Error code: 9.
Re: Error code: 9.
I see a lot of errors like this in the cmdsubsys.log
Couldn't resolve proxy 'fg.umniah.com'
Also, can you run the following and return /tmp/reconfigure.txt
./reconfigure_nagios.sh >/tmp/reconfigure.txt 2>&1
habuhejleh
Re: Error code: 9.
Post by habuhejleh »
I removed the proxy and here is the output of the command:
login as: nagiosadmin
[email protected]'s password:
Last login: Mon Jul 9 14:01:53 2018 from 188.247.75.83
[nagiosadmin@um-isp-nagios-redline ~]$ vi /tmp/reconfigure.txt 2>&1
Another reconfigure process is still running, sleeping...
"/tmp/reconfigure.txt" 319L, 18293C 114,1 33%
and we have now another error in apply the configuration as in attachment Error3
Re: Error code: 9.
Please post the output of the following commands:
getenforce
grep NAGIOS /etc/sudoers
habuhejleh
Re: Error code: 9.
Here is the output:
Last login: Mon Jul 9 14:17:14 2018 from 188.247.75.83
-bash: fork: retry: Resource temporarily unavailable
[nagiosadmin@um-isp-nagios-redline ~]$ getenforce
Disabled
[nagiosadmin@um-isp-nagios-redline ~]$ grep NAGIOS /etc/sudoers
User_Alias NAGIOSXI=nagios
User_Alias NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/component s/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/get profile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/backup_xi.sh *
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/compon ents/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/ getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
Re: Error code: 9.
Do you regularly see this? its like your system is our of file handles or something
habuhejleh
Re: Error code: 9.
Yes. What is the solution please?!
Our business is considerably impacted.
Re: Error code: 9.
please run the following
rm -f /usr/local/nagiosxi/scripts/reconfigure_nagios.lock
and then the following again and return /tmp/reconfigure.txt
habuhejleh
Re: Error code: 9.
Dear ,
I did the command "killall5 -9" in order to kill processes because each time I try to reset to configuration factory defaults or run command of reconfigure.sh it gives me error that another process is running...
After I did the command above I am now unable to login to nagiosxi by ssh and web page does not open, please advise how to fix this issue.
habuhejleh
Re: Error code: 9.
We tried rebooting the entire VM however no luck. Please advise.
Re: Error code: 9.
For the "-bash: fork: retry: Resource temporarily unavailable" error, you can try following the steps, outlined here:
https://access.redhat.com/solutions/543503
Did you try removing the reconfigure_nagios.lock, prior to running the reconfigure_nagios.sh script as suggested by scottwilkerson?
I saw in the profile, that your hard drive was almost 90% full. Do you have enough HD space now? What is the output of the following command?
df -h
Do you see any errors in the web UI, when you try to log in?
http://<ip address>/nagiosxi
What about errors in the apache error log?
Is apache running?
service httpd status
Also, if you are using a proxy, I would recommend reviewing our KB article on the topic here:
https://support.nagios.com/kb/article/n ... s-147.html
