
check_interval 1
The commands posted above are using check_nrpe, where as the ones @Box293 had you run are with check_nt - in order to get it working, I suggest you switch them over to use check_nt specifically, as they appear to be working for you from the CLI -
uxsms: Started
windefend: Started
windefend: Started
UxSms: Started
kwhogster
Post by kwhogster »
They are using check_nt
I was just siting another example of something that is working on those two servers
Can we focus on the problem at hand review page 1 first post
The config files use check_nt.
The config file has 70 plus other services that use check_nt
It is just these 6 services not working and they are all started automatically
Thoughts :oops:
I looked at the Changelog for NSClient++ and there has been a lot of bug files for the check_nt compatibility and also a few bugs fixed for the SERVICESTATE command.
I suggest that you upgrade the servers with the latest stable 0.4.x version of NSClient++ and see if that fixes the issue.
You can download it at the following link.
http://www.nsclient.org
