CHECK_NRPE: Error - Could not complete SSL handshake
amitgupta19
Re: CHECK_NRPE: Error - Could not complete SSL handshake
Post by amitgupta19 »
Still the same error.
nsclient.ini file attached.
Kindly look into it.
nsclient.ini
(1.67 KiB) Downloaded 2776 times
This is not the entire config, is it? You are missing many of the default directives...
You can add the missing default entries (if this is the case here) by running the following command from the CMD prompt on the Windows machine:
nscp settings --generate --add-defaults --load-all
amitgupta19
When i run the above command it gives me the below error:
C:\Program Files\NSClient++>nscp settings --generate --add-defaults --load-all
E client Failed to initialize settings: Failed to save file 'ini://${shared-
path}/nsclient.ini': I/O error: 5: Access is denied.
c:\source\master\service\settings_client.cpp:132
C:\Program Files\NSClient++/nsclient.log could not be opened, Discarding: error:
Failed to initialize settings: Failed to save file 'ini://${shared-path}/nsclie
Although i am part of the adminstrators but still i do not have the privileges to modify any file in the C Drive. I can only replace the file.
So if you can help me with the contents of the file, i can create a copy outside the C Drive and replace the actual file in the C Drive.
Do let me know your thoughts.
you need to open cmd.exe by right clicking "run as administrator"
amitgupta19
After adding the missing default entries i am getting following error:
"CHECK_NRPE STATE CRITICAL: Socket timeout after 30 seconds."
Any thoughts.
This document contains the basic steps
amitgupta19
I followed all the steps mentioned in the Document.
After this i have started getting the following error:
connect to address xxx.xxx.xxx.xxxx port 5666: Connection refused
connect to host xxx.xxx.xxx.xxx port 5666: Connection refused
Earlier i was not getting this error.
Can anyone suggest what to do?
Updated nsclient.ini file is attached here with.
nsclient.ini
(29.82 KiB) Downloaded 2884 times
Did you restart the service after making the changes?
Is the windows firewall blocking port 5666?
amitgupta19
NS Client++ Service restarted.
there was no changes made to the server that i am trying to monitor.
Any idea how to track it down?
Do you see any errors in the nsclient.log?
