Nagios web interface is running only on some computers
bolson
Re: Nagios web interface is running only on some computers
I'll let you know next steps as soon as possible.
From the same host I uploaded by virtualbox a machine with parrot os, result is that I can see without problems nagios in parrot os while in the physical machine windows 7 keeps appearing not runningbolson wrote:I'll let you know next steps as soon as possible.
https://image.ibb.co/hR9fXF/parrotwindows7.png
bolson
I know this seems unlikely, but is it possible that you have two separate installations of Nagios Core running?
I only have one running, anyway can you explain that on certain hosts I can view without problems and others not? I search and I search and I do not find anyone who has the same problembolson wrote:I know this seems unlikely, but is it possible that you have two separate installations of Nagios Core running?
bolson
This is the problem... we have never encountered your issue before. Please attach these two files:
/var/log/httpd/access_log
/var/log/httpd/error_log
And open this url in a web browser and send a screenshot:
http://192.168.2.239/nagios/cgi-bin/sta ... gramstatus
Also, clear the cache on the host which cannot connect and try again.
The file access_log I can not upload it should be by the size I will look for another method or if you want I can send it to the mail that you have in your signature foot I pay attention to your instructions, an additional fact is that on the host I can access without problems Navador chrome if I go to certificates in other people I get the certificate nagios.org in the same computer that I can enter I tried to enter with INTERNET EXPLORER and it says to me that it has not certified that page and it will not let me enter and I could not leave the same " Not running "on the other hand on the host that I can not enter that certificate is not in google chrome I tried to export it from the host that if I can enter, but I did it wrong or that is not the problem because it is still offline .. I hope you understand it That I tried to explainbolson wrote:This is the problem... we have never encountered your issue before. Please attach these two files:
In the browser that if I can enter I get that certificate the others do not have them, but even though I tried to import / export I still do not see
https://ibb.co/cajhxF
bolson
Is your Nagios Core installation running over https with SSL? If so, that may explain your issue.
bolson wrote:Is your Nagios Core installation running over https with SSL? If so, that may explain your issue.
Is not working with SSL, it was only information that I attached to the case
I sent the missing file to the nagios support mail in your signature.
bolson
Your Nagios Core installation may be faulty. You should be prompted for a username and password for the Web GUI. What method did you use to install Nagios Core? How many hosts and services do you have configured? How many simultaneous connections to the Nagios Core server do you typically have?
Nagios runs on centos 7 of 64, I have 53 host and 202 services. At first I connected in nagios by any computer in the network without problems now only can of informatica in the commune of "the counts" that use ip 192.168.1.xxx in the commune of hill where I am implementing only can connect one Comrade and only via google chrome no other browser can ip 192.168.2.xxx range and in the commune of "quilicura" the only computer there can not connect ip range 192.168.3.xxx, I did tests coming from other windows operating systems like Windows 10 and I can not, but with linux step without problems in any computer. Now I attach the 2 pages where I get information for the installation of nagiosbolson wrote:Your Nagios Core installation may be faulty. You should be prompted for a username and password for the Web GUI. What method did you use to install Nagios Core? How many hosts and services do you have configured? How many simultaneous connections to the Nagios Core server do you typically have?
https://www.sfinetworks.com/blog/index. ... -centos-7/
https://wiki.centos.org/es/HowTos/Nagios
I am so sorry, and thank you very much for the help you are giving me
