NCPA 2.1.1 Service Error
dgannon
Re: NCPA 2.1.1 Service Error
Post by dgannon »
I resolved the issue with the disk space checks.
The problem seems to have been the introduction of the "exclude_fs_types" option. Removing the fstypes we are interested in monitoring and then restarting the client has fixed it. (we had some cifs and nfs mounted file systems we wanted monitored).
Post by dwhitfield »
@twalters2, as OP, I want to leave this open until I get the ok from you.
If anyone other than twalters2 is having an issue with the fix, please open a new thread, rather than tacking on to this one. Thanks!
smperry123
Post by smperry123 »
Hi, how do you update the NCPA wizard? Thanks
Go to Admin > System Extensions > Manage Config Wizards, click on "Check for Updates", then click on "Install Updates".
