Hello, sorry for my english translator. I have a small problem with nagios which works without problems, but in the web interface in some computers not at all it is not possible to access the web interface in the home page shows not running and for example go to services Whoops Error: Could not Read object configuration data.
I explain: in the browser I have installed nagios http://192.168.x.xxx I see without problems deamon running whit pid xxxx, in the computer of my boss in the same network and other users also see it without problems, but in my computer Of windows I can not throw me is not running to another user it happens the same we use windows 7 everything, I do not know that in some computers I can see the web interface well and in others I can not
Nagios web interface is running only on some computers
bolson
Re: Nagios web interface is running only on some computers
Hello h4doukeeN, from your PC which can't access the web interface, are you able to ping the Nagios server?
Yes, server responds to pingbolson wrote:Hello h4doukeeN, from your PC which can't access the web interface, are you able to ping the Nagios server?
Extra information: I am working under a domain, it could be some configuration of active directory that does not let me enter with some users.
bolson
Just a hunch...
Can you run ipconfig /all from a PC that is able to access the Web GUI and from one that isn't?
Yes, I can run without problemsbolson wrote:Just a hunch...
bolson
I'm sorry, I meant to ask you to post the results of ipconfig /all from both Windows hosts.
bolson wrote:I'm sorry, I meant to ask you to post the results of ipconfig /all from both Windows hosts.
Tests performed on the same host but with different users (same ip proxy etc) supposedly checked active directory and ip permissions and both are identical
User 1:
https://ibb.co/h6ACwa
https://ibb.co/dkbkGa
User 2 with problems
https://ibb.co/ihWkGa
https://ibb.co/gcWkGa
bolson
Hello h4doukeeN, this will require some research. It's really not possible for what we're seeing here to be true. I'll talk it over with my team and let you know what we find out. Thank you for your patience.
bolson wrote:Hello h4doukeeN, this will require some research. It's really not possible for what we're seeing here to be true. I'll talk it over with my team and let you know what we find out. Thank you for your patience.
Ok, thank you very much for the help I will be attentive since I can not find the solution by any means
