disable port using nagios core
I use Nagios Core and want a device not to show any status or information on a particular port of a device e.g port is down or interface is down
In other NMS we disable the port using the OID (SNMP)
Is there any way Nagios can do this
npolovenko
- Support Tech
Re: disable port using nagios core
Hello, @DOkuwa. How are you monitoring the device? Do you have separate service checks defined for each port of the device? Or are you using SNMP trap?
we are using snmp to monitor the devices
we have a check for all the ports for a group of devices but Nagios keeps reporting that a some specific port is down which is correct because they are alcatel devices which it's port cannot be disabled from the terminal
so we want nagios to exclude monitoring this specific port using the sysOID
or maybe put in in maintenance mode for this group of devices
npolovenko
- Support Tech
@DOkuwa, Can you upload the snmptt.conf file from your Nagios server?
Usually that configuration file defines how your trap information is processed by Nagios. So we might be able to modify it..
Also, please share with us a screenshot of your SNMP check output on Service Detail page.
/etc/snmp/snmptt.conf Also, please share with us a screenshot of your SNMP check output on Service Detail page.
The first service is the actual service that monitors the port
the second service is the generic services it uses and the third is the script that the service uses
I have the snmp oid which relates to the desired port on the alcatel devices that needs to be filtered out and don't know if this can be adjusted in the script
name alcatel-network-ports
service_description Alcatel_Network_Ports
is_volatile 0
check_command check_alcatel_network_ports
max_check_attempts 3
normal_check_interval 3
retry_check_interval 1
active_checks_enabled 1
check_period 24x7
parallelize_check 1
obsess_over_service 0
check_freshness 0
flap_detection_enabled 0
process_perf_data 0
retain_status_information 1
retain_nonstatus_information 0
notification_interval 180
notification_period 24x7
notification_options w,c,r
notifications_enabled 1
contact_groups Core_Team
register 0
name generic-service
service_description generic-service
is_volatile 0
normal_check_interval 5
passive_checks_enabled 0
check_period 24x7
parallelize_check 1
process_perf_data 1
notification_interval 60
notification_period 24x7Code: Select all
more check_alcatel_ports.pl
#!/usr/bin/perl
=pod
=head1 NAME
=head1 SYNOPSIS
check_alcatel_ports.pl community-string agent
=head1 DESCRIPTION
Uses Net::SNMP to query an Alcatel 7450 VPLS switch to find status of the
network ports. Alarms critical if the ports are UP/DOWN.
=head1 NOTES
=head1 TODO
=head1 REFERENCES
TIMETRA-PORT-MIB.mib
=cut
# Modules
use strict;
use warnings;
use Net::SNMP;
use Getopt::Long;
Getopt::Long::Configure("bundling");
use lib qw( /usr/local/nagios/libexec );
use utils qw($TIMEOUT %ERRORS &print_revision &support);
# Globals
use vars qw|$PROGNAME $DEBUG $VERSION|;
$DEBUG = 0;
$VERSION = '01.00';
$PROGNAME = "$0";
my $agent;
my $comm_string;
my $ok;
my $state = $ERRORS{'OK'};
my ($opt_V, $opt_h);
# Just in case of problems, let's not hang Nagios
$SIG{'ALRM'} = sub {
print ("ERROR: Unable to get status from $agent (alarm timeout)\n");
exit $ERRORS{"UNKNOWN"};
alarm($TIMEOUT);
#Option checking
$ok = GetOptions(
"V" => \$opt_V, "version" => \$opt_V,
"h" => \$opt_h, "help" => \$opt_h,
"H=s" => \$agent, "hostname=s" => \$agent,
"C=s" => \$comm_string, "community=s" => \$comm_string,
unless ( $ok ) {
exit $ERRORS{'OK'};
if ($opt_V) {
exit $ERRORS{'OK'};
if ($opt_h) {
exit $ERRORS{'OK'};
if (!$comm_string) {
print STDERR "No community string specified!\n";
exit $ERRORS{'UNKNOWN'};
unless ( utils::is_hostname($agent) ) {
print "Invalid hostname\n";
# Alcatel OIDs
my $port_name_oid = '1.3.6.1.4.1.6527.3.1.2.2.4.2.1.6';
my $port_desc_oid = '1.3.6.1.4.1.6527.3.1.2.2.4.2.1.5';
my $port_mode_oid = '1.3.6.1.4.1.6527.3.1.2.2.4.2.1.11';
my $port_admin_oid = '1.3.6.1.4.1.6527.3.1.2.2.4.2.1.37';
my $port_oper_oid = '1.3.6.1.4.1.6527.3.1.2.2.4.2.1.38';
my $port_state_oid = '1.3.6.1.4.1.6527.3.1.2.2.4.2.1.39';
my %ports;
my $answer = '';
my $error = 0;
# Initiate SNMP session
my $session = Net::SNMP->session(
-hostname => $agent,
-version => 'snmpv2c',
-community => $comm_string,
-port => 161,
-timeout => 2,
-retries => 1,
-maxmsgsize => 20000,
# Port Name
my $table = $session->get_table( -baseoid => $port_name_oid );
if ($session->error) {
print $session->error . "\n";
exit(1);
foreach my $entry (sort keys %{$table}) {
my $index = (split /\./, $entry)[16];
$ports{$index} = [ $table->{$entry} ];
# Port Mode
$table = $session->get_table( -baseoid => $port_mode_oid );
exit(1);
$ports{$index}->[1] = $table->{$entry};
# Port Admin Status
$table = $session->get_table( -baseoid => $port_admin_oid );
exit(1);
$ports{$index}->[2] = $table->{$entry};
# Port Oper Status
$table = $session->get_table( -baseoid => $port_oper_oid );
exit(1);
$ports{$index}->[3] = $table->{$entry};
# Port Desc
$table = $session->get_table( -baseoid => $port_desc_oid );
print $session->error;
exit(1);
$ports{$index}->[4] = $table->{$entry};
# Port State
$table = $session->get_table( -baseoid => $port_state_oid );
exit(1);
$ports{$index}->[5] = $table->{$entry};
foreach my $port (sort keys %ports) {
my $name = $ports{$port}->[0];
my $desc = $ports{$port}->[4];
my $mode = $ports{$port}->[1];
my $admin = $ports{$port}->[2];
my $oper = $ports{$port}->[3];
my $port_state = $ports{$port}->[5];
# Skip if not network port
if ($mode != 2) {
next;
# Skip if admin down
elsif ($admin == 3) {
next;
# Skip if state is 'ghost' (port provisioned by not physically present)
elsif ($port_state == 2){
next;
# Alarm if oper down
elsif ($oper != 2) {
$error = 1;
$state = $ERRORS{'CRITICAL'};
$answer .= "[$desc OperStatus down] ";
next;
if (!$error) {
$answer .= "All ports OK.";
print $answer;
else {
print "$answer";
exit $state;
Reason: breaking up the code block since it's two different things
npolovenko
- Support Tech
@DOkuwa, I'm not a pro at programming but I think you could add a new else if statement to the script to filter out that particular port based on some criteria? I haven't seen the actual output of this script so it's hard to tell. As an option, you could email customer support for a custom development.
yes this is true
I will need to figure this out
- Former Nagios Staff
I'm not seeing any references online to this plugin. Where did you get it from? Did it originally have a different name? Is it just something someone in your organization wrote? I ask because there might be newer versions with the features you want.
i have not seen any plugin for this but i might need to modify the check_alcatel_ports.pl
This request has been ordered by the network team as the alarms caused by this network port down is flooding their mails
and hence this needs to be removed/disabled
- tacolover101
you need to modify the plugin, and build logic to handle the returned message properly.
