Error code: 9.
habuhejleh
Error code: 9.
Post by habuhejleh »
Dear ,
We are facing problem in our Nagios XI version when we apply the configuration it takes long time verifying then give the below error:
There was an error while attempting to apply configuration. Error code: 9.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
Our Nagios XI version is 5.4.12 and it is installed on VM.
Please advise ASAP.
Best regards,
Haitham
npolovenko
Re: Error code: 9.
Post by npolovenko »
Hello, @habuhejleh. In XI web interface please go to Configure -> Core Configurations Manager, then click on Tools -> Config File Management in the left column. Then perform the following actions in order:
1)Write
2)Delete
3)Write
4)Verify
Please post any errors after clicking the "Verify" button.
habuhejleh
Re: Error code: 9.
Hello ,
I did and I get the below verification result in the attachment:
Verification
and when I do apply configuration it takes long time (10 minutes) then gives me he below error in the attached:
Apply config Error
Please advise ASAP.
Thank you,
Haitham
npolovenko
Re: Error code: 9.
@habuhejleh, Please establish SSH session to the Nagios console. Switch to the nagios user:
su - nagios
And run the following script as nagios user:
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
Please let me know of the output.
habuhejleh
Re: Error code: 9.
We got the below error after executing the command:
RESETTING CONFIG PERMS FAILED!\n
Also you can see failures in the GUI as attached. Please advise asap.
Re: Error code: 9.
From that screenshot I can see there are database errors, please run these steps
https://assets.nagios.com/downloads/nag ... tabase.pdf
then, also return the results of
getenforce
grep NAGIOS /etc/sudoers
habuhejleh
Re: Error code: 9.
Databases were repaired by the script.
Here is the output of the commands you requested:
[nagiosadmin@um-isp-nagios-redline ~]$ getenforce
Disabled
[nagiosadmin@um-isp-nagios-redline ~]$ grep NAGIOS /etc/sudoers
User_Alias NAGIOSXI=nagios
User_Alias NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/backup_xi.sh *
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
We are still having the same problem when applying the configuration, it takes 10 minutes in verifying the configuration then gives the below error:
Please advise how to solve this problem asap
habuhejleh
Re: Error code: 9.
Please advise...
Re: Error code: 9.
Please send a copy of profile.zip from Admin -> System Profile
Thanks!
habuhejleh
Re: Error code: 9.
Done. Please advise.
