I downloaded it straight from that site, your site, no where else.
this is ESXi v6.0
max virtual disk size? ext3 vs ext4 issues
Re: max virtual disk size? ext3 vs ext4 issues
as you can see from screenshot, its ext3 on both the old server and the new server.
looks like the partition table is msdos?? looking like I have two different issues.
so the newly created OVA, does show ext4 as the filesystem when I do mount or file -SL /dev/sda1
however, cfdisk shows Linux ext3
df -T also shows ext4
think the 2TB limitation is coming from the msdos partition, since its not GPT.
- Former Nagios Staff
Locking the thread, since we have a ticket for the issue.
