Thanks @mcapra, @cdienger
I already tried the steps you mentioned, I ran the query and it seems to be working fine. I also modified the script by substituting the dbname in the query, and also print the fetched row value.
When I ran query against the db, it returned one row with the values, But the same is not returning any rows when running from this script.
Plugin to monitor MSSQL DB Mirroring- not working
sannatar16
Re: Plugin to monitor MSSQL DB Mirroring- not working
When you manually run the command, are you doing that on the sql server? Is there any logging on the sql server you can enable to see why it would be failing? At this point I think it's likely making a connection but for some reason it doesn't like when the request is made from the XI machine.
Was the dumptrace you refereed to earlier a tcpdump? I'd be curious to see the request/response. You can run one with:
yum -y install tcpdump
tcpdump -s 0 -i any port 1433 -w output.pcap
Run the script a couple times when this is running and then use CTRL+C to stop it. PM me the file since it can contain sensitive info.
