Posts: 19396 Joined: Tue Nov 15, 2011 3:11 pm
Post
by scottwilkerson » Fri Dec 14, 2018 4:58 pm
raydx wrote: In re to "what you have configured for check_nrpe in the GUI", which file are you referring to?
In the GUI Configuration -> Select Commands
What does it say by check_nrpe ?
raydx wrote: In the CLI, in /usr/local/nagios/libexec$, I ran the command and CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
This looks like check_nrpe may not even be able to communicate with your nsclient machine, do you get anything with just this
If not are you sure port 5666 is not being blocked by the Windows firewall?
raydx
Posts: 34 Joined: Thu Jun 28, 2018 3:51 pm
Post
by raydx » Fri Dec 14, 2018 5:34 pm
In the GUI Configuration -> Select Commands for check_nrpe:
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 120 -c $ARGS$
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 120 -c (not an $ARGn$ index: "S")
Running ./check_nrpe - H 10.11.96.130 does return NRPE v3.2.1
I don't think it is an firewall issue as other checks are functioning.
Post
by scottwilkerson » Fri Dec 14, 2018 5:42 pm
danjoh wrote:
# 'check_nrpe' command definition
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 120 -c $ARG1$ -a $ARG2$
as stated before you need to change the command to the above
raydx wrote: Running ./check_nrpe - H 10.11.96.130 does return NRPE v3.2.1
This doesn't seem quite right, is 10.11.96.130 the windows machine?
raydx
Post
by raydx » Fri Dec 14, 2018 5:59 pm
commands.cfg updated and In the GUI Configuration:
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 120 -c $ARGS$ -a $ARG2$
Status Information is NRPE Plugin for Nagios which is not correct.
10.11.96.130 is the Nagios Server running on Ubuntu v16.04
Post
by scottwilkerson » Fri Dec 14, 2018 6:02 pm
raydx wrote: commands.cfg updated and In the GUI Configuration:
This is still incorrect, it needs to be
You want to run the command using the Windows servers IP not the Nagios servers IP
raydx
Post
by raydx » Fri Dec 14, 2018 6:18 pm
Ok, now the GUI Configuration does show:
On the Windows Server machine and using nscp, do I run ./check_nrpe - H 10.11.103.104 or
check_nrpe -H 10.11.103.104?
Thanks again for your assistance.
Post
by scottwilkerson » Mon Dec 17, 2018 8:11 am
If 10.11.103.104 is the Windows server you would run the following from the Nagios server
raydx
Post
by raydx » Mon Dec 17, 2018 12:04 pm
Running ./check_nrpe -H 10.11.103.104 returns:
I (0.5.2.35 2018-01-28) seem to be doing fine...
In the Nagios console for the check_eventlog services, I'm now seeing:
Invalid command line: unrecognised option '-a'
Post
by scottwilkerson » Mon Dec 17, 2018 12:37 pm
raydx wrote: Running ./check_nrpe -H 10.11.103.104 returns:
Ok, good, this looks like what we would expect
Lets run this
./check_nrpe - H 10.11.103.104 -t 30 -c check_eventlog -a "filter=provider = 'Application Error' and id = 1000 and message like 'Spacelabs.SLNIService.exe'"
If you still get
raydx wrote: Invalid command line: unrecognised option '-a'
Lets show the output of this
raydx
Post
by raydx » Mon Dec 17, 2018 1:14 pm
I ran ./check_nrpe - H 10.11.103.104 -t 30 -c check_eventlog -a "filter=provider = 'Application Error' and id = 1000 and message like 'Spacelabs.SLNIService.exe'" and the following was returned:
OK: No entries found| 'problem_count'=0;0;0
