Added two new VM servers to Nagios both Windows 2008 R2
I defined 45 services and of the 45 services two came up as NOT FOUND and the other as STOPPED
When I look on the servers all three services are started two of the services are set to automatic(delayed) the other is set to automatic
My defined services
host_name TGCS00
service_description UxSms
check_command check_nt!SERVICESTATE!-d SHOWALL -l UxSms
host_name TGCS006
service_description WinDefend
check_command check_nt!SERVICESTATE!-d SHOWALL -l WinDefend
host_name TGCS006
service_description wuauserv
check_command check_nt!SERVICESTATE!-d SHOWALL -l wuauserv
From the servers
Windows PowerShell
Copyright (C) 2009 Microsoft Corporation. All rights reserved.
PS C:\Windows\system32> get-service -name windef*
Status Name DisplayName
Running WinDefend Windows Defender
PS C:\Windows\system32> get-service -name uxsms
Running uxsms Desktop Window Manager Session Manager
PS C:\Windows\system32> get-service -name wuauserv
Running wuauserv Windows Update
PS C:\Windows\system32>As you can see they are all running
Thoughts
update:
on the two services that are stopped. wuauserv they once in awhile go ok but then come back they also have a box next to them with a arrow that goes up and down and inside the box the color is green
HTH
