tail -25 /usr/local/nagios/var/ndo2db.debug
109=1.00000
162=xi_timeperiod_24x7
262=XIWIZARD:0:switch
999
[1484283001.283140] [001.2] [pid=28273] Handling: 54=0
[1484283001.283169] [001.2] [pid=28273] Handling: 98=0.00000
[1484283001.283202] [001.2] [pid=28273] Handling: 71=0.00000
[1484283001.283232] [001.2] [pid=28273] Handling: 42=0.24284
[1484283001.283262] [001.2] [pid=28273] Handling: 113=0
[1484283001.283291] [001.2] [pid=28273] Handling: 45=0
[1484283001.283320] [001.2] [pid=28273] Handling: 103=1
[1484283001.283368] [001.2] [pid=28273] Handling: 91=1
[1484283001.283403] [001.2] [pid=28273] Handling: 78=0
[1484283001.283433] [001.2] [pid=28273] Handling: 37=
[1484283001.283479] [001.2] [pid=28273] Handling: 11=check_xi_host_ping!3000.0!80%!5000.0!100%
[1484283001.283515] [001.2] [pid=28273] Handling: 86=5.00000
[1484283001.283546] [001.2] [pid=28273] Handling: 109=1.00000
[1484283001.283577] [001.2] [pid=28273] Handling: 162=xi_timeperiod_24x7
[1484283001.283609] [001.2] [pid=28273] Handling: 262=XIWIZARD:0:switch
[1484283001.283640] [001.2] [pid=28273] Handling: 999
[1484283001.283700] [002.0] [pid=28273] INSERT INTO nagios_hoststatus SET instance_id='1', host_object_id='316', status_update_time=FROM_UNIXTIME(1484283001), output='OK - 209\.29\.4\.234: rta 46\.805ms, lost 0%', long_output='', perfdata='rta=46\.805ms;3000\.000;5000\.000;0; pl=0%;80;100;; rtmax=53\.568ms;;;; rtmin=45\.010ms;;;;', current_state='0', has_been_checked='1', should_be_scheduled='1', current_check_attempt='1', max_check_attempts='5', last_check=FROM_UNIXTIME(1484283001), next_check=FROM_UNIXTIME(1484283301), check_type='0', last_state_change=FROM_UNIXTIME(1481223386), last_hard_state_change=FROM_UNIXTIME(1481223386), last_hard_state='0', last_time_up=FROM_UNIXTIME(1484283001), last_time_down=FROM_UNIXTIME(1481223386), last_time_unreachable=FROM_UNIXTIME(0), state_type='1', last_notification=FROM_UNIXTIME(0), next_notification=FROM_UNIXTIME(0), no_more_notifications='0', notifications_enabled='1', problem_has_been_acknowledged='0', acknowledgement_type='0', current_notification_number='0', passive_checks_enabled='1', active_checks_enabled='1', event_handler_enabled='1', flap_detection_enabled='1', is_flapping='0', percent_state_change='0.000000', latency='0.000000', execution_time='0.242840', scheduled_downtime_depth='0', failure_prediction_enabled='0', process_performance_data='1', obsess_over_host='1', modified_host_attributes='0', event_handler='', check_command='check_xi_host_ping!3000\.0!80%!5000\.0!100%', normal_check_interval='5.000000', retry_check_interval='1.000000', check_timeperiod_object_id='131' ON DUPLICATE KEY UPDATE instance_id='1', host_object_id='316', status_update_time=FROM_UNIXTIME(1484283001), output='OK - 209\.29\.4\.234: rta 46\.805ms, lost 0%', long_output='', perfdata='rta=46\.805ms;3000\.000;5000\.000;0; pl=0%;80;100;; rtmax=53\.568ms;;;; rtmin=45\.010ms;;;;', current_state='0', has_been_checked='1', should_be_scheduled='1', current_check_attempt='1', max_check_attempts='5', last_check=FROM_UNIXTIME(1484283001), next_check=FROM_UNIXTIME(1484283301), check_type='0', last_state_change=FROM_UNIXTIME(1481223386), last_hard_state_change=FROM_UNIXTIME(1481223386), last_hard_state='0', last_time_up=FROM_UNIXTIME(1484283001), last_time_down=FROM_UNIXTIME(1481223386), last_time_unreachable=FROM_UNIXTIME(0), state_type='1', last_notification=FROM_UNIXTIME(0), next_notification=FROM_UNIXTIME(0), no_more_notifications='0', notifications_enabled='1', problem_has_been_acknowledged='0', acknowledgement_type='0', current_notification_number='0', passive_checks_enabled='1', active_checks_enabled='1', event_handler_enabled='1', flap_detection_enabled='1', is_flapping='0', percent_state_change='0.000000', latency='0.000000', execution_time='0.242840', scheduled_downtime_depth='0', failure_prediction_enabled='0', process_performance_data='1', obsess_over_host='1', modified_host_attributes='0', event_handler='', check_command='check_xi_host_ping!3000\.0!80%!5000\.0!100%', normal_check_interval='5.000000', retry_check_interval='1.000000', check_timeperiod_object_id='131'
[1484283001.284660] [002.0] [pid=28273] INSERT INtO nagios_customvariablestatus SET instance_id='1', object_id='316',status_update_time=FROM_UNIXTIME(1484283001), has_been_modified='0', varname='XIWIZARD', varvalue='switch' ON DUPLICATE KEY UPDATE instance_id='1', object_id='316',status_update_time=FROM_UNIXTIME(1484283001), has_been_modified='0', varname='XIWIZARD', varvalue='switch'
[1484283001.284859] [001.2] [pid=28273] Handling:
Please advise. thanks.
