CHECK_NRPE: Error - Could not complete SSL handshake
amitgupta19
I have installed the Nagios Core on Cent OS.
I am trying to monitor a windows server 2012, using the NSClient++ ---Version--05.2.35 .
I have followed the process to enable the NRPE Listener for the NSClient.
But when i run the following command from the Nagios Server:
./check_nrpe -H xxx.xxx.xxx.xxx
I gets the below Error.
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with xxx.xxx.xxx.xxx : 1
nsclient.ini file is attached for your referrence.
nsclient.ini- (1.36 KiB) Downloaded 2781 times
amitgupta19
Re: CHECK_NRPE: Error - Could not complete SSL handshake
Can anyone please look into it?
It looks like you have insecure set twice in the NRPE section of your nsclient.ini file. Is that on purpose? It sets it to true up top and then false down below. Depending on the version of OpenSSL on the check_nrpe side it may not be able to connect.
amitgupta19
I have deleted the 1 instance of the insecure.
Restarted the NSClient. Still same error.
Which line do you currently have in the config?I have deleted the 1 instance of the insecure.
insecure = trueCode: Select all
insecure = falseCode: Select all
./check_nrpe -H xxx.xxx.xxx.xxx -2Be sure to check out our Knowledgebase for helpful articles and solutions!
amitgupta19
I have the following line
insecure= true
i tried with following command as well, but still the same error:
[xxxxx@-------libexec]$ sudo ./check_nrpe -H xxx.xxx.xxx.xxx -2
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with xxx.xxx.xxx.xxx: 1
insecure= true
Comment out these two lines in the nsclient.ini, so that they will look like this:
Add the following line under the [/settings/NRPE/server] section:
and restart the nsclient++ service.
Is your check working now?
; ssl options = no-sslv2,no-sslv3
; verify mode = peer-certCode: Select all
allowed ciphers = ALL:!MD5:@STRENGTHIs your check working now?
amitgupta19
Yes it is working Now.
Thanks for the Help.
amitgupta19
I am trying to monitor the Physical memory on the windows server using the following command:
sudo ./check_nrpe -H 172.16.5.180 -p 5666 -c CheckMEM -a MaxWarn=80% MaxCrit=90% ShowAll type=physical
When i run the command manually from the nagios server, it is giving the following error:
[XXXXXXXXX@XXXXXXXX libexec]$ sudo ./check_nrpe -H xxx.xxx.xxx.xxx -p 5666 -c CheckMEM -a MaxWarn=80% MaxCrit=90% ShowAll type=physical
[sudo] password for xxxxxx:
Unknown command(s): checkmem
Do i need to do any configuration on the windows server so that command can run without any error?
Try enabling the disabled modules in the nsclient.ini. Currently, you have:
Change "disabled" to "enabled", restart the nsclient++ service, and try your check again. If this doesn't work, post the entire nsclient.log file on the forum. Thanks!
; Undocumented key
CheckExternalScripts = disabled
; Undocumented key
CheckHelpers = disabled
; Undocumented key
CheckNSCP = disabled
; Undocumented key
CheckDisk = disabled
; Undocumented key
CheckSystem = disabled
; Undocumented key
CheckEventLog = disabledBe sure to check out our Knowledgebase for helpful articles and solutions!
