Hi
Try nmap -sU localhost -p 161
=> On which machine (Nagios or monitored server).
If you want to PM the snmp.conf rather than posting it here, that is fine. Just make sure you update the thread some it comes back on our support dashboard.
=> As I said : on remote host, /etc doesn't contain snmp directory (so, no snmp.conf)
On nagios server :
[root@nagiosxi ~]# snmpwalk -v 1 -c public 172.16.1.19
Timeout: No Response from 172.16.1.19
You have mail in /var/spool/mail/root
On monitored server :
libriciel@iparapheurtestcd04:~$ systemctl restart snmpd
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to restart 'snmpd.service'.
Authenticating as: libriciel,,, (libriciel)
Password:
==== AUTHENTICATION COMPLETE ===
Failed to restart snmpd.service: Unit snmpd.service not found.
Then
libriciel@iparapheurtestcd04:~$ sudo apt-get update
[sudo] password for libriciel:
Atteint:1 http://fr.archive.ubuntu.com/ubuntu xenial InRelease
Réception de:2 http://security.ubuntu.com/ubuntu xenial-security InRelease [102 kB]
Réception de:3 http://fr.archive.ubuntu.com/ubuntu xenial-updates InRelease [102 kB]
Réception de:4 http://fr.archive.ubuntu.com/ubuntu xenial-backports InRelease [102 kB]
Réception de:5 http://security.ubuntu.com/ubuntu xenial-security/main amd64 Packages [219 kB]
Réception de:6 http://fr.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages [485 kB]
Réception de:7 http://security.ubuntu.com/ubuntu xenial-security/main i386 Packages [212 kB]
Réception de:8 http://fr.archive.ubuntu.com/ubuntu xenial-updates/main i386 Packages [475 kB]
Réception de:9 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 Packages [79,1 kB]
Réception de:10 http://security.ubuntu.com/ubuntu xenial-security/universe i386 Packages [74,1 kB]
Réception de:11 http://security.ubuntu.com/ubuntu xenial-security/universe Translation-en [43,9 kB]
Réception de:12 http://fr.archive.ubuntu.com/ubuntu xenial-updates/main Translation-en [193 kB]
Réception de:13 http://fr.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages [411 kB]
Réception de:14 http://fr.archive.ubuntu.com/ubuntu xenial-updates/universe i386 Packages [405 kB]
Réception de:15 http://fr.archive.ubuntu.com/ubuntu xenial-updates/universe Translation-en [155 kB]
3 058 ko réceptionnés en 1s (1 682 ko/s)
Lecture des listes de paquets... Fait
libriciel@iparapheurtestcd04:~$ sudo apt-get install snmpd
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Les paquets suivants ont été installés automatiquement et ne sont plus nécessaires :
linux-headers-4.4.0-31 linux-headers-4.4.0-31-generic linux-headers-4.4.0-62
linux-headers-4.4.0-62-generic linux-image-4.4.0-31-generic
linux-image-4.4.0-62-generic linux-image-extra-4.4.0-31-generic
linux-image-extra-4.4.0-62-generic
Veuillez utiliser « sudo apt autoremove » pour les supprimer.
The following additional packages will be installed:
libsensors4 libsnmp-base libsnmp30
Paquets suggérés :
lm-sensors snmp-mibs-downloader snmptrapd
Les NOUVEAUX paquets suivants seront installés :
libsensors4 libsnmp-base libsnmp30 snmpd
0 mis à jour, 4 nouvellement installés, 0 à enlever et 28 non mis à jour.
Il est nécessaire de prendre 1 123 ko dans les archives.
Après cette opération, 4 378 ko d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer ? [O/n] O
Réception de:1 http://fr.archive.ubuntu.com/ubuntu xenial/main amd64 libsensors4 amd64 1:3.4.0-2 [28,4 kB]
Réception de:2 http://fr.archive.ubuntu.com/ubuntu xenial/main amd64 libsnmp-base all 5.7.3+dfsg-1ubuntu4 [224 kB]
Réception de:3 http://fr.archive.ubuntu.com/ubuntu xenial/main amd64 libsnmp30 amd64 5.7.3+dfsg-1ubuntu4 [813 kB]
Réception de:4 http://fr.archive.ubuntu.com/ubuntu xenial/main amd64 snmpd amd64 5.7.3+dfsg-1ubuntu4 [57,1 kB]
1 123 ko réceptionnés en 0s (2 759 ko/s)
Préconfiguration des paquets...
Sélection du paquet libsensors4:amd64 précédemment désélectionné.
(Lecture de la base de données... 199269 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../libsensors4_1%3a3.4.0-2_amd64.deb ...
Dépaquetage de libsensors4:amd64 (1:3.4.0-2) ...
Sélection du paquet libsnmp-base précédemment désélectionné.
Préparation du dépaquetage de .../libsnmp-base_5.7.3+dfsg-1ubuntu4_all.deb ...
Dépaquetage de libsnmp-base (5.7.3+dfsg-1ubuntu4) ...
Sélection du paquet libsnmp30:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../libsnmp30_5.7.3+dfsg-1ubuntu4_amd64.deb ...
Dépaquetage de libsnmp30:amd64 (5.7.3+dfsg-1ubuntu4) ...
Sélection du paquet snmpd précédemment désélectionné.
Préparation du dépaquetage de .../snmpd_5.7.3+dfsg-1ubuntu4_amd64.deb ...
Dépaquetage de snmpd (5.7.3+dfsg-1ubuntu4) ...
Traitement des actions différées (« triggers ») pour man-db (2.7.5-1) ...
Traitement des actions différées (« triggers ») pour libc-bin (2.23-0ubuntu5) ...
Traitement des actions différées (« triggers ») pour systemd (229-4ubuntu16) ...
Traitement des actions différées (« triggers ») pour ureadahead (0.100.0-19) ...
Paramétrage de libsensors4:amd64 (1:3.4.0-2) ...
Paramétrage de libsnmp-base (5.7.3+dfsg-1ubuntu4) ...
Paramétrage de libsnmp30:amd64 (5.7.3+dfsg-1ubuntu4) ...
Paramétrage de snmpd (5.7.3+dfsg-1ubuntu4) ...
adduser: Warning: The home directory `/var/lib/snmp' does not belong to the user you are currently creating.
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
update-rc.d: warning: stop runlevel arguments (1) do not match snmpd Default-Stop values (0 1 6)
insserv: warning: script 'K01alfresco' missing LSB tags and overrides
insserv: warning: script 'alfresco' missing LSB tags and overrides
