https://assets.nagios.com/downloads/nag ... ios_XI.pdf
Then blank out your /etc/snmp/snmptt.conf file and then run the addmib command against your MIBs:
addmib /usr/share/snmp/mibs/YOURMIBFILE
addmib /usr/share/snmp/mibs/YOUROTHERMIBFILECode: Select all
service snmptt restart--
I'll include this additional information here to help you out:
This is the general flow of how SNMP traps work:
Device -> Nagios Server -> snmptrapd -> snmptt -> Nagios Service
Here's how it works in greater detail:
1. The device sends a SNMP trap with say an OID of .1.3.6.1.6.3.1.1.5.1 to the Nagios XI server.
2. The snmptrapd service receives the trap and then runs the default handler for traps (in this case SNMPTT)
- Taken from /etc/snmp/snmptrapd.conf
traphandle default /usr/sbin/snmptthandler4. SNMPTT doesn't know anything about the traps in your MIB files, the MIB files on the system are just used for translation from .1.3.6.1.6.3.1.1.5.1 into coldStart. You need to process the MIB file that contains your traps to get them into the /etc/snmp/snmptt.conf file which SNMPTT reads to match against to see if it should do anything with it (.1.3.6.1.6.3.1.1.5.1).
5. Since you've run addmib on the MIB file containing your traps (in this case /usr/share/snmp/mibs/SNMPv2-MIB.txt) it processes the trap and puts it into a format SNMPTT understands and changes the EXEC line (see below) to execute the snmptraphandling.py script (that's what puts it into Nagios).
EVENT coldStart .1.3.6.1.6.3.1.1.5.1 "Status Events" Normal
FORMAT A coldStart trap signifies that the SNMP entity, $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "A coldStart trap signifies that the SNMP entity, $*"
SDESC
supporting a notification originator application, is
reinitializing itself and that its configuration may
have been altered.
Variables:
EDESCYou can read more about SNMPTT and what those lines mean (and how you can change them if you want) here:
http://snmptt.sourceforge.net/docs/snmptt.shtml
Please see here for advanced reading:
https://support.nagios.com/kb/article.php?id=232
https://support.nagios.com/kb/article.php?id=559
https://support.nagios.com/kb/article.php?id=77
https://support.nagios.com/kb/article.php?id=493
https://support.nagios.com/kb/article.php?id=558
Thank you
