Host is not scheduled to be checked...
Re: Host is not scheduled to be checked...
The configs should work for you. Since the service check is a passive check, disabling Active Checks is what you need to do.
Check these out for more of an explanation -
https://assets.nagios.com/downloads/nag ... hecks.html
Both help explain it pretty well. If you still have issues post your objects.cache which will show the configuration files after templates have been applied.
Thanks for the assist, @rkennedy!
