not able to monitor windows 2008 server
jtintegration
Post by jtintegration »
I am running Nagios XI 5.2.3, installed the NSClient ++ on the server. Within Confguration Wizard of Nagios, I select Windows Server (disk space, process, etc) Everything failed except Ping. I am not sure why it is not picking up other monitors except Ping. I am not sure what I am missing. thanks in advance
Re: not able to monitor windows 2008 server
Can you show us the message that is being reported for the failed services?
Also, from the Windows machine, what is the output of these commands?
netstat -na | findstr 12489
netstat -na | findstr 5666
jtintegration
here are the output from server
It looks like NSClientServer isn't turned on, just NRPE. If you used the default wizard, that would explain it. Please post your NSClient++ configuration file for us to review. (usually nscslient.ini)
jtintegration
I do not see NSCLIENTSERVER service within Windows 2008 Server. Here is the nsclient.ini
Add these parts to your configuration file under the respected section (might already exist, but I know the [/settings/NSClient/server] one isn't) -
[/settings/default]
password = FPRi5c9ZQmCCOZll
[/modules]
NSClientServer = 1
; PORT NUMBER - Port to use for check_nt.
port = 12489
then, restart the NSClient++ service. (nscp)
If you have further issues, this file is a good reference - https://assets.nagios.com/downloads/nag ... ios-XI.pdf
jtintegration
It is still not working, please see screenshoot of nagios and ssh seesion from Nagios server. I also included the nsclient.ini. After made changes to the ini file, I did restart the Nsclient service.
Here is the ini file:
# If you want to fill this file with all available options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; TODO
[/settings/default]
; Undocumented key
; Undocumented key
allowed hosts = 172.0.0.1,::1
; TODO
[/settings/NRPE/server]
port = 12489
; Undocumented key
ssl options = no-sslv2,no-sslv3
; Undocumented key
verify mode = peer-cert
; Undocumented key
insecure = false
; TODO
[/modules]
NSClientServer = 1
; Undocumented key
CheckExternalScripts = 1
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NRPEServer = 1
; Undocumented key
Is 172.0.0.1 the IP of the Nagios machine? Otherwise, you may need to adjust this, and then restart the nscp service. From there, I check out the nsclient.log to see if it's showing any indication as to what's going on.
jtintegration
I changed the ip address to the Nagios server but still getting following message on the nsclientl log file:
2017-02-13 12:20:20: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:24:21: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:24:35: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:25:18: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:29:18: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:29:32: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:30:17: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:34:16: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:34:30: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:35:16: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:39:15: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:39:29: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:40:14: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:44:13: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:44:28: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:45:10: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:49:12: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:49:26: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:50:10: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:54:10: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:54:24: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:55:08: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:59:08: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 12:59:22: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:00:05: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:04:07: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:04:21: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:05:04: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:09:04: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:09:18: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:10:01: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:14:03: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:14:16: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:15:00: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:19:01: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:19:15: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:19:58: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:23:59: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:24:13: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:24:56: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:28:57: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:29:12: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:29:53: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:33:55: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:34:10: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:34:53: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:38:53: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:39:09: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:39:52: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:43:53: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:44:08: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:44:51: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:48:50: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:49:06: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
2017-02-13 13:49:49: error:c:\source\master\include\socket/connection.hpp:257: Failed to establish secure connection: short read: 219
Try adding the following to the nsclient.ini file and restart the service and see if that fixes the checks that are failing.
; Section for NSClient (NSClientServer.dll) (check_nt) protocol options.
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
use ssl = 0
; PERFORMANCE DATA - Send performance data back to Nagios (set this to 0 to remove all performance data).
performance data = 1
port = 12489
