Host is not scheduled to be checked...
neel5481
Post by neel5481 »
I am using cent OS 7 with nagios 4.0.8.
I am always getting host status as "Pending" with status information saying "Host is not scheduled to be checked... ".
Below are my hosts.cfg and services.cfg file content.
hosts.cfg
define host {
host_name MyLocalHost
address 127.0.0.1
use generic-host
active_checks_enabled 0
passive_checks_enabled 1
flap_detection_enabled 0
max_check_attempts 10
services.cfg
service_description MyService
check_command check_ping!3000.0,80%!5000.0,100%
check_freshness 0
contact_groups admins
I have added this file entry in nagios.cfg file under "cfg_file" as below.
cfg_file=/usr/local/nagios/etc/objects/hosts.cfg
cfg_file=/usr/local/nagios/etc/objects/services.cfg
Can you please suggest how to make host "Up" ?
Thanks in Advance.
Re: Host is not scheduled to be checked...
In your host.cfg and service.cfg file, you have the disabled the active checks which will stop the check from running.
Since it is disabled, the active check will never run, and that is causing the message you are seeing.
Edit both the service and host configuration files and change the following from
to
active_checks_enabled 1
Also, in the hosts.cfg file, you do not have an active check defined, add the following check command to that host.cfg file.
check_command                   check-host-alive
Save the files and restart the nagios daemon and that should schedule the active checks to start to run for both the host and service checks.
Take a look at this link for the details on active checks.
https://assets.nagios.com/downloads/nag ... hecks.html
neel5481
Post by neel5481 »
Thank you for your quick reply.
Host is up now with your suggestion. I have made same changes to services.cfg file but on main "Services" page status shows "Pending" but when we click on that service then it display correct current status. Any reason for this ?
My services.cfg file looks as below after your suggestion.
check_freshness 0
It could of taken a few minutes to update the Main services screen due to the refresh rate on the menu that could of caused the delay.
If you go back, does it still show pending?
Try clearing your browsers cache and see if that helps out as well.
neel5481
Post by neel5481 »
I have tried as per your suggestion regarding clear the cache and waited for half an hour but service status always shows "OK" on main services page.
I am suspecting something wring with 'check_command' in services.cfg file. What should be 'check_command' in services.cfg file ? Is "check_ping" ok ?
Is there anything i need to add in services.cfg file ? Any pointer how to debug this ?
neel5481
Post by neel5481 »
I was debugging and found the log of "nagios.log" and below is the error.
[1490857367] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MyHost;MyService;2;Level increased (threshold values: {1,2,3}, current value: 316) (new State: HIGH , old State: LOW)
[1490857367] Warning: Passive check result was received for service 'MyService' on host 'MyHost', but the service could not be found!
[1490857367] Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;MyHost;MyService;2;Level increased (threshold values: {1,2,3}, current value: 316) (new State: HIGH , old State: LOW)
[1490857367] External command error: Command failed
I was suspecting the issue with permissions but permission seems to be correct as below. Let me know if anything is missing.
[neel@localhost nagios]$ ls -l /usr/local/nagios/var/
total 124
drwxrwxr-x. 2 nagios nagios 6 Mar 29 11:55 archives
-rw-r--r--. 1 nagios nagios 196 Mar 30 12:31 nagios.configtest
-rw-r--r--. 1 nagios nagios 6 Mar 30 12:31 nagios.lock
-rw-r--r--. 1 nagios nagios 48698 Mar 30 12:32 nagios.log
-rw-r--r--. 1 nagios nagios 14363 Mar 30 12:31 objects.cache
-rw-r--r--. 1 nagios nagios 14363 Mar 30 12:31 objects.precache
-rw-------. 1 nagios nagios 15824 Mar 30 12:31 retention.dat
drwxrwsr-x. 2 nagios nagcmd 39 Mar 30 12:31 rw
drwxr-xr-x. 3 root root 25 Mar 29 11:55 spool
-rw-rw-r--. 1 nagios nagios 16153 Mar 30 12:41 status.dat
Just for your reference, I followed below link to setup nagios 4 on CentOS 7.
https://www.unixmen.com/install-configu ... -centos-7/
Any idea why command is getting failed ?
In your previous post, your service check called MyService has this host name called MyLocalHost but your messages from the nagios.log the host is called MyHost.
Are they the same host or are they different?
If they are different, you will have to create service configuration for that host/service and this message from the log
is stating that the check is a passive check but there is not a definition of that check in Nagios causing the warning.
Take a look at this link for more details on passive checks in Nagios.
The External command failed message, we would have to see how the following command is defined on your system.
neel5481
Post by neel5481 »
Sorry it was log copy/paste issue. The host is same as "MyLocalHost" not "MyHost".
We are using the command as below.
[<timestamp>] PROCESS_SERVICE_CHECK_RESULT;<host_name>;<service_name>;<code>;<status_text>
[1490857367] PROCESS_SERVICE_CHECK_RESULT;MyLocalHost;MyService;2;Level increased (threshold values: {1,2,3}, current value: 316) (new State: HIGH , old State: LOW)
Here Code will be 0,1,2 which represent the status as OK,WARNING, CRITICAL like that and 'status_text' will be message displayed in last column of "Status Information".
Do you want to monitor the MyLocalHost system with an active check or a passive check?
If you want to do it passively, you will have to disable the active checks and replace the active check command with your passive check command.
I will need to see how the command
is defined in your commands.cfg file to help out on the External command error: Command failed error.
neel5481
Post by neel5481 »
Everything works fine after disabling active check in services.cfg file.
Final hosts.cfg and services.cfg file will be as below.
define host {
address 127.0.0.1
use generic-host
check_freshness 0
Are above configurations fine or is there any problem in future ?
Thanks in Advance.
