Please check your inboxlmiltchev wrote:@shamrozkadiwal, can you zip up the /usr/local/nagios directory and PM the zip file to me or any other member of the Nagios Support team? Thank you!
Not getting Email alerts
shamrozkadiwal
Re: Not getting Email alerts
I sent you a PM. Thanks!
shamrozkadiwal
I noticed that debug_log was 0 so I changed it to 32 as you said. I have attached whole nagios log filebenjaminsmith wrote:Hello shamrozkadiwal,
Let's change the debug level settings to capture notification data, and then put adxp011a into a down state and then back up (recovery state). We will then take a look at the log file for this host and review the state changes and whether or not notifications were sent.
1. Open up the nagios configuration file /usr/local/nagios/etc/nagios.cfg, and set debug_level=32, and then re-start Nagios.
2. Put the adxpo11a into a down state and then a recovery.
2. Post or PM the nagios log data or the contents of the log file at /usr/local/nagios/var
nagios.log. You'll want to search the log data for host notification entries for adxp011a. The perl statement at the end will convert the unix timestamp into human readable text. Are notifications beings sent? If so, to the correct contacts?Let me know what you find out.Code: Select all
cat nagios.log | grep adxp011a | perl -pe 's/(\d+)/localtime($1)/e'
Main Configuration File Options
https://assets.nagios.com/downloads/nag ... gmain.html
nagios.log- (658.24 KiB) Downloaded 318 times
npolovenko
- Support Tech
@shamrozkadiwal, Looks like the archive you sent to @lmiltchev doesn't have all the information we needed. Your configs and objects.cache file is in a custom directory /usr/nagios. Can you zip that whole folder and send it to me in a PM?
shamrozkadiwal
I have sent you PM anther tar.gz filenpolovenko wrote:@shamrozkadiwal, Looks like the archive you sent to @lmiltchev doesn't have all the information we needed. Your configs and objects.cache file is in a custom directory /usr/nagios. Can you zip that whole folder and send it to me in a PM?
benjaminsmith
Hello @shamrozkadiwal,
In your service escalations, you've configured the disk-contacts group to receive email alerts for W,C,R and the infrastructure-pager contact group for C,R.
One thing I noticed is that your the configuration settings for the member in disk-contacts, production and setup, have the service notification options set to none (n) and the host notification options set to unreachable (u).
While the members of infrastructure-pager are as so:
Please try re-setting the notification options, W,C,U, for the disk-contacts group and put adxp011a into a down state, and then review the log file as mentioned earlier to verify notifications were sent.
## Service Escalations
define serviceescalation {
hostgroup_name data-servers,processing-servers,!no_data_drive
host_name aft001,eris,ftp01,ftp02,!app403,!app012
service_description Disk Space Data
contact_groups disk-contacts
first_notification 1
last_notification 0
notification_interval 180
escalation_options w,c,r
hostgroup_name data-servers,!no_data_drive
contact_groups infrastructure-pager
last_notification 0
notification_interval 120
escalation_options c,r
define contact {
contact_name production
alias Production
host_notification_period never
service_notification_options n
host_notification_options u
service_notification_commands notify-by-email
host_notification_commands host-notify-by-email
email [email protected]
host_notifications_enabled 1
service_notifications_enabled 1
can_submit_commands 1
retain_status_information 1
define contact {
contact_name setup
alias Setup
define contact {
contact_name bhswar
alias Bhagwat Swarup
service_notification_period 24x7
host_notification_period 24x7
service_notification_options c,r
host_notification_options d,r
service_notification_commands notify-by-email,notify-by-pager
host_notification_commands host-notify-by-email,host-notify-by-pager
pager [email protected]
define contact {
contact_name bhswar-email
alias Bhagwat Swarup - Email Only
service_notification_options w,u,c,r
host_notification_options d,u,r
shamrozkadiwal
@Benjaminsmith, I didn't understand where exactly or file I need to make a change.
We have purposely set W,C,R just for email notification and C,R for infrastructure-pager. We don't want W on the infrastructure-pager.In your service escalations, you've configured the disk-contacts group to receive email alerts for W,C,R and the infrastructure-pager contact group for C,R.
shamrozkadiwal
Also wondering, why do we receive the EMAIL notification for adx800, but not for adxp011a when we have the similar configuration for both
benjaminsmith
If you look at the service definition for Disk Space Data on adxp011a you'll see the notifications options are only for critical and recovery. The debug logs that I have do not show this host going into a state that would trigger notifications.
Keep the debug settings as before, then update your service definition for adxp011a, put the host in a warning state by adjusting the check variables, restart and then examine the debug log to see if the notifications were sent
I'm trying to figure that out as well. For Nagios Core, you are running a large system and there are many layers to the configuration files. Currently, adxp011a is not set to notify on a warning state. You can see that in the nagios.debug log:Also wondering, why do we receive the EMAIL notification for adx800, but not for adxp011a when we have the similar configuration for both
[1544453107.040894] [032.0] [pid=1583] ** Service Notification Attempt ** Host: 'adxp011a', Service: 'Disk Space Data', Type: 0, Options: 0, Current State: 1, Last Notification: Wed Dec 31 18:00:00 1969
[1544453107.040915] [032.1] [pid=1583] We shouldn't notify about WARNING states for this service.
[1544453107.040919] [032.0] [pid=1583] Notification viability test failed. No notification will be sent out.
host_name adxp011a
check_period no-sun
check_command check_nt_disk-large!D!90!95
initial_state o
check_interval 20.000000
retry_interval 3.000000
max_check_attempts 5
is_volatile 0
parallelize_check 1
active_checks_enabled 1
passive_checks_enabled 1
obsess_over_service 1
event_handler_enabled 1
low_flap_threshold 0.000000
high_flap_threshold 0.000000
flap_detection_enabled 1
flap_detection_options o,w,u,c
freshness_threshold 0
check_freshness 0
notification_interval 1440.000000
first_notification_delay 0.000000
stalking_options n
process_perf_data 1
failure_prediction_enabled 1
shamrozkadiwal
Please keep this thread open. I am also debugging from my end too
