Downgrade Nagios XI
sandeepatil
Re: Downgrade Nagios XI
Post by sandeepatil »
Ohh..
No need to format the system, only run uninstall ---> install previous version ---> restore db. right ?
Post by dwhitfield »
If you started with a clean system when you installed the initial XI, then uninstall, install, restore should be all you need to do.
Any modifications to a default CentOS/RHEL system such as turning on SELinux, will likely cause the install to fail. Of course, if you have someone that knows how to set SELinux policy, it can be done, but that is not something we will help you with.
sandeepatil
Got it.. !
Thanks for support...
A point of clarification. It's possible one version, say 5.3.x could install properly with some modification, but then 5.4.x will fail. We test against clean systems, but various command line tools such as psmisc are not going cause problems. Anything that touches Apache or MySQL are the real no-go zone, but because we can't possibly know every application that might touch Apache or MySQL, we just say "clean".
Let us know if you run into any trouble!
sandeepatil
Understood ....
Let us know if you have any other questions on this or if we can close and lock the post for you.
sandeepatil
You can close this post.
Thanks for sharing valuable information.
