port 5666: Connection refused SAVE ME , I tried everything
Re: port 5666: Connection refused SAVE ME , I tried everythi
Is 192.168.0.93 the correct IP address of your nagios server? Have you restarted xinetd after modifying the nrpe file, so that the changes can take effect? have you tried stopping the iptables temporarily just in case, and running your check again?
pohlin
Post by pohlin »
yes 192.168.0.93 is the correct ip adress of the nagios server.
Yup, restarted.
tried stopping iptables ,output still the same.
Are you using TCP wrappers? Do you have host.allow or host.deny configured on this system? Run the following commands on the remote box, and show the output:
ip a
uname -a
cat /etc/*release
netstat -anp | grep 5666
/usr/local/nagios/bin/nrpe -V
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
Also, upload the nrpe.cfg file on the forum. Thank you!
pohlin
Post by pohlin »
im sorry, i am new to everything..so i dont know if im using a tcp wrapper or not, and also dont know i have host.deny or host.allow... :cry:
here are the screenshot and file, thank you for trying to help me
nrpe.cfg
(7.05 KiB) Downloaded 675 times
npolovenko
Post by npolovenko »
@pohlin, I looked at your nrpe.cfg config file and the line:
allowed_hosts=127.0.0.1
Doesn't have the entry for the Nagios server. Please change it to:
allowed_hosts=127.0.0.1,192.168.0.93
Exit out of the file and restart nrpe with:
service nrpe restart
Then, from the nagios server run the following command:
/usr/local/nagios/libexec/check_nrpe -H 192.168.0.137
pohlin
Post by pohlin »
HI everyone ,thank you so much for helping me, but i've moved on to install nagios core on an real server, ubuntu 14.04, and i am still facing connection refuse issue. i have posted a new thread : https://support.nagios.com/forum/viewto ... 20&t=47623
I will be closing this thread and we will continue in the other.
