Yes i know i need to modify the scripts check_alcatel_ports.pl to ignore the administrative down message for that particular interface or maybe oid
This is what i am trying to figure out
disable port using nagios core
Re: disable port using nagios core
We do offer custom development, and if that is a service you are interested in I can start that process for you so we can get a quote generated.
any ideas for this logic
L#186-L#219 is where I suspect the change would need to be made.DOkuwa wrote:I have the snmp oid which relates to the desired port on the alcatel devices that needs to be filtered out and don't know if this can be adjusted in the script
foreach my $port (sort keys %ports) {
my $name = $ports{$port}->[0];
my $desc = $ports{$port}->[4];
my $mode = $ports{$port}->[1];
my $admin = $ports{$port}->[2];
my $oper = $ports{$port}->[3];
my $port_state = $ports{$port}->[5];
# Skip if not network port
if ($mode != 2) {
next;
# Skip if admin down
elsif ($admin == 3) {
next;
# Skip if state is 'ghost' (port provisioned by not physically present)
elsif ($port_state == 2){
next;
# Alarm if oper down
elsif ($oper != 2) {
$error = 1;
$state = $ERRORS{'CRITICAL'};
$answer .= "[$desc OperStatus down] ";
next;
it has been sorted
just needed to add some modification to the check_alcatel_ports scripts
e.g if $name = "A/4 ")
next;
This skips any interface with name of A/4 which is the interface to be ignored
it has been sorted
next;
kyang
Sounds good! Are there any more questions or can we close this thread?
please close this thread but expecting answers from my other threads
very big thanks you
very big thanks you
kyang
Sounds good! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
