Error while configuring Linux snmp wizard
Re: Error while configuring Linux snmp wizard
Post by dwhitfield »
What's the output of sudo find / -name snmpd.conf?
For clarity, did you use https://assets.nagios.com/downloads/nag ... g_SNMP.pdf for setting this up?
Frédéric GRANAT
Post by Frédéric GRANAT »
=> No, I thought snmp was installed on the remote machine
I found snmpd.conf (attached).
It looks like you did not perform the step of editing the snmpd.conf listed on page 2 of https://assets.nagios.com/downloads/nag ... g_SNMP.pdf
Based on the fact that you are not using the documentation, you may also need to run sudo apt-get install libsnmp-dev
Frédéric GRANAT
I performed the steps of page 2 and sudo apt-get install libsnmp-dev :
[root@nagiosxi libexec]# ./check_snmp_storage.pl -H 172.16.1.19 -C Str0ngC0mmunity -m "^/$" -w 2 -c 4
ERROR: Description/Type table : No response from remote host '172.16.1.19'.
What's the output of the following?
From Ubuntu
ps -A | grep snmp
From Nagios
telnet 172.16.1.19 161
Also, you changed community strings in your examples. Was that intentional?
Frédéric GRANAT
libriciel@iparapheurtestcd04:~$ ps -A | grep snmp
24306 ?        00:01:48 snmpd
[root@nagiosxi ~]# telnet 172.16.1.19 161
-bash: telnet: command not found
=> Please tell me which example
./check_snmp_storage.pl -H 172.16.1.19 -C Str0ngC0mmunity -m "^/$" -w 2 -c 4 vs. snmpwalk -v 1 -c public 172.16.1.19
Looks like you need to run yum install telnet and then telnet 172.16.1.19 161
Frédéric GRANAT
Str0ngC0mmunity is the community described in the document you told me to apply (Nagios XI – Monitoring Linux Using SNMP)
I applied the changes described in that document (p.2 and 3).
Do you think it's a wrong value ?
./check_snmp_storage.pl -H 172.16.1.19 -C Str0ngC0mmunity -m "^/$" -w 2 -c 4 is the command given in the same document to test snmp (p.6)
Trying 172.16.1.19...
telnet: connect to address 172.16.1.19: Connection refused
Str0ngC0mmunity is just an example we use in our documentation. You will need to be sure to change this to the community string your device is configured to use.
Frédéric GRANAT
=> I don't know what's the community my device is configured to use, where can I find it ?
