How to complete installing a plugin from Nagios Exchange
Re: How to complete installing a plugin from Nagios Exchange
Can you post the Nagios configuration file for that server so we can view it?
It looks like the service check is missing for the Exchange check.
I uploaded nagios.cfg file. Kindly help me check. Thanks.
nagios.cfg- (43.78 KiB) Downloaded 438 times
That's the main Nagios configuration file. We need to see the config file for the specific server that you are trying to monitor.
If i understood you, that is NSClient++ which i installed on Exchange Server. See nsclient.ini as attached file.
Kindly feedback again if i was wrong. Thank you!
nsclient.ini- (7.34 KiB) Downloaded 427 times
Did you place your PS script in "C:\NagiosMonitoring\"? Usually, scripts are placed in the "C:\Program Files\NSClient++\scripts" directory. Try moving your script there, then change your command from this:
to this:
and restart the NSClient++ service.
Test it by running the following command from the command line on the Nagios XI server:
If you are still having issues, load all of the "defaults" in the nsclient.ini file by running the following in the CMD Prompt on the Windows machine as administrator:
Next, upload the updated nsclient.ini file on the forum. We may need to tweak some of the settings in there.
LyncFrontendServicesCheck=cmd /c echo C:\NagiosMonitoring\NagiosMonitoring_Exchange2016_Services.ps1 | PowerShell.exe -Command -Code: Select all
LyncFrontendServicesCheck=cmd /c echo scripts\NagiosMonitoring_Exchange2016_Services.ps1; exit $LastExitCode | powershell.exe -command -Test it by running the following command from the command line on the Nagios XI server:
/usr/local/nagios/libexec/check_nrpe -H <client ip> -c LyncFrontendServicesCheckCode: Select all
cd "C:\Program Files\NSClient++"
nscp settings --generate --add-defaults --load-allBe sure to check out our Knowledgebase for helpful articles and solutions!
I followed up your instruction steps and here is report. Hope you find the problem. Thanks
1) Output command
By the way, Anyone share me the photo of final result if there is sucesfulled configure.
1) Output command
2) Output command "nscp settings --generate --add-defaults --load-all"Service OK: All services are up and running
3) See newest nsclient.ini as attached.C:\Program Files\NSClient++>nscp settings --generate --add-defaults --load-all
l scripts\commands.hpp:100 Failed to parse arguments for command 'LyncFrontendS
ervicesCheck', using old split string method: unknown escape sequence: cmd /c ec
Adding default values
nsclient.ini- (22.12 KiB) Downloaded 444 times
Hi rafael,
If you're getting:
that means the plugin is up and running. Not sure why you're getting the parsing message but the config appears to be good and returning what you'd want now.
If you're getting:
Service OK: All services are up and runningAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Hi cdienger,
Now, I'd like to look the results/achieves. Where can i find it ? What's all Exchange services state information ? I could only view like photo below.
Any one can show me the result sample ? And where can i find it on my Nagios ?
Thanks.
Thanks.
The script will return a result like this if all services are up and running:
To see the results you must create config for this check Under Configure > CCM > Services. For example:
