/usr/local/nagios/var/npcd.log
Nagios 5.5
npolovenko
- Support Tech
Re: Nagios 5.5
@dfmco, I'd like to see the error message when you try to start the service + please upload the log file:
Re: Nagios 5.5
[root@bm-qr-nagiosxi var]# cat /usr/local/nagios/var/npcd.log
[07-12-2018 22:19:22] NPCD: npcd Daemon (0.4.14) started with PID=16890
[07-12-2018 22:19:22] NPCD: Please have a look at 'npcd -V' to get license information
[07-12-2018 22:19:22] NPCD: HINT: load_threshold is enabled - ('10.000000')
[07-12-2018 22:23:59] NPCD: Caught Termination Signal - Hasta la vista... baby
[07-12-2018 22:23:59] NPCD: npcd Daemon (0.4.14) started with PID=19083
[07-12-2018 22:23:59] NPCD: Please have a look at 'npcd -V' to get license information
[07-12-2018 22:23:59] NPCD: HINT: load_threshold is enabled - ('10.000000')
[07-12-2018 22:24:07] NPCD: Caught Termination Signal - Hasta la vista... baby
[07-12-2018 22:24:07] NPCD: npcd Daemon (0.4.14) started with PID=19503
[07-12-2018 22:24:07] NPCD: Please have a look at 'npcd -V' to get license information
[07-12-2018 22:24:07] NPCD: HINT: load_threshold is enabled - ('10.000000')
[07-13-2018 21:58:33] NPCD: Caught Termination Signal - Hasta la vista... baby
[07-13-2018 21:58:51] NPCD: npcd Daemon (0.4.14) started with PID=1828
[07-13-2018 21:58:51] NPCD: Please have a look at 'npcd -V' to get license information
[07-13-2018 21:58:51] NPCD: HINT: load_threshold is enabled - ('10.000000')
[08-01-2018 13:48:09] NPCD: Caught Termination Signal - Hasta la vista... baby
[08-01-2018 13:48:34] NPCD: npcd Daemon (0.4.14) started with PID=1203
[08-01-2018 13:48:34] NPCD: Please have a look at 'npcd -V' to get license information
[08-01-2018 13:48:34] NPCD: HINT: load_threshold is enabled - ('10.000000')
[08-12-2018 22:33:23] NPCD: Caught Termination Signal - Hasta la vista... baby
[08-12-2018 22:34:14] NPCD: npcd Daemon (0.4.14) started with PID=1200
[08-12-2018 22:34:14] NPCD: Please have a look at 'npcd -V' to get license information
[08-12-2018 22:34:14] NPCD: HINT: load_threshold is enabled - ('10.000000')
[08-13-2018 00:24:38] NPCD: npcd Daemon (0.4.14) started with PID=14618
[08-13-2018 00:24:38] NPCD: Please have a look at 'npcd -V' to get license information
[08-13-2018 00:24:38] NPCD: HINT: load_threshold is enabled - ('10.000000')
[08-13-2018 00:28:39] NPCD: Caught Termination Signal - Hasta la vista... baby
[08-13-2018 00:29:27] NPCD: npcd Daemon (0.4.14) started with PID=1108
[08-13-2018 00:29:27] NPCD: Please have a look at 'npcd -V' to get license information
[08-13-2018 00:29:27] NPCD: HINT: load_threshold is enabled - ('10.000000')
[08-13-2018 00:42:48] NPCD: Caught Termination Signal - Hasta la vista... baby
[08-13-2018 00:42:49] NPCD: npcd Daemon (0.4.14) started with PID=6819
[08-13-2018 00:42:49] NPCD: Please have a look at 'npcd -V' to get license information
[08-13-2018 00:42:49] NPCD: HINT: load_threshold is enabled - ('10.000000')
[08-13-2018 00:43:29] NPCD: Caught Termination Signal - Hasta la vista... baby
[08-13-2018 00:43:30] NPCD: npcd Daemon (0.4.14) started with PID=8789
[08-13-2018 00:43:30] NPCD: Please have a look at 'npcd -V' to get license information
[08-13-2018 00:43:30] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-19-2018 15:13:59] NPCD: WARN: MAX load reached: load 14.970000/10.000000 at i=0
[10-19-2018 15:14:15] NPCD: WARN: MAX load reached: load 22.220000/10.000000 at i=1
[10-19-2018 15:14:30] NPCD: WARN: MAX load reached: load 28.370000/10.000000 at i=1
[10-19-2018 15:14:45] NPCD: WARN: MAX load reached: load 31.440000/10.000000 at i=1
[10-19-2018 15:15:00] NPCD: WARN: MAX load reached: load 32.030000/10.000000 at i=1
[10-19-2018 15:15:15] NPCD: WARN: MAX load reached: load 40.720000/10.000000 at i=1
[10-19-2018 15:15:30] NPCD: WARN: MAX load reached: load 88.100000/10.000000 at i=1
[10-19-2018 15:15:45] NPCD: WARN: MAX load reached: load 155.700000/10.000000 at i=1
[10-19-2018 15:16:00] NPCD: WARN: MAX load reached: load 182.600000/10.000000 at i=1
[10-19-2018 15:16:15] NPCD: WARN: MAX load reached: load 144.700000/10.000000 at i=1
[10-19-2018 15:16:30] NPCD: WARN: MAX load reached: load 112.650000/10.000000 at i=1
[10-19-2018 15:16:45] NPCD: WARN: MAX load reached: load 88.240000/10.000000 at i=1
[10-19-2018 15:17:00] NPCD: WARN: MAX load reached: load 68.890000/10.000000 at i=1
[10-19-2018 15:17:15] NPCD: WARN: MAX load reached: load 54.530000/10.000000 at i=1
[10-19-2018 15:17:30] NPCD: WARN: MAX load reached: load 42.590000/10.000000 at i=1
[10-19-2018 15:17:45] NPCD: WARN: MAX load reached: load 33.780000/10.000000 at i=1
[10-19-2018 15:18:00] NPCD: WARN: MAX load reached: load 26.370000/10.000000 at i=1
[10-19-2018 15:18:15] NPCD: WARN: MAX load reached: load 20.690000/10.000000 at i=1
[10-19-2018 15:18:30] NPCD: WARN: MAX load reached: load 16.250000/10.000000 at i=1
[10-19-2018 15:18:45] NPCD: WARN: MAX load reached: load 13.890000/10.000000 at i=1
[10-19-2018 15:19:00] NPCD: WARN: MAX load reached: load 11.180000/10.000000 at i=1
[10-19-2018 15:19:15] NPCD: WARN: MAX load reached: load 11.140000/10.000000 at i=1
[10-19-2018 15:23:00] NPCD: Caught Termination Signal - Hasta la vista... baby
[10-19-2018 15:23:59] NPCD: npcd Daemon (0.4.14) started with PID=1133
[10-19-2018 15:23:59] NPCD: Please have a look at 'npcd -V' to get license information
[10-19-2018 15:23:59] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:05:37] NPCD: Caught Termination Signal - Hasta la vista... baby
[10-31-2018 11:05:37] NPCD: npcd Daemon (0.4.14) started with PID=20978
[10-31-2018 11:05:37] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:05:37] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:05:37] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:05:37] NPCD: Exiting...
[10-31-2018 11:05:37] NPCD: Daemon ended. PID was '20978'
[10-31-2018 11:06:01] NPCD: npcd Daemon (0.4.14) started with PID=22892
[10-31-2018 11:06:01] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:06:01] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:06:01] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:06:01] NPCD: Exiting...
[10-31-2018 11:06:01] NPCD: Daemon ended. PID was '22892'
[10-31-2018 11:07:40] NPCD: npcd Daemon (0.4.14) started with PID=30221
[10-31-2018 11:07:40] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:07:40] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:07:40] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:07:40] NPCD: Exiting...
[10-31-2018 11:07:40] NPCD: Daemon ended. PID was '30221'
[10-31-2018 11:10:34] NPCD: npcd Daemon (0.4.14) started with PID=11668
[10-31-2018 11:10:34] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:10:34] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:10:34] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:10:34] NPCD: Exiting...
[10-31-2018 11:10:34] NPCD: Daemon ended. PID was '11668'
[10-31-2018 11:10:46] NPCD: npcd Daemon (0.4.14) started with PID=12486
[10-31-2018 11:10:46] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:10:46] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:10:46] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:10:46] NPCD: Exiting...
[10-31-2018 11:10:46] NPCD: Daemon ended. PID was '12486'
[10-31-2018 11:18:33] NPCD: npcd Daemon (0.4.14) started with PID=18596
[10-31-2018 11:18:33] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:18:33] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:18:33] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:18:33] NPCD: Exiting...
[10-31-2018 11:18:33] NPCD: Daemon ended. PID was '18596'
[10-31-2018 11:22:56] NPCD: npcd Daemon (0.4.14) started with PID=8773
[10-31-2018 11:22:56] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:22:56] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:22:56] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:22:56] NPCD: Exiting...
[10-31-2018 11:22:56] NPCD: Daemon ended. PID was '8773'
[10-31-2018 11:24:52] NPCD: npcd Daemon (0.4.14) started with PID=17242
[10-31-2018 11:24:52] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:24:52] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:24:52] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:24:52] NPCD: Exiting...
[10-31-2018 11:24:52] NPCD: Daemon ended. PID was '17242'
[10-31-2018 11:26:25] NPCD: npcd Daemon (0.4.14) started with PID=24373
[10-31-2018 11:26:25] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:26:25] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:26:25] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:26:25] NPCD: Exiting...
[10-31-2018 11:26:25] NPCD: Daemon ended. PID was '24373'
[10-31-2018 11:34:58] NPCD: npcd Daemon (0.4.14) started with PID=1164
[10-31-2018 11:34:58] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 11:34:58] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 11:34:58] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 11:34:58] NPCD: Exiting...
[10-31-2018 11:34:58] NPCD: Daemon ended. PID was '1164'
You have mail in /var/spool/mail/root
Re: Nagios 5.5
I just tried to restart again
[10-31-2018 12:59:25] NPCD: npcd Daemon (0.4.14) started with PID=17881
[10-31-2018 12:59:25] NPCD: Please have a look at 'npcd -V' to get license information
[10-31-2018 12:59:25] NPCD: HINT: load_threshold is enabled - ('10.000000')
[10-31-2018 12:59:25] NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
[10-31-2018 12:59:25] NPCD: Exiting...
[10-31-2018 12:59:25] NPCD: Daemon ended. PID was '17881'
npolovenko
- Support Tech
Re: Nagios 5.5
@dfmco, This path doesn't look right:
It should be:NPCD: Error while get file list from spooldir (/var/nagiosramdisk/nagios/spool/perfdata/) - No such file or directory
Did you change the last path correctly to --> /var/nagiosramdisk/spool/perfdata/, or did you change it to --> /var/nagiosramdisk/nagios/spool/perfdata/ ?/var/nagiosramdisk/spool/perfdata/
Re: RPM for 5.5.5 is broken. Won't install properly on Cent
So for some reason there was a swap file created and it did not save my initial change. I have re-run the steps and the npcd service is now running. The performance grapher is back up and the graphs are now populating. Thank you for your help.
Re: Nagios 5.5
Great! We are marking this issue as resolved and locking the topic.
