Here is my complete nsclient config file and it still does not work:
# If you want to fill this file with all available options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Section for NSClient (NSClientServer.dll) (check_nt) protocol options.
[/settings/NSClient/server]
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
use ssl = 0
; PERFORMANCE DATA - Send performance data back to Nagios (set this to 0 to remove all performance data).
performance data = 1
; PORT NUMBER - Port to use for check_nt.
port = 12489
; TODO
[/settings/default]
; Undocumented key
password = FPRi5c9ZQmCCOZll
; Undocumented key
allowed hosts = 10.1.13.143
; TODO
[/settings/NRPE/server]
port = 12489
; Undocumented key
ssl options = no-sslv2,no-sslv3
; Undocumented key
verify mode = peer-cert
; Undocumented key
insecure = false
; TODO
[/modules]
NSClientServer = 1
; Undocumented key
CheckExternalScripts = 1
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NRPEServer = 1
And scrrenshoot of Nagios is included
not able to monitor windows 2008 server
jtintegration
Re: not able to monitor windows 2008 server
I'm not sure why your NRPE is running on port 12489. Change this to 5666. Then restart the service, they're probably fighting for who gets to listen.
After doing so, try again. If that doesn't work, post your config + the nsclient log file once again.
; TODO
port = 12489
jtintegration
It still does not work when I changed the port to 5666. Please take a look at the screenshot of nsclient.ini and screenshoot of nagios ofr those windows services.
use ssl = 0
port = 5666
; TODO
[/settings/default]
; Undocumented key
; Undocumented key
; TODO
port = 12489
; Undocumented key
; Undocumented key
; Undocumented key
insecure = false
; TODO
[/modules]
NSClientServer = 1
; Undocumented key
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NRPEServer = 1
use ssl = 0
port = 5666
; TODO
[/settings/default]
; Undocumented key
; Undocumented key
; TODO
port = 12489
; Undocumented key
; Undocumented key
; Undocumented key
insecure = false
; TODO
[/modules]
NSClientServer = 1
; Undocumented key
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NRPEServer = 1
You changed the wrong part. NSClient runs on 12489, and NRPE on 5666. See above.rkennedy wrote:I'm not sure why your NRPE is running on port 12489. Change this to 5666. Then restart the service, they're probably fighting for who gets to listen.After doing so, try again. If that doesn't work, post your config + the nsclient log file once again.Code: Select all
; TODO [/settings/NRPE/server] ; PORT NUMBER - Port to use for check_nt. port = 12489
jtintegration
I am still having problem with monitoring my Windows 2008 with NSClient. Can someone help? thanks
jtintegration wrote:I am still having problem with monitoring my Windows 2008 with NSClient. Can someone help? thanks
You are not following directions on what should be changed, so it's hard to say what the problem is at this point. I would review the following documents as they btoh contain quite a bit of good information for teaching you about how to configure NSClient++ with NRPE -rkennedy wrote:You changed the wrong part. NSClient runs on 12489, and NRPE on 5666. See above.rkennedy wrote:I'm not sure why your NRPE is running on port 12489. Change this to 5666. Then restart the service, they're probably fighting for who gets to listen.After doing so, try again. If that doesn't work, post your config + the nsclient log file once again.Code: Select all
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
