What is the name of the host?
Also, please provide the output of the following:
# date
# hwclock
# grep date.timezone /etc/php.ini
# mysql -unagiosxi -pn@gweb -e "SELECT NOW();"
# service ntpd status
# df -i
# df -h
Regarding the instructions below, if you do not have killall, you can install it via the following command:
# yum install psmisc
If psmisc is not in your repos, then instead you can check to make sure nagios is not running with
# ps -aef | grep nagios
If that document does not resolve your issue, please run the following commands in order and report any errors. You ***must*** use mariadb instead of mysqld in the commands below, ***if*** you have mariadb.
# service nagios stop
# service ndo2db stop
# service mysqld stop
# service crond stop
# service httpd stop
# killall -9 nagios
# killall -9 ndo2db
# rm -rf /usr/local/nagios/var/rw/nagios.cmd
# rm -rf /usr/local/nagios/var/nagios.lock
# rm -f /usr/local/nagios/var/ndo.sock
# rm -f /usr/local/nagios/var/ndo2db.lock
# rm -f /usr/local/nagiosxi/var/reconfigure_nagios.lock
# for i in `ipcs -q | grep nagios |awk '{print $2}'`; do ipcrm -q $i; done
# service ndo2db start
# service nagios start
# service mysqld start
# service crond start
# service httpd start
Also, can you post a screenshot of http://YOURSERVER/nagiosxi/admin/globalconfig.php
Force Check not working for host
- Former Nagios Staff
Re: Force Check not working for host
I tried running through command steps outlined to restart/clear out lock files but still not working. This is strange that issue is only with this particular host. I have tried to re-add the host but it still did not work. What exactly is the host check attempting to do? ICMP poll ? Below is the output of the commands requested I run:
# date
Wed Jun 7 20:02:03 GMT 2017
# hwclock
Wed 07 Jun 2017 08:02:06 PM GMT -0.677835 seconds
; http://www.php.net/manual/en/datetime.c ... e.timezone
date.timezone = Africa/Monrovia
| NOW() |
| 2017-06-07 20:02:53 |
ntpd (pid 2092) is running...
# date
# hwclock
| NOW() |
# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/mapper/VolGroup00-LogVol00
327680 12715 314965 4% /
tmpfs 2035305 1 2035304 1% /dev/shm
/dev/sda3 65536 51 65485 1% /boot
/dev/mapper/VolGroup00-LogVol02
1310720 37 1310683 1% /home
/dev/mapper/VolGroup00-LogVol06
1310720 24336 1286384 2% /opt
/dev/mapper/VolGroup00-LogVol07
2621440 21 2621419 1% /store
/dev/mapper/VolGroup00-LogVol03
327680 1077 326603 1% /tmp
/dev/mapper/VolGroup00-LogVol04
5898240 113359 5784881 2% /usr
/dev/mapper/VolGroup00-LogVol05
2621440 4913 2616527 1% /var
rkpe4fanr002:/vol/Patches_Linux_new
3112959 77576 3035383 3% /REPOS
rkpe4fanr002:/vol/OpsPatchRepoL
6225917 169928 6055989 3% /REPOS_OPSCode: Select all
# df -h
4.8G 537M 4.1G 12% /
tmpfs 7.8G 0 7.8G 0% /dev/shm
/dev/sda3 976M 95M 830M 11% /boot
20G 45M 19G 1% /home
20G 2.2G 17G 12% /opt
40G 1.4G 36G 4% /store
4.8G 54M 4.5G 2% /tmp
89G 4.3G 80G 6% /usr
40G 2.3G 36G 6% /var
100G 73G 28G 73% /REPOS
200G 101G 100G 51% /REPOS_OPS
Reason: code blocks FTW
ksafa, what is the name of the "problem" host?
ksafa, can we lock this thread as the issue has been resolved (in PM)? Thanks!
