Add more Host Groups Nagios
Re: Add more Host Groups Nagios
In the hostgroups file WSTEST1 is set as a member of the web-server hostgroup AND in the WSTEST1 host definition you are setting citrix-servers in the hostgroups directive
define hostgroup{
	hostgroup_name		web-servers		; The name of the hostgroup
	alias			web servers		; Long name of the group
	members			WSTEST1
define host {
  host_name WSTEST1
  use windows-server
  alias WSTEST1
  address 10.xx.xx.x
  hostgroups citrix-servers
  max_check_attempts 3
  check_period 24x7
  notification_interval 60
  notification_period 24x7
DiegoAnjos
Post by DiegoAnjos »
WSTEST1 is duplicated:
hostgroups.cfg:
It is set as member of web-servers:
define hostgroup{
	members			WSTEST1
And it on host definition the hostgroup is set as a citrix-servers member:
define host {
  host_name WSTEST1
  use windows-server
  alias WSTEST1
  address 10.xx.xx.x
  check_period 24x7
Remove the hostgroups citrix-servers on host definition.
Hope it helps!
kyang
Post by kyang »
Based on @scottwilkerson and @DiegoAnjos suggested. Check their suggestions in your host.cfg regarding the hostgroups citrix-servers
Let us know if you have any more questions.
michaelpn
Post by michaelpn »
hi,
do I get an answer soon:) ?
Sorry I solved it myself. Many thanks :) It helped me.
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
