Database Backend Is Not Running
gselvakumar
Post by gselvakumar »
We just upgraded the Nagios XI to 5.4.0 and now it says that the database backend isn't running.Even availability report is not working.I tried to follow the below mentioned post but still database backend isn't running :cry:
https://support.nagios.com/forum/viewto ... 72&start=0
All the services are running on the server as mentioned below
[root@xxxxxxx nagiosxi]# service nagios status
nagios (pid 1456) is running...
[root@xxxxxxxxxx nagiosxi]# service mysqld status
mysqld (pid  25955) is running...
[root@xxxxxx nagiosxi]# service ndo2db status
ndo2db (pid 1199) is running...
[root@xxxxxxxx nagiosxi]# service crond status
crond (pid  27187) is running...
Could please help us to fix it.
Thanks & Regards,
Gomathyshankar Selvakumar
Re: Database Backend Is Not Running
It could be a permission problem for the folders the ndo2db daemon stores it's lock/pid file.
Can you run the following as root on the server and post the output so we can see if the files are being created?
ls -l /usr/local/nagios/var/
ls -l /usr/local/nagiosxi/var/subsys
ps -ef --cols=300
raamardhani7
Post by raamardhani7 »
tgriep wrote:It could be a permission problem for the folders the ndo2db daemon stores it's lock/pid file.
ps -ef --cols=300
Hi Tom,
Please find the output for the ones asked for.
ps -ef --cols=300
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0  2015 ?        00:17:27 /sbin/init
root         2     0  0  2015 ?        00:00:01 [kthreadd]
root         3     2  0  2015 ?        00:09:57 [migration/0]
root         4     2  0  2015 ?        01:15:21 [ksoftirqd/0]
root         5     2  0  2015 ?        00:00:00 [stopper/0]
root         6     2  0  2015 ?        00:02:13 [watchdog/0]
root         7     2  0  2015 ?        00:09:59 [migration/1]
root         8     2  0  2015 ?        00:00:00 [stopper/1]
root         9     2  0  2015 ?        01:17:04 [ksoftirqd/1]
root        10     2  0  2015 ?        00:02:16 [watchdog/1]
root        11     2  0  2015 ?        00:27:46 [events/0]
root        12     2  0  2015 ?        00:46:17 [events/1]
root        13     2  0  2015 ?        00:00:00 [cgroup]
root        14     2  0  2015 ?        00:00:00 [khelper]
root        15     2  0  2015 ?        00:00:00 [netns]
root        16     2  0  2015 ?        00:00:00 [async/mgr]
root        17     2  0  2015 ?        00:00:00 [pm]
root        18     2  0  2015 ?        00:02:09 [sync_supers]
root        19     2  0  2015 ?        00:02:19 [bdi-default]
root        20     2  0  2015 ?        00:00:00 [kintegrityd/0]
root        21     2  0  2015 ?        00:00:00 [kintegrityd/1]
root        22     2  0  2015 ?        00:38:45 [kblockd/0]
root        23     2  0  2015 ?        00:40:28 [kblockd/1]
root        24     2  0  2015 ?        00:00:00 [kacpid]
root        25     2  0  2015 ?        00:00:00 [kacpi_notify]
root        26     2  0  2015 ?        00:00:00 [kacpi_hotplug]
root        27     2  0  2015 ?        00:00:00 [ata_aux]
root        28     2  0  2015 ?        00:00:00 [ata_sff/0]
root        29     2  0  2015 ?        00:00:00 [ata_sff/1]
root        30     2  0  2015 ?        00:00:00 [ksuspend_usbd]
root        31     2  0  2015 ?        00:00:00 [khubd]
root        32     2  0  2015 ?        00:00:00 [kseriod]
root        33     2  0  2015 ?        00:00:00 [md/0]
root        34     2  0  2015 ?        00:00:00 [md/1]
root        35     2  0  2015 ?        00:00:00 [md_misc/0]
root        36     2  0  2015 ?        00:00:00 [md_misc/1]
root        37     2  0  2015 ?        00:00:00 [linkwatch]
root        39     2  0  2015 ?        00:00:12 [khungtaskd]
root        40     2  0  2015 ?        00:04:03 [kswapd0]
root        41     2  0  2015 ?        00:00:00 [ksmd]
root        42     2  0  2015 ?        00:15:50 [khugepaged]
root        43     2  0  2015 ?        00:00:00 [aio/0]
root        44     2  0  2015 ?        00:00:00 [aio/1]
root        45     2  0  2015 ?        00:00:00 [crypto/0]
root        46     2  0  2015 ?        00:00:00 [crypto/1]
root        54     2  0  2015 ?        00:00:00 [kthrotld/0]
root        55     2  0  2015 ?        00:00:00 [kthrotld/1]
root        56     2  0  2015 ?        00:00:00 [pciehpd]
root        58     2  0  2015 ?        00:00:00 [kpsmoused]
root        59     2  0  2015 ?        00:00:00 [usbhid_resumer]
root        60     2  0  2015 ?        00:00:00 [deferwq]
root        92     2  0  2015 ?        00:00:00 [kdmremove]
root        93     2  0  2015 ?        00:00:00 [kstriped]
root       177     2  0  2015 ?        00:17:00 [mpt_poll_0]
root       178     2  0  2015 ?        00:00:00 [mpt/0]
root       179     2  0  2015 ?        00:00:00 [scsi_eh_0]
root       182     2  0  2015 ?        00:00:00 [scsi_eh_1]
root       183     2  0  2015 ?        00:00:00 [scsi_eh_2]
root       315     2  0  2015 ?        00:00:00 [kdmflush]
root       317     2  0  2015 ?        00:00:00 [kdmflush]
root       335     2  0  2015 ?        01:45:48 [jbd2/dm-0-8]
root       336     2  0  2015 ?        00:00:00 [ext4-dio-unwrit]
root       345     2  0  2015 ?        07:41:46 [flush-253:0]
root       609     2  0  2015 ?        00:09:08 [vmmemctl]
root       768     2  0  2015 ?        00:00:00 [jbd2/sda1-8]
root       769     2  0  2015 ?        00:00:00 [ext4-dio-unwrit]
root       852     2  0  2015 ?        00:09:56 [kauditd]
root      1190     1  0  2015 ?        10:00:29 /usr/sbin/vmtoolsd
root      1360     1  0  2015 ?        02:10:48 irqbalance --pid=/var/run/irqbalance.pid
dbus      1509     1  0  2015 ?        00:00:30 dbus-daemon --system
68        1526     1  0  2015 ?        00:02:56 hald
root      1527  1526  0  2015 ?        00:00:00 hald-runner
root      1559  1527  0  2015 ?        00:00:00 hald-addon-input: Listening on /dev/input/event2 /dev/input/event0
68        1569  1527  0  2015 ?        00:21:07 /usr/libexec/hald-addon-acpi
root      1632     1  0  2015 ?        00:14:11 /opt/storix/bin/lighttpd -f /storix/config/sthttpd.conf
root      1688     1  0  2015 ?        1-05:43:36 /opt/storix/tcl/bin/tcl /opt/storix/bin/stqdaemon
root      1774 15347  0 22:20 ?        00:00:00 CROND
root      1775 15347  0 22:20 ?        00:00:00 CROND
root      1776 15347  0 22:20 ?        00:00:00 CROND
root      1777 15347  0 22:20 ?        00:00:00 CROND
root      1778 15347  0 22:20 ?        00:00:00 CROND
root      1779 15347  0 22:20 ?        00:00:00 CROND
nagios    1802  1774  0 22:20 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1
nagios    1803  1777  0 22:20 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1
nagios    1804  1775  0 22:20 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1
nagios    1807  1778  0 22:20 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
nagios    1808  1776  0 22:20 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php > /usr/local/nagiosxi/var/event_handler.log 2>&1
nagios    1809  1779  0 22:20 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1
nagios    1811  1804  0 22:20 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php
nagios    1812  1807  0 22:20 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php
nagios    1814  1808  0 22:20 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php
nagios    1816  1802  0 22:20 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php
nagios    1817  1803  0 22:20 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php
nagios    1819  1809  0 22:20 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php
root      1972     1  0  2015 ?        00:00:27 rhnsd
nagios    2005     1  0 22:20 ?        00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
root      2026     1  0  2015 tty1     00:00:00 /sbin/mingetty /dev/tty1
root      2028     1  0  2015 tty2     00:00:00 /sbin/mingetty /dev/tty2
root      2030     1  0  2015 tty3     00:00:00 /sbin/mingetty /dev/tty3
root      2032     1  0  2015 tty4     00:00:00 /sbin/mingetty /dev/tty4
root      2034     1  0  2015 tty5     00:00:00 /sbin/mingetty /dev/tty5
root      2036     1  0  2015 tty6     00:00:00 /sbin/mingetty /dev/tty6
nagios    2091 23396  0 22:20 ?        00:00:00 /usr/local/nagios/libexec/check_icmp -H 10.81.96.255 -w 3000.0 80  -c 5000.0 100  -p 5 -t 60
nagios    2092 23395  0 22:20 ?        00:00:00 /usr/local/nagios/libexec/check_icmp -H 10.111.66.62 -w 3000.0 80  -c 5000.0 100  -p 5 -t 60
nagios    2101 23398  0 22:20 ?        00:00:00 /usr/local/nagios/libexec/check_icmp -H 10.138.40.50 -w 3000.0 80  -c 5000.0 100  -p 5 -t 60
nagios    2107 23396  0 22:20 ?        00:00:00 /usr/local/nagios/libexec/check_icmp -H 10.137.0.1 -w 3000.0 80  -c 5000.0 100  -p 5 -t 60
nagios    2121 23395  0 22:20 ?        00:00:00 /usr/local/nagios/libexec/check_icmp -H 10.138.31.255 -w 3000.0 80  -c 5000.0 100  -p 5 -t 60
nagios    2179  2005  0 22:20 ?        00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios    2180  2179  1 22:20 ?        00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios    2356 23397  0 22:20 ?        00:00:00 /usr/local/nagios/libexec/check_tcp -H 10.40.224.10 -p 22
root      2364 25000  0 22:20 pts/0    00:00:00 ps -ef --cols=300
ajaxterm  4015     1  0  2016 ?        01:12:35 python /usr/share/ajaxterm/ajaxterm.py --daemon --port=8022 --uid=ajaxterm
root      5341 11472  0  2016 ?        00:00:00 /sbin/udevd -d
root      5342 11472  0  2016 ?        00:00:00 /sbin/udevd -d
root     11048     1  0  2016 ?        00:12:09 xinetd -stayalive -pidfile /var/run/xinetd.pid
root     11472     1  0  2016 ?        00:00:00 /sbin/udevd -d
root     11800     1  0  2016 ?        00:56:52 /usr/sbin/snmpd -LS0-6d -Lf /dev/null -p /var/run/snmpd.pid
root     11943     1  0  2016 ?        00:10:56 /usr/sbin/snmptrapd -Lsd -p /var/run/snmptrapd.pid
postgres 12368     1  0  2016 ?        00:00:10 /usr/bin/postmaster -p 5432 -D /var/lib/pgsql/data
postgres 12370 12368  0  2016 ?        00:00:34 postgres: logger process
postgres 12372 12368  0  2016 ?        00:03:22 postgres: writer process
postgres 12373 12368  0  2016 ?        00:02:58 postgres: wal writer process
postgres 12374 12368  0  2016 ?        00:00:56 postgres: autovacuum launcher process
postgres 12375 12368  0  2016 ?        00:00:36 postgres: stats collector process
telegraf 13022     1  0  2016 ?        04:40:17 /usr/bin/telegraf -pidfile /var/run/telegraf/telegraf.pid -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d
root     13707     1  0  2016 ?        00:00:04 /usr/bin/rhsmcertd
root     14425     1  0  2016 ?        00:00:00 /usr/sbin/certmonger -S -p /var/run/certmonger.pid
root     14541     1  0  2016 ?        00:08:05 /usr/sbin/sshd
nagios   14565     1  0 19:12 ?        00:00:03 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
root     14837     1  0 19:12 pts/0    00:00:00 /bin/sh /usr/bin/mysqld_safe --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock --pid-file=/var/run/mysqld/mysqld.pid --basedir=/usr --user=mysql
root     14930     1  0  2016 ?        00:05:04 /usr/sbin/sssd -f -D
root     14931 14930  0  2016 ?        00:55:00 /usr/libexec/sssd/sssd_be --domain modern.local --uid 0 --gid 0 --debug-to-files
root     14932 14930  0  2016 ?        00:20:44 /usr/libexec/sssd/sssd_nss --uid 0 --gid 0 --debug-to-files
root     14933 14930  0  2016 ?        00:02:54 /usr/libexec/sssd/sssd_sudo --uid 0 --gid 0 --debug-to-files
root     14934 14930  0  2016 ?        00:27:27 /usr/libexec/sssd/sssd_pam --uid 0 --gid 0 --debug-to-files
root     14935 14930  0  2016 ?        00:00:59 /usr/libexec/sssd/sssd_ssh --uid 0 --gid 0 --debug-to-files
root     14936 14930  0  2016 ?        00:00:56 /usr/libexec/sssd/sssd_pac --uid 0 --gid 0 --debug-to-files
mysql    14946 14837  1 19:12 pts/0    00:03:17 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --log-error=/var/log/mysqld.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/lib/mysql/mysql.sock
root     15237     1  0 19:13 ?        00:00:00 /usr/sbin/httpd
apache   15239 15237  1 19:13 ?        00:02:44 /usr/sbin/httpd
apache   15240 15237  1 19:13 ?        00:02:46 /usr/sbin/httpd
apache   15241 15237  1 19:13 ?        00:02:47 /usr/sbin/httpd
apache   15242 15237  1 19:13 ?        00:02:48 /usr/sbin/httpd
apache   15243 15237  1 19:13 ?        00:02:48 /usr/sbin/httpd
apache   15244 15237  1 19:13 ?        00:02:46 /usr/sbin/httpd
apache   15245 15237  1 19:13 ?        00:02:44 /usr/sbin/httpd
apache   15246 15237  1 19:13 ?        00:02:43 /usr/sbin/httpd
root     15347     1  0 19:13 ?        00:00:04 crond
298      15955     1  0  2016 ?        00:06:35 memcached -d -p 11211 -u memcached -m 64 -c 1024 -P /var/run/memcached/memcached.pid
apache   15967 15237  1 19:13 ?        00:02:45 /usr/sbin/httpd
apache   16615 15237  1 19:13 ?        00:02:45 /usr/sbin/httpd
apache   16837 15237  1 19:13 ?        00:02:44 /usr/sbin/httpd
postfix  18475 19914  0 21:29 ?        00:00:00 pickup -l -t fifo -u
rpc      19773     1  0  2016 ?        00:00:10 rpcbind -w
root     19914     1  0  2016 ?        00:04:19 /usr/libexec/postfix/master
postfix  19917 19914  0  2016 ?        00:02:40 qmgr -l -t fifo -u
root     19966     1  0  2016 ?        00:18:06 auditd
ntp      20029     1  0  2016 ?        00:08:44 ntpd -x -u ntp:ntp -p /var/run/ntpd.pid
root     20059     1  0  2016 ?        00:00:00 /usr/sbin/oddjobd -p /var/run/oddjobd.pid -t 300
root     20230     1  0  2016 ?        00:00:00 /sbin/portreserve
root     20274     1  0  2016 ?        00:00:11 /usr/sbin/atd
root     20579     1  0  2016 ?        00:00:13 /usr/sbin/abrtd
root     20599     1  0  2016 ?        00:09:04 abrt-dump-oops -d /var/spool/abrt -rwx /var/log/messages
root     22233     1  0  2016 ?        00:17:18 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
nagios   23392     1  0 19:20 ?        00:00:24 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   23395 23392  0 19:20 ?        00:00:02 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   23396 23392  0 19:20 ?        00:00:02 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   23397 23392  0 19:20 ?        00:00:02 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   23398 23392  0 19:20 ?        00:00:02 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   23427 23392  0 19:20 ?        00:00:01 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     24214     1  0  2016 ?        1-05:41:49 /usr/local/tripwire/te/agent/bin/../sup/rtm/tesvc -port 1169
root     24285     1  0  2016 ?        03:30:53 ./wrapper ./agent.conf wrapper.pidfile=../tmp/teagent.pid wrapper.daemonize=TRUE
root     24290 24285  0  2016 ?        07:45:32 /usr/local/tripwire/te/agent/jre/bin/java -da -server -Dtw.server=false -Djava.security.manager=com.tripwire.kernel.ext.security.TripwireSecurityManager -Djava.security.properties=/usr/local/tripwire/te/agent/data/security/security.properties -Djava.se
root     24361 14541  0 16:09 ?        00:00:00 sshd: rardhani1 [priv]
502      24414 24361  0 16:09 ?        00:00:02 sshd: rardhani1@pts/0
502      24415 24414  0 16:09 pts/0    00:00:00 -bash
root     24989 24415  0 16:09 pts/0    00:00:00 sudo su -
root     24997 24989  0 16:09 pts/0    00:00:00 su -
root     25000 24997  0 16:09 pts/0    00:00:00 -bash
apache   25820 15237  1 19:23 ?        00:02:34 /usr/sbin/httpd
root     27941     1  0  2016 ?        01:09:15 /usr/local/bin/python bin/carbon-cache.py --instance=a start
root     29682     1  0  2016 ?        03:42:33 python /usr/bin/goferd
apache   32237 15237  1 21:10 ?        00:00:58 /usr/sbin/httpd
total 3440
drwxr-xr-x. 2 nagios nagios   12288 Jan  3 23:59 archives
-rw-r--r--. 1 nagios nagios    1050 Jan  4 22:22 host-perfdata
-rwxr-xr-x. 1 nagios nagios    1124 Jan  4 19:20 nagios.configtest
-rwxr-xr-x. 1 nagios nagios       6 Jan  4 19:20 nagios.lock
-rwxr-xr-x. 1 nagios nagios 1073565 Jan  4 22:21 nagios.log
-rw-r--r--. 1 nagios nagios       5 Jan  4 22:20 ndo2db.lock
srwxr-xr-x. 1 nagios nagios       0 Jan  4 22:20 ndo.sock
-rwxr-xr-x. 1 nagios nagios   27637 Jan  4 19:12 npcd.log
-rwxr-xr-x. 1 nagios nagios  469504 Jan  4 19:20 objects.cache
-rwxr-xr-x. 1 nagios nagios  469504 Jan  4 19:20 objects.precache
-rwxr-xr-x. 1 nagios nagios   24240 Dec 20 09:02 perfdata.log
-rw-------. 1 nagios nagios  693524 Jan  4 22:20 retention.dat
drwxr-sr-x. 2 nagios nagcmd    4096 Jan  4 19:20 rw
-rw-r--r--. 1 nagios nagios    7375 Jan  4 22:22 service-perfdata
drwxr-xr-x. 5 nagios nagios    4096 Jun 15  2016 spool
drwxr-xr-x. 2 nagios nagios    4096 Jan  4 22:21 stats
-rw-rw-r--. 1 nagios nagios  692681 Jan  4 22:21 status.dat
total 4
-rw-r--r--. 1 root   root   0 Jan  4 19:20 nagios
-rw-r--r--. 1 nagios nagios 0 Jan  4 22:20 ndo2db
-rw-r--r--. 1 root   root   5 Jan  4 19:12 npcd.pid
Post by dwhitfield »
That thread you link is a few pages long. Could you clarify a bit exactly what you did?
Also, can you post your upgrade.log?
raamardhani7
dwhitfield wrote:That thread you link is a few pages long. Could you clarify a bit exactly what you did?
I've followed the same document that is given for upgradation and tried the same steps. Post upgradation I a could see the Database Backend is in stopped state. attaching the update.log file.
It looks like you were trying to upgrade from 5.3.1. Can you upgrade to 5.3.4 first and then 5.4.0? That will help us determine if there is a bug in our 5.4 upgrade scripts. You can find 5.3.4 available at https://assets.nagios.com/downloads/nag ... 3.4.tar.gz
raamardhani7
dwhitfield wrote:It looks like you were trying to upgrade from 5.3.1. Can you upgrade to 5.3.4 first and then 5.4.0? That will help us determine if there is a bug in our 5.4 upgrade scripts. You can find 5.3.4 available at https://assets.nagios.com/downloads/nag ... 3.4.tar.gz
Thank you so much for your quick response. this is now sorted. I have upgraded to the version you asked me to and then upgraded it to the latest version. looks like everything is working fine. thanks.
gselvakumar
I have upgraded to the version you asked me to and then upgraded it to the latest version but I am still getting "Database Backend Is Not Running" :cry:
Thanks & Regards,
What's the output of ll /usr/lib/systemd?
Also, it looks like the OP never posted an upgrade.log. Could you do that? Thanks!
raamardhani7
dwhitfield wrote:What's the output of ll /usr/lib/systemd?
Hi
Please find the update.
ll /usr/lib/systemd
total 4
drwxr-xr-x. 2 root root 4096 Sep 26 07:16 system
Reason: removing profile for security purposes
